TR2/3/3A TR2 Rear Plate Lite on TR3A
JFS
Bronze
Will the TR2 rear license plate light interchange with that of a TR3A? I like the idea of adding a third brake/tail light, but don't want an outline of the previous light to show on the paint, nor do I wish to drill more holes. Anyone know?
TR3driver
Great Pumpkin - R.I.P
No, they mount differently and are slightly different shapes. The early light mounts in a large center hole, while the later one has 2 smaller holes to the sides.
Geo Hahn
Yeah, with the TR2 Triumph invented the 3rd brake light... just didn't have the 1st and 2nd light yet.
I changed the turn signal fixtures to dual filaments ones (like the front sidelamps/turn signals) and used the second filaments for 2 more brake lights. It does make the rear turn signal harder to see when the brake lights but that's a trade-off I live with.
TR3driver
Another option, if you're so inclined, might be to remove the chrome cover and put some LED 'stars' inside. You would need to provide some kind of current limit, either a resistor or an active current source. (I used a simple two transistor current source.)
JFS
JFS
Bronze
Or https://litezupp.com/epages/ac0e8ca...h=/Shops/ac0e8cab-e6c1-4d6b-ab90-9213bdc3f061
Their description:
Below is a TR3 rear lamp. As you can see the right angle version fits in the socket and projects out the lens in a TR3. We recommend matching lens color to the LED as LEDs have a very narrow spectrum of light and you will get the maximum transmission of light through a color matching lens. We use four LED devices that provide up to 180 degree of beam out of our product so you will get a wide beam that will fill the rear lens with light.
TR3driver
I could be wrong, but I don't think that will fit in the license lamp. It uses single filament bulbs with a smaller base (and globe) than the others.
JFS
JFS
Bronze
I'm thinking their use in tail lights rather than adding the third light. I've also seen some nice looking led license plate frames, but would like something located up higher.
TR3driver
My thought was to have something that was clearly a brake light, even if people didn't see it come on. I've had several people in the past mistake the original corner brake lights (on my old TR3A) for tail lights.
This seems to have been effective. I've noticed that people are more apt to stop a bit farther back, rather than running up until I disappear under their hood ornament! The video below also shows my LED tail/brake/turn on the left, with a tungsten bulb on the right. Not a huge difference, but I like how the LEDs come on just a tiny bit sooner than the incandescent.
[video=youtube;q4GMcD9DktQ]https://www.youtube.com/watch?feature=player_embedded&v=q4GMcD9DktQ[/video]
TexasKnucklehead
I chose a third LED brake light bar that fell out of a friends Celica spoiler during one of her accidents. A few days after another friend was rear ended in his TR3 by a pickup at a red light that didn't see him, I installed it on my luggage rack. It is much higher and more visible IMO. I drilled through the latch and wired it thru a 1/4 amp fuse thinking if the wire ever chaffs, the small fuse will blow and the remaining brake lights will function. It is attached to the rack with some plastic wire clamps and can be rotated up or down. It's high enough that I can see the reflection on the trunk lid in the mirror at night. I drive in congested traffic often and want all the visibility I can get.
Administrator
Boss
This is a test reply to see if you get a notification email for the subscription to this thread.
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
C TR2/3/3A TR2 Rear axle setup Triumph 1
C TR2/3/3A TR2 rear axle disassembly Triumph 13
TR3driver TR4/4A "Mad Marx" rear main seal for TR2-4A once again available Triumph 10
TRJohn TR2/3/3A TR2 rear axle woes Triumph 6
1 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 4
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 5
S Wanted tr2 original grill Triumph Classifieds 10
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
S TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
R TR2/3/3A TR2 Scam Triumph 13
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
M General Tech TR2 Slave cylinder Triumph 0
