TR2/3/3A Flushing Hydrulic Fluid
frankfast
I have to replace both master cylinders and while I'm at it I'd like to flush out both systems and replace the old fluid with DOT 5. What is the best way to flush it out? I'm thinking that I can use compressed air to blow it out. That means disconnecting the lines to all the cylinders and then treating the cylinders separately. Is that the way to go or is there a better way?
Geo Hahn
You'll get various opinions on this.
I just sucked out what was in the reservoir, filled it with DOT5, then pedal-pumped and bled (one corner at a time) until the new stuff was coming out.
That was 18 years ago in the case of the TR3A.
How nice or nasty is the fluid in there now? If it looks pretty good (amber, not black) then that may help in your decision.
Got_All_4
I did exactly what you are planing to do. Don't remember where the info came from but it was strongly suggested that it be flushed out with isopropyl alcohol. Took a couple of bottles and pumped them through a couple of times by saving and reusing it. Then took a couple of fresh bottles (quart each) and did the same with each one of them until the alcohol ran clean. To dry out the system I had an old reservoir cap so I drilled a hole in it to accept a air nipple. Then screwed it on top of the reservoir and ran compressed air through it for about a half hour through each individual bleeder screws. That was a couple of years ago and like GEO says no problems. Also no worries!
Popeye
I am far from an expert, but after flushing with alcohol it seems care needs to be taken to ensure all solvent is out. Otherwise the resulting fresh fill of fluid will be thinned.
Can any chemists in the group talk about what happens to "dissolved" hydraulic fluid - meaning fluid that the alcohol has dissolved/thinned, but still remains in the system. The air will evaporate the alcohol, but will it evaporate the "dissolved" hydraulic fluid?
Got_All_4, I am not doubting or debating what you did in the slightest. Just curious about the cautions one must take.
Geo Hahn
Both methods will leave some old fluid in the system though much less so in the case of the alcohol flush.
All I can say is that (on 3 cars in my case) it hasn't been a problem.
I have never disassembled a caliper after doing this - I have replaced pistons and seals through the years but never had to split a caliper open - so I cannot say what is in there.
F
frankfast
I am told that DOT5 will mix with DOT3 and 4 so even if the old brake fluid is not completely flushed with air there shouldn't be a problem if a little of the old fluid remains.
TR4nut
Dot 5 won’t mix, but as Geo has seen some residual Dot3 or 4 hasn’t been an issue. I used denatured alcohol and air dried, worked on 2 cars and I currently converting a third. In my case I changed out the rear cylinders at the same time - they are pretty cheap and it avoided any worries of hurting the seals.
dklawson
This board has had some rather lengthy threads on DOT-5 and DOT-5 conversions. In addition to this thread you should search for some of the older ones. I don't wish to repeat all of their content here but I will make the following statements. These are based on personal experience as well as what I have seen with others first hand.
  • DOT-5 will NOT mix with any other brake fluids. Period. Clean all old fluid out of the pipes.
  • Yes you can flush DOT-3/-4 out the lines with isopropyl. Do it multiple times and blow the lines dry between alcohol rinses.
  • Do NOT use DOT-5 with seals that have already seen service with DOT-3/-4. Replace ALL the seals with new and include with that the rubber flex hoses, and the internals of things like brake servos and PDWAs.
  • If you happen to be working on a car with a hydraulic brake light switch, expect it to fail after switching to DOT-5. Some say the Harley brake light switch is compatible and will work. Others convert from a hydraulic switch to a pedal actuated switch.
Once a rubber part has been used with one fluid, it will not work well with other types. That means new or rebuilt wheel cylinders and rebuilt calipers. Your best, longest life will come from replacing all the contaminated rubber bits and thoroughly flushing the old metal lines.
Geo Hahn
I am told that DOT5 will mix with DOT3 and 4...
Not only will it not mix, but the DOT3/4 will suck the purple color out of the DOT5. When I first converted using the brute force / crude method mentioned above the DOT5 turned colorless. Now, after many years and subsequent flushes/replacements it retains its purple color - suggesting that either most of the old DOT3/4 is gone or that what is hiding somewhere is saturated with the purple dye.
TR3driver
Great Pumpkin - R.I.P
Right, DOT 5 won't mix. However, it is compatible, the two can co-exist peacefully. In my experience, it seems that the non-DOT 5 absorbs not only the purple dye, but also any moisture and wear particles, etc. such that it eventually turns into a black goo. Unsightly, but doesn't seem to present any problem except perhaps (if it settles inside a caliper) boiling easier than DOT 5.
DOT 5.1 is not silicone, and will still eat paint, absorb moisture, degrade over time and so on. Better than DOT 4 (higher BP and all), but not as good as DOT 5 (for our old cars, IMO).
I agree that "best practice" is to replace all the seals, soft lines and so on. Preferably using the SS/teflon soft lines instead of rubber. (Good time to think about replacing those antique hard lines too.)
However, I'm not convinced that it is always essential to do so. For example, I converted a 1980 Chevy to DOT 5 in 1988 by just bleeding through at all 4 corners until clear purple fluid came out. One caliper was replaced (it was leaking before), everything else remained original. I never touched the brake hydraulics again, they were still working perfectly when the car was junked in 2005 (with roughly 250,000 miles on it).
If you do want to flush the lines, you might consider using brake cleaner rather than rubbing alcohol. It's a much better solvent, and unlike rubbing alcohol, doesn't contain water. Personally, I wouldn't use shop air either, as it is often contaminated with water and/or oil. Or at least use a filter on it.
jimstr4
I followed Randall's advice and converted to Silicon.
My lines had been removed from the car during the restoration (still going on), emptied but not flushed.
There was a bit of the old Dot 4 fluid pushed out by the silicon but not alot and my brakes work perfectly.
The silicon seemed to be harder to bleed and was alot more expensive in New Zealand but I'm sure it's worth it as the old fluid ended up corroding all my hydraulics.
Jim and the stationary TR4
DornTRoriginal
Does anyone know how much fluid is need to refill the entire system? Is a one quart bottle enough to complete the task?
Geo Hahn
The capacity of the system is less than one quart though, depending on what you are doing, you may use the rest of the quart for flushing.
TR3driver
Isopropyl is commonly available at drug stores or perhaps even the grocery store. Just ask for "Rubbing alcohol".
I actually used Methanol (yet another kind, aka "wood alcohol", aka methyl alcohol) back when, as it is supposedly compatible with rubber brake lines (the other two aren't). Harder to find, but my drug store had it behind the counter. It's much more poisonous than the other two, so they don't put it out on the shelf.
dklawson
Read the label on the rubbing alcohol. There are still some brands that are denatured ethanol. Both the ethanol and isopropyl rubbing alcohol are typically a certain percentage water. Isopropyl is a better solvent. If you choose to use rubbing alcohol, be sure to blow the lines dry.
Electronic supply firms sell isopropyl without water.
Also look for it by its other name, isopropanol.
jdubois
Right. I don't know how the very popular idea that DOT5 and DOT3/4 aren't compatible and will destroy the world if mixed came about. US DOT regulations actually require them to be compatible, and have stringent compatibility tests that must be performed on the fluids before they can be sold. Extensive testing in Europe in the 70's showed a 50/50 mix of the two will work without issue for many miles of driving. The main problem with mixing them is that you don't know exactly what percentage you have and so you don't know your boiling point. Not usually a big issue on street cars. The Australian army did some testing in the 80's looking at what happens when you convert from DOT3 to DOT5 by flushing. What they found is that you will always have a non-insignificant amount of left over DOT3 in the system, mostly in the bottom of the calipers (because the bleeder valves are meant to bleed air, not fluid) and it is very hard to determine how much exactly is left, so they abandoned the practice.
CJD
After the previous threads we came to a limited conclusion that Silicone is likely better in dry climates, where there is little moisture to settle to the bottom of calipers and cause rust damage. Glycol fluid is likely better for wet climates, as it absorbs the moisture, preventing it from settling to the bottom and causing rust. Of course you would have to change the glycol fluid before is saturates.
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
B Flushing brake/clutch Austin Healey 16
Scotsman TR2/3/3A Flushing break lines on TR3 Triumph 3
AUSMHLY Flushing the transmission and overdrive Austin Healey 6
T filling/flushing steering rack Spridgets 7
D Flushing the coolant. Austin Healey 23
T Flushing brake and fuel lines Triumph 3
hondo402000 TR6 flushing your cooling system, TR6 car specific Triumph 14
J TR2/3/3A Flushing out my TR2 brake system.... Triumph 4
davidk Flushing DOT 5 Fluid Triumph 5
ronzet MGA Speaking of Flushing -- MGA MG 13
Foghat73 Back Flushing? MG 19
T Radiator Flushing Triumph 7
zimmy flushing antifreeze 74 midget Spridgets 3
mrstinson Flushing Radiator and Replacing Hoses --- Suggest? Spridgets 7
S Wedge Flushing of Gas Tank on TR7 Triumph 4
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
E General MG Transmission Fluid Level MG 2
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
M Wedge TR7 break fluid Triumph 7
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
P Subaru fluid leak Other Cars 9
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C MGA Shock fluid MG 14
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
longbridgehealey Clutch fluid Spridgets 7
K TR2/3/3A Steering box fluid again.... Triumph 2
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
Rut Latest fluid recommendations Spridgets 5
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
D General TR Fluid Film Rust and Corrosion Inhibitor Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
M Brake fluid on tire - cylinder need replaced? Spridgets 19
