TR2/3/3A Apple Hydraulics vs White Post Restoration
ckeithjordan
Has anybody had current experience with the above-named rebuilders of brake/clutch cylinders? I found some forum references from 10-20 years ago, but nothing more recent. Apple charges $125 per brake/clutch master cylinder, White Post $225 per, quite a difference.
CJD
I used White Post 4 years ago. All is good with the rebuild. Is Apple re-sleeving the cylinders with bronze at that price?
ckeithjordan
ckeithjordan
I asked Mark Macy what they charge to rebuild and he replied they don’t rebuild, they install new TRF or Moss ones. Aside from costs, what might be the benefit of one or the other (rebuild vs. new)?
By the way Moss has them on sale for $21.95(!), though out of stock at the moment, TRF’s are about $41.95, I think.
groupdeville
Shops install new units to avoid the potential liability of rebuilding a brake part: if a shop does a rebuild, they're liable if the brakes fail and losses are incurred. If they simply install a new unit, then the liability for the unit generally flows to the manufacturer of the brake cylinder. Nothing to do with whether a new or rebuilt unit is better, and everything to do with ducking potential lawsuits.
TFB
I have 10k on a Moss brake master with no issues,while I am on my fourth clutch master.Leaking from cylinder bore wear was the issue,likely due to longer stroke and way more frequent use.The internals are always fine with dot 5.
Moss replaced the last one on warranty.I took the new internals out and sent to Apple with a worn Moss cylinder and they resleeved,awaiting installation but looks nice with brass or bronze sleeveand a closer fit on the piston.
3 weeks and 90+since I supplied the internals..
I think all the available cylinders are the same except for some name castings in some like the Willwood.
Moss did say they changed the design,this well after the recall issue,but the last cylinder was the same as the previous 3,in and out.They do have a slightly different boot and rubber band but not an issue for me.
Tom
ckeithjordan
ckeithjordan
I can appreciate the liability issue, but shops rebuild all kinds of components where failure could be a result (and catastrophic). Apple Hydraulics and White Post rebuild brake parts and are subject to that same liability. Mark stated that time was a factor, plus his opinion that new was better. I did not ask why.
My particular follow-on question is really about owners' opinions or experiences with new versus rebuilds (plus I'm still looking for additional comments about the two rebuilders).
CJD
In my case the TR2 master cylinder is no longer available. There are repros...but they are obviously “unoriginal”.
windsor
I used Apple to rebuild the lever shocks as well as the brake and clutch master cylinders on my TR6 4 years ago . I was happy with the work . In the case of the master cylinders , I powder coated them before having them sleeved
2long
I used Whitepost for my double bore TR2 Lockheed master cylinder on the TR2 and the Doretti, and the rebore (with stainless, I think?) has been fine. An ownership change occurred in the last 3-5 years ar Whitepost, I believe, but they did really nice work for me and backed it up with a lifetime guaranty. I would recommend a quality rebuild of an original part rather than a cheaper newly manufactured part. There have been problems with classic gold stuff in the past, and its hard to keep track of what quality standards are used. I don't think the rebuild or reboring is rocket science, so maybe Apple can do as well as White Post.
Dan
donbmw
It will be 20 years in October when Apple did both my calipers.
TR3driver
Great Pumpkin - R.I.P
Same thing applies to early Girling MCs.
Resleeving seems like it should be fairly easy, but so far has frustrated my meager machining skills. For one thing, the bore is not actually straight but changes size near the bottom. For another, the mounting flange is not rigid enough to hold the cylinder while boring it out for the new sleeve. The casting flexes, causing the bore to be tapered.
BL50
Bronze
I've used Apple a number of times with excellent results.
Grantura_MKI
White post was sending out the work to another shop in the past. They may now have the machines, but would use Apple if I was on the east coast.
i know this, because I had a problem and Billy at White Post referred me directly to the shop that did the work.
D TR2/3/3A Carb work by Apple Hydraulics Triumph 2
AngliaGT For Sale TWO Apple Hydraulics Gift Certificates Jaguar Classifieds 1
T Apple Hydraulics for M/C re-sleeve Triumph 11
testaj Apple Hydraulics Shocks MG 10
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
R Clutch Hydraulics Spridgets 4
P TR6 Clutch hydraulics Triumph 6
F TR2/3/3A Bleeding Hydraulics Triumph 9
TR3MT TR2/3/3A Clutch Hydraulics II Triumph 8
S TR6 life of TR6 hydraulics Triumph 5
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
Lukens TR2/3/3A Clutch hydraulics ? Triumph 8
Lukens TR2/3/3A More questions concerning clutch hydraulics Triumph 9
sundown TR6 1973 TR6 hydraulics Triumph 1
JPSmit Trivia question - clutch hydraulics Spridgets 16
PatGalvin TR2/3/3A 5-way valve, brake hydraulics Triumph 4
Rut Brake hydraulics Spridgets 3
Kleykamp clutch hydraulics ??? Triumph 8
John_Mc Clutch hydraulics-to hone, or not to hone? Triumph 14
drooartz Hydraulics or Engine first? Spridgets 18
drooartz RHD vs LHD hydraulics Spridgets 2
Steve P. Brit vs. American hydraulics Spridgets 10
H Hydraulics -- Rebuild or Buy New? Triumph 12
Nunyas T-Series Sloooooowwwww leak in Clutch hydraulics MG 38
SunbeamTom Clutch hydraulics rebuild Sunbeam (Rootes) 2
danielnorton After Marke slave cylinder for clutch hydraulics? Spridgets 20
Brosky Silicone vs Dot 4/5 in new CLUTCH hydraulics? Triumph 17
MGTF1250Dave TR2/3/3A TR3A Clutch Hydraulics Triumph 8
J TR4/4A TR4A clutch hydraulics Triumph 2
zimmy bleeding new clutch hydraulics Spridgets 19
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
B Dodge Chrysler Cool Vanilla = Old English White? Spridgets 7
M Old English White Paint Code for early BE Spridgets 1
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
S TR2/3/3A de-bossed sections that are painted white Triumph 2
Jim_Stevens TR2/3/3A Pearl White not what I expected Triumph 22
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
Jim_Stevens TR2/3/3A Nimbus White? Triumph 15
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
71TR6 TR2/3/3A Modern paint code for 1959 Triumph #19 Pearl White Triumph 20
TomMull White Mold Restoration & Tools 3
D For Sale TR3A-B Side curtain set - white Triumph Classifieds 1
Jim_Gruber Paint Codes for Olde English White Spridgets 11
5 Old English White Bugeye on E-Bay Spridgets 10
M Spotted: white Healey 100...in Maine Austin Healey 2
M Mystery white smoke Spridgets 11
T TR2/3/3A For sale: New side curtains, white, for later tr3a Triumph 8
