Left Rear Shock Mount
John Turney
I'm not liking the look of these:
IMG_1411-Reduced.jpgLeft Read Shock Mount-Lower Front.jpgLeft Read Shock Mount-Lower Rear.jpg
While replacing the left axle shaft, bearing, etc. I noticed these cracks. Looks like some drilling to stop the cracks and welding is in order.
gonzo
Common fatigue area. Did you find any signs on the other side? Prep, drill, weld, finish and enjoy. Good luck with the repair. A Hot Rod (muffler shop) did mine before I had any welding skills. It's held up nicely after all these years. Gonzo
John Turney
John Turney
No sign on the right side; that was the first place I looked.
I have Waxoil inside the frame. I wonder if it will ignite?
roscoe
I'll watch for the mushroom cloud. I welded a couple of small cracks in that area a few years ago. Filled the gas tank (less vapor phase that way) and welded away. If you are really concerned about the waxoil, just purge the frame a bit with some argon or whatever inert gas you weld with.
bob hughes
Much sucking of teeth!
Get the grinder out and channel out the cracks or a series of small holes and then weld 'em up. I doubt if the waxoil would cause much of a problem but just in case try a sample weld on a piece of steel with waxoil on it and see what happens.
PS Then let us know the results :wink-new:
:cheers:
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
Martinld123 My left rear wheel is locking up Austin Healey 16
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
D Problems with left rear turn signal Austin Healey 11
G TR4/4A tr4a irs left rear wheel Triumph 14
D Left rear hub nut Austin Healey 9
RickB MGB NOS left rear bumper for 70 MGB - GONE for $62 MG 0
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
M Left shock Spridgets 4
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
B TR2/3/3A TR3 sag to the left [port sag] Triumph 10
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
M Wanted Bj8 left front wing Austin Healey Classifieds 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
Rut I’ve lost my mind, or what’s left of it! Spridgets 12
Tosh TR6 Engine dies slow left turn. Triumph 26
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
F BN7's left Austin Healey 9
PeterK General TR Timely memory of a time capsule left in my 3A Triumph 19
C Left to right hand drive Austin Healey 2
Lotus Club SoCal Left Coast Octoberfest Lotus 0
T Wanted TR6 Left Taillight Housing Triumph Classifieds 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
Boink Left-hand Drive E-type at Windsor Jaguar 5
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
B TR2/3/3A Tr3a brakes pull to left on hard braking Triumph 9
Popeye TR4/4A Seats - left/right Triumph 8
C TR4/4A left brake lamp not lighting TR4A Triumph 4
Jim_Gruber Bugsy II - Left for a new home this morning Spridgets 4
P TR6 Left direction signal no work Triumph 15
D 69 E-Type sputters when making left hand turn Jaguar 6
GTP1960 TR2/3/3A New left front wing body panel from TRF? Triumph 11
M TR4/4A Left lower dash crash pad. Triumph 5
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
P T-Series TD Door Hinges: just what is the difference between right and left? MG 11
K TR2/3/3A Pullsl to the left when accelerating? Triumph 9
AngliaGT What Goes to the Left of the Tach? Spridgets 3
SD Bugeye Are there any of us with 948 builds left? Spridgets 13
C Pulling to left Spridgets 8
