TR4/4A Wiper Arm Question
ghawk16
OK...So I've looked at tons of pictures and seen them both ways. Are both the wiper arms on a TR4 straight or does the passenger have a bend? Did the bended arm come in after a certain commission number? Do the TR3's have two straight arms and it went into the TR4 run and then they switched it? Like I said, I've seen TR4's with two straight arms and some with a bent passenger and straight driver so I'm stumped. I bought an aftermarket bent one but the finish doesn't match my refinished straight arms so was thinking just running straight arms for both. I did a search and didn't get a real answer. Thoughts?
TR3driver
Great Pumpkin - R.I.P
The information I have is that none of them were entirely straight. TR3A had a 15 degree bend at the end; TR4 had a 10 degree bend on one arm and a 40 degree bend on the other. There is a change in the Lucas part number for the 40 degree arm, but the description and Triumph part number remained the same.
M_Pied_Lourd
Does the tr4 have the pop up fresh air inlet duct in the center of the scuttle (like my TR250)? Weren't the bends in the arm to clear this?
Cheers
Tush
Geo Hahn
...There is a change in the Lucas part number for the 40 degree arm, but the description and Triumph part number remained the same.
That, of course, illustrates the arms for a RHD car (oddly, I have a set of those on the shelf). There will be different parts for LHD.
Can't imagine not have the benefit of that scuttle vent and can't imagine how it could be used unless the wiper arm above it was cranked.
G
ghawk16
This plus...If the passenger side arm wasn't bent, the blade wouldn't be able to park at the base of the windshield.
See...that's the biggest thing and it makes sense as I do have the pop up vent. However, it's almost like Triumph realized this after the fact and still put some "minor" bend ones on for the driver and passenger on LHD drive cars. Anyone out there with low commission 62/63 TR4's that may be able to say "yes, I have the 40deg bend one.
I know Marv was going to check to see if he had one for me that of course would have to be chromed to match. Oh well. Now looking for OEM bent wiper arm! Anyone?
charleyf
Gary,
In my cache of parts I found two of the 40 degree bend wipers. One has an arm that measures .20" and the other measures .375 " wide. My two TR4's that are between 17000 and 20000 have the smaller width blades and both have the 40 degree bend.
Let me know if you are interested in either of these. They are both bright finished. Also the "other " wipers on my cars do have the 10 degree bend right at the tip.
G
ghawk16
Gary,
Thanks Charley. I may have to take you up on that offer. I will have to measure when I get back to my garage and see what the width is. Both my arms are straight and what is odd is one is longer than the other. I just used the shorter one, but I'll measure those as well and let people here know and maybe they can tell me which length is right. Thanks again all!
G
ghawk16
Gary,
Charlie, well I measured and mine are .20". But of my two straight arms, one is 11" in length and one is 12" in length. Anyone know which one is the correct length a s I recently have the 11" one on. Also, Charley would you happen to have an extra screw that goes in the end of the wiper arm and connects the wiper? I stripped my other one trying to make the TRF wiper arm work as I had to drill and tap but the metal was too hard and I accidentally stripped it.
charleyf
Gary,
I will look for the screw and get a length measurement and get back to you.
TR3driver
Yes, the bends are opposite directions for LHD.
Length is given as 11-1/2" for both
But the way they measure is a bit odd
G
ghawk16
Great info! Thanks. And sadly...neither one of my arms have the 10deg bend so I think those aren't even the right ones. I'm betting that the longer one is what I should use since the way it shows they measure the arm I'd be at 10.5" with the one installed right now. However, no 10deg bend in them sooooooo Charley...have a 10deg one as well? HAHA Guess the finishes will match now!
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
F TR2/3/3A Beware eBay wiper blade and arm sales Triumph 6
W Removing wiper arm on 74 XJ6? Jaguar 0
B Windshield wiper arm MG 3
I TR6 help with TR6 windshield wiper arm removal Triumph 6
chicken Windscreen wiper arm, what length Austin Healey 9
AUSMHLY Wiper arm and wheel box Austin Healey 3
tomshobby Wiper arm pressure? Triumph 2
G Even Karmann couldn't grasp the wiper arm design Triumph 4
J Wiper arm box - mk1 right hand drive sprite Spridgets 0
Rob_P Wiper arm MG 8
S Mystery Wiper Arm Attacfhment Austin Healey 7
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
R TR2/3/3A TR3 Wiper motor Triumph 10
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
R TR2/3/3A Wiper Arms Triumph 8
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
R TR2/3/3A Windshield Wiper System Triumph 2
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
M TR6 Wiper washer knob Triumph 5
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
P Wiper direction Austin Healey 9
R GT6 Wiper Motor problem and time capsule Triumph 4
N TR2/3/3A Wiper motor armature Triumph 11
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
J TR2/3/3A Wiper Motor bracket Triumph 5
JPSmit Question - wiper switch and signal switch ends Spridgets 4
T TR5/TR250 TR250 wiper switch and motor Triumph 1
