Repacking the muffler
steveg
Here's an interesting thread on repacking a Lotus Elan muffler with a Brit product - Acousta-Fil:
https://www.lotuselan.net/forums/lotus-twincam-f39/how-repack-non-repackable-silencer-t36438.html
My Moss replacement, which had been used for several years, had fiberglass packing in the front 2" or so but was otherwise empty.
83 - 85 DB in spirited driving.
I've ordered the product from the aptly-named DemonTweeks.com and will follow up with the installation.
RAC68
Hi Steve,
Very interesting and I know a friend that will be as well. Looking forward to hear about your experiences in this area. I am always interested in Fixing or making rather than buying.
Ray(64BJ8P1)
glemon
I remember reading a story in Road & Track magazine many years ago about some guy's first MG TC, he talked abouthow the sports car guys would pull the stuffing out of the mufflers with a bent wire hanger to get a more sporting exhaust note. I have never tried stuffing or unstuffing, but it is good to know a man on a budget has options. Certainly much better than tuning the "engine sound" that some modern cars play through their sound system.
DerekJ
I have the DWR side exit exhaust which has got louder to such an extent its right on the scrutineering noise limit of 105 db. They are expensive to replace so I'm interested in the re-packing option. BTW Demon Tweeks is a long established, very successful UK speed shop. Its owners race some very expensive classic cars including a Maserati 'Birdcage'.
GregW
Platinum
I had a Micron exhaust on one of my motorcycles. It was designed to be repacked in that it didn't use rivets but stainless screws. Take 4 screws off and the core would slip out. I repacked with long strand stainless wool. Micron's website.
Michael Oritt
Randy--
There was a Supertrap on my Courier when I bought it. It made the car (MGA engine) sound like the typical fart can-equipped Honda Accord that flat-hatted kids seem to love. I removed it in short order.
Think about meeting at Sebring this March 1-3....
Deleted member 21878
don't use steel wool. not a good idea.
a few years ago i had a 66 vette that i put side pipes on. wow were they loud. the whole car would resonate and vibrate. even with the top down you could not hear yourself think.
i went out and bought a bag of scouring pads. they are stainless steel and do not rust. first i drilled a hole in the pipe before/after the muffler chamber. ran a screw that would go all the way to the other side. then i stuffed in one ball in each side. then 2 balls and then 3. i ended up pulling the last one back out and keeping just two in there. then i drilled and put another screw behind them. they never blew out and really made the car a lot quieter. at idle it sounded more like the mufflers that were on it to begin with. it was a little louder under acceleration but nothing unbearable.
i had read where guys had taken off their mufflers off and put the balls in the down tube. they said it made for a better / different sound. i never tried that. i was happy with them behind the muffler.
steveg
steveg
Demon Tweeks just sent me a 538 page catalog for rainy-day reading. Their name has got to be a marketing masterpiece! Roger Corman (I Was a Teenage Frankenstein) would approve - IIRC he considered a good title to be 80% of the marketing!
HealeyRick
Agreed, very cool name and must have worked since they've been around since the early 1970s. IIRC they were primarily a Mini supplier in their early days.
Healey Nut
Demon Tweeks .....theres a blast from the past for me . I remember buying a cherry bomb muffler for my Ford Fiesta XR2 from them way back 35ish yrs ago when I used to live in the UK . They were located in Chester which was just a quick drive for me to go to the store . They were the go to guys for performance tuning parts for many cars .
Jerry
The muffler I bought for my TR3 was too long so I cut out a section. Full of fiberglass stuffing. I put it all back in and welded it back together. It sounds good and does not leak! I never expected to find so much stuffing in there. I do wonder how long it will last.
Randy--
Absolutely!
Yes, I said the SuperTrapps were popular, I never said they sound good ;)
(press your hand tightly over your mouth and blow; THAT's what a SuperTrapp sounds like!)
I once saw a pair of them on an M Coupe, but years later when I worked on that car for another owner, they were long gone.
steveg
steveg
Current build status - building the muffler while awaiting the Acousta-Fil from Demon Tweeks.
I used reducers from the auto parts store as slightly-bell-mouthed connectors for the internal perforated tubes.
The internal locator piece is 1-1/2" x 1/16" aluminum from the hardware store. Screws are 10-32 x 3/8" SS threaded into the aluminum.
I staked the bell connectors in as I don't yet have welding.
Tomorrow will fit more screws into muffler body.
Muffler ends were enlarged to fit header connectors.
I don't think the aluminum will stand up to the temperature, leaving the screws to fall out.
Steve, I think it's about time for you to step up to a MIG welder (just think of what you can accomplish then!)! Check the classifieds (Craig's list, ebay) for a good used Miller, Lincoln, or even Century.
If you're dead-set on screws, to be able to have future access, change out the aluminum to steel__and a little thicker to get another thread or two in there wouldn't hurt either.
steveg
steveg
When/if the aluminum poops out, will switch to stainless sheet - for which I need to find a source.
Concerned about regular steel corroding away. Whatever I build needs to be able to be disassembled to be repacked.
Addendum: Read up on aluminum melting point; bought some SS sheet and will redo and follow up.
warwick-steve Front hub bearing grease repacking Austin Healey 28
S Wheel Bearing Grease/Repacking Austin Healey 1
S Repacking Front Wheel Bearings Austin Healey 16
S TR2/3/3A tr2 muffler clamp Triumph 10
KVH General Tech Improvement to TR4A Muffler Triumph 1
B Muffler Construction Austin Healey 2
HealeyPassion Reducing Muffler Heat Austin Healey 2
A Muffler/Ground Clearance Austin Healey 13
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
M Muffler Options with Exhaust Header Spridgets 1
FredApplerot For Sale Pace Setter muffler for 1964-74 Spridget - Brand New Spridgets Classified 5
Healey Nut Muffler bearings Austin Healey 5
T Which Harley-Davidson Muffler for a BE? Spridgets 3
Steve P. Side exhaust, which muffler? Spridgets 9
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
T Rattling stainless muffler Austin Healey 10
I TR6 Muffler suggestions? Triumph 6
W Good price on Pacesetter Monza Muffler Spridgets 0
D BJ8 muffler on a BJ7? Austin Healey 6
R muffler advice? Spridgets 76
DanLewis One or two muffler configuration on a 1275? Spridgets 16
M TR4/4A TR4A muffler hanger to cross member attachment Triumph 13
G Anatomy of a Harley muffler Spridgets 63
Morris Opinions on this muffler? Spridgets 11
5 front muffler mount to body Austin Healey 4
B Anyone need a Harley muffler? [NFI] Spridgets 7
B Spitfire Advice on Muffler for 69 Spit Triumph 5
JPSmit Header and muffler connected Spridgets 16
BugeyeNJ58 Harley Muffler Users - did you remove center plug? Spridgets 3
BugeyeNJ58 Put on Harley Muffler--now backfires?? Spridgets 26
drooartz MGB Does this MGB center muffler look right to you? MG 10
M Muffler Bracket Spridgets 4
BugeyeNJ58 Need a Better Muffler for 59 Bugeye Spridgets 5
CZ_Dave Search for Muffler bearings MG 12
Jim_Newman Yet another muffler question. Austin Healey 3
Rut muffler choice Spridgets 15
sqbsprite Today's Project-Harley Muffler Spridgets 25
T TR2/3/3A TR3 muffler clamp Triumph 20
glemon Thoughts on TR Exhaust/Muffler Options Triumph 3
Jim_Newman 3000 muffler design Austin Healey 1
KVH TR4/4A TR4A Muffler Removal Triumph 2
T AH Muffler used on other cars Austin Healey 4
T Muffler inlet/outlet pipe diameters [?] Austin Healey 3
I Bugeye exhaust stud length for muffler? Spridgets 2
I bugeye muffler attachement? Spridgets 2
W Location and size of hole for muffler bracket Spridgets 10
boxfullofyertoys Looking for a Harley muffler Spridgets 54
Michael Oritt Need muffler recommendation Austin Healey 16
S Monza Muffler Spridgets 14
S Looking for muffler shop in western burbs/chicago Triumph 5
