Results 1 to 3 of 3
Thread: On those old original coils
  1. #1
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    2,472
    Chats
    On those old original coils they had that wood screw kinda deal that went into the high voltage chamber. Can that be removed and cleaned without damaging anything, like letting the oil out? I just cannot visualize what that screw goes into and what a good way to seal it up would be when removed. Or if a guy should just leave it alone and clean the top of the screw with a shape screw driver and call that good.
    steve
  2. #2
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    4,383
    Chats
    Re: On those old original coils
    I assume it is soldered to the tiny high tension coil wire underneath...so, like you, I didn't want to mess with it. Not for fear of oil loss, but more because those wires are so tiny to deal with.
    In the end, I just used the bead blaster to clean it from the opening available.
    John
    1955 TR2
  3. #3
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    2,472
    Chats
    Good call with the bead blaster John, I must be getting old I forget sometimes about the bead blaster; heck years ago that was my best go to tool. I must admit, many years ago I pulled a screw out and put it back in with some Indian head gasket sealer and everything worked out fine, but I just do not trust taking one out. This time I have the original coli with lettering I think CB and SW or something and I am a little more causes. Thanks again good call.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
