Results 1 to 14 of 14
Thread: Tonneau Install Question
  1. #1
    Jedi Hopeful CessnaTPA's Avatar
    Join Date
    Apr 2015
    Location
    Tampa, Florida
    Posts
    122
    Chats
    I received a new stiffener bar set and rail for my 57 100-6 BN4 from Moss today and want to confirm the stiffeners should rest on the rail where the red arrow is at in the pic. I installed the rail support pins in the original bolt holes in the fender wells and not sure what the problem is. Any tips or pics of what it should look like would be greatly appreciated. Top.jpgTop.jpg
    1957 Austin Healey 100-6 BN4
  2. #2
    Jedi Trainee red57's Avatar
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    331
    Chats
    Re: Tonneau Install Question
    You are correct, the stiffeners should rest where your arrows are so the flap sewn onto the bottom of the tonneau can wrap around the bar and reach the turnbuckles.
    However, mine did not have the factory pins so I had to make some and therefore I don't know what the factory ones looked like. My guess is that the pins just need to be bent to a more vertical position and the bar will rotate forward.... However, I'm sure someone on here has more specific details, and perhaps pictures.
  3. #3
    Jedi Warrior Rob Glasgow's Avatar
    Join Date
    Feb 2003
    Location
    Lompoc, CA
    Posts
    650
    Chats
    Don't know about a BN4, but the stiffeners on my BT7 rest on to of the crossbar between the turnbutton and the front of the stiffeners, not behind the turnbuttons as you show. Of course, my cross bar is anchored by a hole in the side panels so it can't be installed in any other position. That may not be the case with a BN4.
    Rob Glasgow
  4. #4
    Join Date
    Feb 2003
    Location
    Lompoc, CA
    Posts
    650
    Chats
    Sorry, I must not have had my glasses on. Yes, the cross bar rests exactly where the red arrows are. At least that how my BT7 works.
    Rob Glasgow
  5. #5
    Join Date
    Apr 2015
    Location
    Tampa, Florida
    Posts
    122
    Chats
    Ok guys I think i figured it out. When I install the stiffeners under the bar the tonneau is held snug in place. But I still would like to know if this is the proper way. Like I said I used the original holes to install the rail support pins and wouldn't think Moss would sell the pins not bent correctly.
  6. #6
    Jedi Trainee davidb's Avatar
    Join Date
    Jan 2009
    Location
    ontario, canada
    Posts
    236
    Chats
    If you look on the Moss Motors website, "tonneaus and stiffener bar", they provide a visual as to how the tonneau bar and stiffeners are supposed to fit, and yes, the "flattened" end of the stiffeners sit directly on the tonneau bar. As Rob Glasgow points out, this allows the "female" side of the turnbutton to line up with the "male" end, which comes attached to the stiffener. Just installed one from Moss on my BT7 this summer and it fits well. I had to trim/grind the ends of several stiffeners to make them fit nicely into the stitched pockets of the tonneau top towards the trunk side.
    D.
  7. #7
    Join Date
    Aug 2016
    Location
    Greensburg, PA
    Posts
    81
    Chats
    Quote Originally Posted by CessnaTPA View Post
    Do you have the stiffener bars resting on top of the cross bar? The picture looks as if the stiffeners are beneath the cross bar.
    Jack
  8. #8
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    331
    Chats
    The stiffeners should rest on top of the bar where your arrows are so the flap sewn onto the bottom of the tonneau can wrap around the bar and reach the turnbuckles - that is why there is a flat portion at the end of the stiffeners. The bar appears too far rearward by an inch or so for some reason which is why I suggested rotating the bar a bit by bending the anchor pins a bit.
    Dave
  9. #9
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    331
    Chats
    davidb raises another question - are the stiffeners inserted far enough into the tonneau to rest on top of the rear cockpit trim pieces?
  10. #10
    Join Date
    Jan 2009
    Location
    ontario, canada
    Posts
    236
    Chats
    Red 57 asked the right question, and it was a good point - on the outer stiffeners I had to trim about a half inch or so, on the trunk side of the stiffener (and an angled cut to boot) to get the stiffener to fit nicely in the pocket at the trunk end, and ensure that the flattened part of the stiffener rested on the tonneau bar, otherwise it was too long. Remember that if you've replaced your tonneau cover or the stiffeners with aftermarket stuff, these are generically made, and have to be "tailored" sometimes to get a good fit on your car because there are slight variations from car to car since these cars were essentially handmade. In fact on my tonneau cover, the Tenax buttons weren't attached so I had to punch the holes and mount them myself, so my cover might not properly fit another car.
    Dave.
  11. #11
    Join Date
    Feb 2003
    Location
    Lompoc, CA
    Posts
    650
    Chats
    Just another comment. The cross bar, at least on the BT7 was painted a light grey. The same color as the hood frame. Looks like yours is bare metal. Being painted doesn't make the car work any better, but it's the way they were made.
    Rob Glasgow
  12. #12
    Join Date
    Apr 2015
    Location
    Tampa, Florida
    Posts
    122
    Chats
    The stiffeners are pushed all the way in. I'm going to remove the bar pins and bend them. I was wishful thinking this would be a no modified install. Thanks for the input.
  13. #13
    Join Date
    Mar 2003
    Location
    Hampshire in the UK
    Posts
    1,535
    Chats
    Metal stiffeners - that's posh, my BN4 had wooden ones, I did break one once but it was so easy to reproduce.
  14. #14
    Darth Vader John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    2,735
    Chats
    I had to trim the ends of my stiffeners to get them to fit properly.
    John, BN4
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
