Page 4 of 4 FirstFirst 1234
Results 61 to 72 of 72
Thread: 100/6 vs 3000 driving experiences
  1. #61
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,498
    Thanks Thanks Given
    10
    Thanks Thanks Received
    19
    Thanked in
    Re: 100/6 vs 3000 driving experiences
    Quote Originally Posted by tdskip View Post
    Good morning.
    Priced out a new interior and a set of Dayton tubeless wire wheels at Moss and just saw over $5500 go poof.
    Can you paint one of these to a good, but not outstanding, condition with the fenders and doors on?
    In a word, "NO!". The issue is with the seam where the stainless steel trim is. It's very difficult to sand close enough to the trim to get good adhesion and masking the trim itself is difficult, making it likely you'll face problems in that area in the future. You might be able to remove the trim by loosening the fender bolts, unbending the tabs that keep the trim in place and removing the trim, but at that point, you might as well go all the way and remove the fenders. Even more importantly, electrolytic corrosion (as Brinkerhoff mentioned above) will generally have gone to work between the steel fenders and aluminum shrouds. Unless you address that, you'll end up with bubbling along the trim.
    Rick
  2. #62
    Join Date
    Nov 2005
    Location
    SoCal
    Posts
    9,249
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by HealeyRick View Post
    That explains that join being thin / perforated on many cars I have seen.
  3. #63
    Join Date
    Dec 2010
    Location
    san luis obispo california
    Posts
    2,073
    Thanks Thanks Given
    Thanked in
    Well then,... who knows of a car with little to no rust, somewhat beat or not, for a reasonable amount of dough, so that our newfound friend may create his dream come true?..... Have we dispensed with the pre 57 requirement?... If so the range will open wide. The two seaters are costly, so they may be out of the running. I do believe the 100s are quite dear, the bn4s are restorable but it seems to me that starting with the bt7s, the motor is improved.. and with the tricarb bt7 the pinnacle base motor has appeared. Coupled with the hardtop and sliding sidecurtains the 4 seater makes a fine, roomy, all weather rally auto. Next come the curved windscreen bj7s with roll up windows that retain the spare no nonsense interior.,,, and then the bj8s, the final iteration in their magnificent splendor with the most power in stock form. WHEW,.... what do you all think?... Are you still game T?
    A wise man knows he knows not. Lao Tsu
  4. #64
    Join Date
    Nov 2005
    Location
    SoCal
    Posts
    9,249
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Good morning my friend, thanks for the note.
    Of all the long distance (~1000 events) only 2 have a '57 cut off. The California Mille (which always has a waiting list and we may not get in anyway) and the original Millie in Italy (which we are definitely not getting into).
    The age cut off is a very good consideration, and I appreciate it being pointed out, but I think I was likely too fired up about an unlikely in practice consideration.
    Thank I just got captivated with the potential rather than likely reality of what this car would take.
  5. #65
    Jedi Knight dougie's Avatar
    Join Date
    May 2008
    Location
    Portland, Oregon
    Posts
    1,476
    Blog Entries
    1
    Thanks Thanks Given
    13
    Thanked in
    Quote Originally Posted by elrey View Post
    I know you couldn't build this for what they're asking....
    https://www.carandclassic.co.uk/car/C816151
    Dougie
    '65 BJ8 3000 MKIII GN.29
    '57 100-SIX MM Vintage Racer GN.1 #414
    Team Healey PDX
  6. #66
    Join Date
    Dec 2008
    Location
    Calgary, Alberta, Canada
    Posts
    857
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Cooling (for both engine and passengers) and exhaust system clearances are weak links in the real world.
    Have a look at the later BJ8 frames with a view to notching yours to match to improve exhaust clearances (I don't know if this is feasible as I haven't tried it and don't think I've seen any threads discussing it) - losing the exhaust system on a speed bump would sure mess up a long distance run. There's quite a few threads on the site (and elsewhere) discussing ways to keep the engine cooling as well as keeping the heat out of the cockpit.
    Also there's a thread entitled 'Tasteful Upgrades' that could be worthwhile reviewing as various members have contributed the 'tasteful upgrades' made to their cars to improve comfort, reliability, safety, etc. etc.
    You could get a lot of suggestions on specific items as you make your decisions. Eg.: stock transmission, or Toyota? If you stick with stock seats, then modify them to increase the back angle and experiment with Norman Nock's suggestions regards drilling holes in the seat foam. Etc. Etc. etc. Plus folks have been rallying these beasts ever since they rolled off the assembly line, so someone has done pretty much everything you can think of. Doug
    1959 pristine 948 cc Bug-Eye; DCOE, 5 speed; bought 1971
    1960 BE bought 1971 & stored since; body tub restored and reassembling (1275; etc.)
    1962 AH 3000 BJ7; 3rd owner (1982?); in shop Oct. 2015 for paint job - home soon!
    1962 VW Meyers Manx clone dune buggy; stripped last winter and being reassembled
    1969 Kawasaki 500 H1 Triple, orig. owner; stored since 1973, but runs again! 1999 Buell S3
  7. #67
    Join Date
    Dec 2008
    Location
    Posts
    857
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Dang! When I was reading the thread, I missed the page where the decision was made to not jump off the ledge, so my comments above are a bit irrelevant. Doug
  8. #68
    Join Date
    Nov 2005
    Location
    SoCal
    Posts
    9,249
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by twas_brillig View Post
    Very helpful still - there will be other ledges!
    Thanks Doug.
  9. #69
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,498
    Thanks Thanks Given
    10
    19
    Thanked in
    6Hard to evaluate a car on an auction site, but this one looks like it might be a nice base to build a rally car. Undercarriage looks like the 67k advertised miles could me original: https://bringatrailer.com/listing/19...-bj8-mk-iii-3/ Hardtops are available in the UK to give it that works rally look, although they don't come cheap.
    Rick
  10. #70
    Yoda Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,040
    Thanks Thanks Given
    5
    13
    Thanked in
    I must take exception to the firm "No" with a caveat, though I will agree with Rick's statement if the existing paint is compromised and if rust has gotten into the joints.
    I recently had my car painted in that manner: All exterior trim--everything--was removed, the fender bolts loosened, the strips removed and the car shot with two-part paint. The existing paint was sanded/primed to and beyond where the trim touched the fenders. The result was very good, the painters did not have to spend a lot of time realigning all the panels and the price was reasonable because of the labor saved.
    The caveat is that the existing paint was in very good shape with the exception of 20 years of wear and tear since its body-off restoration in 1997--especially at and within the fender joints--there was no rust anywhere and the new paint was virtually the same color as the old.
    Best--Michael Oritt
    1954 Austin-Healey 100 Le Mans
    1958 Elva Courier (FOR SALE)
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  11. #71
    Join Date
    Nov 2005
    Location
    SoCal
    Posts
    9,249
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Thank you Rick, I will watch that auction. That's a very nicely presenting car.
    Thank you for the additional background Michael, that is good to know. On the 100/6 it would have to be completely taken apart based on what I learned.
  12. #72
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,498
    Thanks Thanks Given
    10
    19
    Thanked in
    Michael,I think we're saying the same thing. My firm "NO" was to trying to paint a Healey while leaving the stainless trim in. I'm sure Earl Scheib did it back in the day with lots of resulting cracking and peeling at the fender joins. OTOH, if you remove the stainless beading and there's no corrosion between the fender and shroud, you should be ok.
    Rick
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
