Ride height
Michael Oritt
My car has a small but definite list to port--the driver's side--perhaps as a result of doing too much solo driving. I have not measured the amount of lean in terms of the number of degrees but estimate that I would need to increase the ride height on the left side. both front and back, about 5/16" to 3/8 to make the car appear level when I am not in it--perhaps another 1/8" to 1/4" inch when I am aboard.
What is the best way of accomplishing this?
Rob Glasgow
I tried to fix mine by swapping the springs and it didn't change the list. Still low on the drivers side. Finally just accepted the situation. Maybe if I moved the steering wheel to the Right side, it would eventually even out.
Patrick67BJ8
Check the mounting ends of your springs to be sure you don’t have a broken one and that leafs are also not broken.that was my problem.
Michael Oritt
Michael Oritt
Interesting solutions.
I went back through the archives and found a discussion about just this from a number of years back. the Late Great Dave Russell suggested simply adjusting the bumper mounts to create the illusion of levelness but I think a cockeyed bumper looks even worse than a listing car.
roscoe
If you carry all the spare stuff that you might need for cross country trips on the RH side of the boot and put some extra ballast in the cockpit, perhaps one of those rescue dummies so you can use the carpool lanes, maybe it'll even out. Or go to RH drive. I'm surprised nobody suggested that as it also evens wear on the seat uphostry. All seriousness aside, I put in a set of Jule springs and it solved all my ride height discrepancies and they are a bit stiffer so I imagine they'll outlast me (probably not hard at my age). Seasons cheer to all.
RAC68
Hi Michael,
This was an issue that drove me mad for a number of years. Initially, I thought the springs were the issue and replaced the rear leaf springs. When the new springs were installed, the car was quite high in the rear and once they settled, I again had the problem.
After a number of years, I took another major try at it. This time I reinstalled my original leaf springs with the an additional second leaf from the newer set. This time the springs moderately raised the back of the car but the driver's side still seemed a little lower then the passenger side when measuring from ground to top of the fender openings.
Although the additional spring leaf on each side raised the car exactly as I wanted and even improved the ride, I still had the side-to-side difference. At this point, I decided to put a spacer between the axel and spring mount on the passenger side to slightly lower the body. As a result, both sides now appear to be of equal height and all is well with the world.
Hope this helped,
Ray(64BJ8P1)
Healey Nut
Two 24rs of real beer in the passeger footwell will fix it , dont use that lite american beer use some real beer .
Michael Oritt
Michael Oritt
Ray--
Thanks for the very helpful post. I have considered the addition of a leaf but I do not believe what would effectively be a different spring rate from one side of the car to the other to be a good solution. I am going to examine the approach of either dropping the right side a bit, as you suggest, or in some fashion shimming up the left. BTW the list appears at the front of the car as well.
As to the springs themselves, I had them replaced with probably 5-6 years back with some new ones I got from DW. I don't guess there is any way to test the "rate" of the springs in situ.
steveg
Hi Michael,
Hope this helped,
Ray(64BJ8P1)
I replaced my springs maybe 13 years ago. Took one of the leaves from each of the originals and inserted it in the new set. The one just above the riveted hoop. Car bottoms a little less.
After a while, removed the extra leaves and it bottomed more, so added them back in.
RAC68
Michael,
The extra leaf in both spring packs was to give my Healey a little extra height and, as Steve indicated, reduce bottoming of my BJ8 Phase 1 with resonators. The small amount of extra height also allowed me to drop the right side slightly and still maintain proper height. With our Healey's rear spring configuration, I have not found a way to add height with a shim ... only reduce height.
The combination of adding overall height and slightly reducing the right side with a shim allowed me to achieve the appearance of an even stance. If you already have sufficient height, you only need the shim.
Ray(64BJ8P1)
mgtf328
For what it's worth I've been through this twice. The first time was on my 1954 MGTF. I was told to swap the front springs around. I found it hard to believe this would sort out the rear where the problem was but I did it anyway and it worked.
My Healey had the same problem. I got John Chatham Cars here in the UK to look at it. He did say that he might be able to level it up by playing around with various shackles and putting new bushes on but I went for the new springs as the cost wasn't high and it fixed it.
AJ
Patrick67BJ8
My Jule Springs fixed my ride height too. I had them set for a level ride height on my phase 2 BJ8. I hate the jacked up rear end look.
CLEAH
My restorer uses standard Moss springs and has them recontoured to his specification. It may not be how BJ8's are "supposed" to look, but it is the way God, Donald Healey, and Gerry Coker intended!
Bob_Spidell
That does look mo' betta, and since you don't have resonators you won't trash them every couple of years. It's a shame BMC couldn't be bothered to modify the rear wings on the PII BJ8s.
RAC68
I totally agree ... and with smaller tail lights you would capture even more of the traditional Healey look as did the BJ8 Phase 1 and BJ7.
Ray(64BJ8P1)
Deleted member 21878
Had the same issue on my TR6 and added a front spring spacer on the driver side.
RAC68
Drone Dog's approach would work but it would also raise the front left suspension by an amount dependent upon the resulting effect needed to compress the right rear (not expected to be 1 to 1). His approach would also not require any addition (i.e. spring change or addition) to raise the rear when the right rear ride height is to low to add a lowering shim between spring and axel. Based upon simplicity, I would attempt this approach first but I did have the right rear ride height to allow the lowering shim which afforded me the less complex approach.
Good thoughts Drone Dog,
Ray(64BJ8P1)
C MGB-GT Ride Height MG 7
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
Pythias Springs and ride height... Questions. Spridgets 2
steveg TR6 Spec needed for correct ride height Triumph 28
Michael Oritt Raising Ride Height Austin Healey 9
H 1/4 elliptic ride height Spridgets 1
BlueMax Bugeye Ride Height? Spridgets 4
T TR4/4A Who is running Good Parts front springs on their TR4a? I have a ride height question. Triumph 1
RJS TR4/4A TR4A Stock Ride Height - my measurements Triumph 0
58Custom Ride height issue, spring help Spridgets 8
RJS TR4/4A TR4A Stock Ride Height Triumph 5
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
T 100 Ride Height Austin Healey 1
S BJ7 Ride Height Austin Healey 7
Zimmycobra TR4/4A TR4A Front ride height revisited Triumph 24
PatGalvin TR2/3/3A TR3A Ride Height Triumph 5
T TR4/4A TR4a ride height question Triumph 17
bcbug Ride Height Spridgets 4
M 1994 xj6 ride height Jaguar 1
B TR2/3/3A TR3 rasied ride height Triumph 5
T AH 300 ride height Austin Healey 3
Sparkie Correct Ride Height Please TVR 0
Jayrz Auto-X/ Vintage race/ spirited street ride height? Spridgets 14
Stinky TR6 TR6 Ride Height ????? Triumph 9
2wrench TR6 TR6 Rear springs and ride height Triumph 15
R TR6 TR6 rear ride height with tube shocks Triumph 5
boxofparts Rubber bumper B - Best way to lower ride height MG 7
R front end ride height Austin Healey 2
RobT TR5/TR250 Anyone know the "stock" ride height for a TR250? Triumph 5
R TR^ Ride Height Triumph 4
R Ride Height Sunbeam (Rootes) 6
R ride height Austin Healey 5
Geo Hahn TR4/4A TR4 Ride Height Question Triumph 3
X spring ride height/ low profile tires/minilites MG 2
J MGB "Ride Height" - 77 MGB MG 6
Rob Glasgow Barbie’s Ride Austin Healey 9
R TR6 Mazda Miata ride, everything else TR6 Triumph 13
Sherlock My ride tonight Other Cars 14
K TR2/3/3A Tire pressure and ride comfort? Triumph 9
Gray_Cat Socal Norton Owners Club Annual Meet, Ride & Show November 3rd, 2019 British Motorbikes 0
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
PeterK TR2/3/3A Father's Day ride Triumph 4
Michael Oritt Every ride is a test ride Austin Healey 9
dougie 100-S Ride Along Austin Healey 3
Gray_Cat Socal Norton Owners Club 39th Annual Meet/Ride & Show 11-4-18 British Motorbikes 0
A Spitfire Spitfire Ride Down The Mountain - Vermont Rt 100 Triumph 12
HighAltitudeTR3 TR2/3/3A Doesn’t want to start up again after a ride... Triumph 24
PeterK General TR Time for a long ride Triumph 3
C Classic Sports Racing Group at Sonoma Raceway/ Track ride. Austin Healey 2
