Results 1 to 15 of 15
Thread: What is available to repair the hardtops for the early 4 seater 100-six and 3000
  1. #1
    Join Date
    Nov 2002
    Location
    PA USA
    Posts
    500
    Chats
    who has any information as to what parts are currently available for some one to recondition a factory hardtop. hardware? interior lining? wood pieces? rubber molding around the bottom attaching to the frame and also surrounding the plexiglas window. Also what is required to recondition the the chrome.
    thank you for your assistance and insight
    healey106
    healey106
  2. #2
    Join Date
    Jul 2008
    Location
    Yorba Linda, California
    Posts
    358
    Chats
    Re: What is available to repair the hardtops for the early 4 seater 100-six and 3000
    Quote Originally Posted by healey106 View Post
    healey106
    Nical Engineering has almost everything!! Moss and AH Spares also have a few items.
    http://www.nicalengineering.co.uk/austin_parts.html
    https://www.ahspares.co.uk/big-heale...s/default.aspx
    https://mossmotors.com/austin-healey...top-100-6-3000
  3. #3
    Join Date
    Nov 2002
    Location
    PA USA
    Posts
    500
    Chats
    Duane - thanks for the very important info
    healeyey106
    healey106
  4. #4
    Darth Vader John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    2,735
    Chats
    British Car Speciaists also have a bunch of the items needed.
  5. #5
    Jedi Warrior healeyblue's Avatar
    Join Date
    Apr 2012
    Location
    Lafayette, LA
    Posts
    691
    Chats
    Hope you're starting with something better than I did. It can be done and is very rewarding once completed. I had to have the headliner fabric sewn to match the original pattern, as all I was able to get was the material in bulk and not pre-sewn (it is a simple seam though).
    http://www.britishcarforum.com/bcf/s...ets-a-hard-top
  6. #6
    Join Date
    Nov 2002
    Location
    PA USA
    Posts
    500
    Chats
    Healeyblue - thanks for sharing - those photos are really great!!!
    healey106
  7. #7
    This write up of my hardtop restoration that I did a few years back may be helpful?
    http://valvechatter.us/?p=3272
    Lin
    1959 AN5 Bugeye
    1960 BT7 3000 MKI
    1964 Jaguar MK2
    1969 MB 280SL
    1987 Alfa Romeo Spider Quadrifoglio
  8. #8
    Join Date
    Nov 2002
    Location
    PA USA
    Posts
    500
    Chats
    Lin - your article is truly FANTASTIC. Thanks for sharing
  9. #9
    You bet :-)
    Lin
    1959 AN5 Bugeye
    1960 BT7 3000 MKI
    1964 Jaguar MK2
    1969 MB 280SL
  10. #10
    Jedi Knight andrea's Avatar
    Join Date
    Apr 2008
    Location
    TRIESTE- N.Est -Italy
    Posts
    801
    Chats
    [QUOTE=healey106;1070507]Healeyblue - thanks for sharing - those photos are really great!!!
    When I have rebuild my Longbridge 100/6 Hard Top I have followed LIN instructions and Photos (the BEST)
    I have collect also a lot of HT photos in this album that can be useful
    https://photos.google.com/album/AF1Q...NzaqNg27waWUjZ
    I remember the panic on rear perspex assembly (two days of battles)
    on this Google album you can see some photos of the work steps-Fabrizio TWO hands- helps a lot in the work
    https://photos.google.com/album/AF1Q...LG0NIGFgg0yStm
    Lot of spares find from AHead4Healeys
  11. #11
    Join Date
    Dec 2012
    Location
    Rome, GA
    Posts
    73
    Chats
    All suggestions offered, especially the Lin Rose technical article, are very helpful.
    I purchased my rebuild kit from AH Spares. Not perfect, but complete with the exception of headliner materials. Cape International (UK) provided headliner material and side panels.
    Rear glass "fit" was almost perfect. Installation took less than an hour. A little silicone lube and a proper install tool really helped!
    If you are going to do your own paint and body work, please be prepared for the thin and delicate fiberglass material. My top was in poor condition. I had to spray a new gelcoat. After some initial sanding I sprayed epoxy primer and filler. Then I actually reassembled the aluminum extrusion structure to get enough support to properly block and sand the top. It was like trying to sand an air filled balloon. every time I pushed, it went the other way. Hope your is in better shape than mine was.
    I am happy with the end product.
    TFR1
  12. #12
    TFR1
    Nice work! Well done. Another hardtop saved.
    Lin
    1959 AN5 Bugeye
    1960 BT7 3000 MKI
    1964 Jaguar MK2
    1969 MB 280SL
  13. #13
    Join Date
    Dec 2012
    Location
    Rome, GA
    Posts
    73
    Chats
    Quote Originally Posted by Lin View Post
    Lin,
    Your technical article was the first good bit of information found as I searched for information 2 years ago when I started planning to rebuild my hardtop.
    The enlarged photos and printed copy of the article were kept it in a folder in the workshop. It provided encouragement to begin.
    It was a difficult job, but I do like the result. My BN4 is much better looking with a hardtop!
    Thanks for the compliment.
    TFR1
  14. #14
    Darth Vader Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,688
    Chats
    TFR
    The Nical top for my 100 was so thin and flexible it was impossible to install the rear window without first mounting a pair of bars to triangulate the corners. That made the top rigid enough so that i could exert force against the window and moulding. They were not part of the 100 top kit but luckily i had ordered a pair of them on spec from Freeman.
  15. #15
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,688
    Chats
    At least to my eye a Healey's lines are graced by a well-designed hardtop though not all will agree. Conversely
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
