Door check installation
Michael Oritt
I need to replace the driver's side door check.
Can I do this without having to remove the fender?
pan
G'day Michael, I installed mine with the mudguards (wing, fender) already mounted. But the engine was out at the time which I recall made it easier to get my hand into the gap.
Cheers,
Alwyn
dh100m
get a strong magnet from old speaker ect. place on face of panel use long handle magnet if you cant get your hand in there
that is how i did mine a fiddly job but saves taking off fender
good luck
RAC68
Hi Michael,
As I remember (although not confidently), I undid the lower fender bolts and a few of the in-jam screws to allow the bottom of the fender to be separated enough to squeeze my arm up in place. Although my door-checks are in place, I have only had them perform properly for a very short time and found them useless.
Have a great Holiday,
Ray(64BJ8P1)
Michael Oritt
Michael Oritt
Thanks fellas and I am going to try to avoid dealing with fender connectors if at all possible.
DH100--I have a now-disused speaker in the left kick panel and not only would its removal give me the strong magnet you suggest but it also may allow me to reach the rear of the jamb to R&R the present check.
Ray--At this point I will settle for a mere 20 or so years of use from the new check.
roscoe
Posted under the wrong thread, dang!
RAC68
Hi Michael,
The failure I previously referred to involving the door check was the resistance-pad in the check that kept the door from closing. I changed it a number of times and, if you can tell me how to keep it working for 20 years, I would be grateful.
Enjoy,
Ray(64BJ8P1)
Michael Oritt
Michael Oritt
Today I installed the new door check I got from Moss.
After first detaching the old check from the door I was able to open it--the door--far enough that I could get at the two screws attaching the check to the A pillar. In examining the new piece it looked to me that the old one could somehow be manipulated to come out of the hole in the pillar and the new one installed in the same way, but no matter how I turned and twisted the check it would not come out and while manipulating it while holding it with a big hemostat I ultimately wound up dropping it and it fell into the void behind the pillar!
As I posted yesterday there are some disused speakers in the outer footwell panels and by removing the speaker I was able to reach into the void, extract the old check and then hold the new one in place so I could get the mounting screws in place, and I then attached the arm of the check to the door. All of this took about an hour.
I must say that I am not at all happy with the new check: Whereas the plate of the old--no doubt original--check had a bead pressed around its perimeter to stiffen it the new one did not and though the plate is firmly attached to the inside of the pillar it flexes a bit when the door is closed. (Perhaps this will go away as the check wears a bit).
If I had to do this job again I would probably enlarge the hole just a bit to allow the check to pass through it, making its R & R a much easier job. Alternatively, I might install the check on the rear face of the A pillar, as the face of the pillar would serve to keep the check's plate from flexing and once it is painted out it would not be very noticeable.
Anyway, taking my age into consideration and given how long the old check lasted, even with the new unit's weaker construction I am hopeful I will not have to do this job again.
R TR4/4A Door check straps Triumph 7
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
KVH TR4/4A Door Check Straps Triumph 11
D TR2/3/3A Door check bracket? Triumph 7
M BN1 door check replacement Austin Healey 9
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
HealeyDave Door Check Friction Adjustment Austin Healey 12
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 Door check strap Triumph 3
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
G 6 door check noise Triumph 13
K door check strap Spridgets 10
me61ic Forum search and Door Check Strap ? Austin Healey 1
Stinger TR4/4A TR4A Door Check Strap Spring Clip Replacement Triumph 4
A Door check Lotus 4
S TR2/3/3A door check straps for tr3 Triumph 1
W Broke check strap on door Triumph 4
mjobrien Door Check - Color? Austin Healey 2
Russ Austin TR2/3/3A Door Check Strap TR3 Triumph 10
F TR4/4A TR4 Question: Door check strap pin Triumph 5
Rob Glasgow Door Check Strap Austin Healey 12
S TR4/4A TR4 Door Check Straps Triumph 4
This14u Spitfire Spit Door Check Triumph 3
M Door check strap repair Austin Healey 6
S door check strap attachment Triumph 15
6 door check strap Triumph 6
I TR6 Removing door check arm in TR6 Triumph 6
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
