Results 1 to 17 of 17
Thread: Spark Plug Wire Caps
  1. #1
    Join Date
    Dec 2012
    Location
    Jersey Shore
    Posts
    108
    Thanks Thanks Given
    30
    Thanks Thanks Received
    Thanked in
    I bought these caps from a vendor in the UK, one of the well known suppliers. When the caps arrived, I placed them on some Champion plugs. They do seem to “click” onto the top of the plug, but once in place they wiggle. The fit is a little loose.
    I asked the vendor, and they stated theat the caps should work fine and are the right spec for an Austin Healey 3000. I have generally had good experience with this vendor in the past.
    I have seen these caps on other cars at car shows. As can be seen, I use the recommended Champion plug.
    I am curious if anyone else has had an experience with them. I have not installed them yet. I would like to use them, but not if it compromises the cars reliability.
    I would appreciate any feedback. As always, thanks so much.
    Thanks,
    Bill
    1975 Triumph TR6 & 1962 Austin Healey 3000 BJ7
  2. #2
    Join Date
    Sep 2016
    Location
    Gloucestershire, England
    Posts
    18
    Thanks Thanks Given
    Thanked in
    Re: Spark Plug Wire Caps
    I have them on mine and I agree that once in place they are a loose fit but don't come off without a tug and have never been a problem. I wouldn't worry.
    steve
  3. #3
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,143
    Thanks Thanks Given
    28
    12
    Thanked in
    I have different ones, they wiggle back & forth, and they work fine.
    John, BN4
  4. #4
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,441
    Thanks Thanks Given
    6
    Thanked in
    Well:
    I use Bosh plug caps and they do not wiggle and work a treat.
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  5. #5
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,137
    Thanks Thanks Given
    44
    55
    Thanked in
    One can take it on faith that Champion is not in the business of making spark plug caps that make their plugs perform badly.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  6. #6
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,441
    Thanks Thanks Given
    6
    Thanked in
    Quote Originally Posted by steveg View Post
    ] They perform badly all by themselves------
    1985 XJ6 Saloon
    1973 Volvo P1800ES
  7. #7
    Yoda Randy Forbes's Avatar
    Join Date
    Feb 2003
    Location
    SW Florida (Sarasota/Bradenton area)
    Posts
    4,445
    Thanks Thanks Given
    8
    25
    Thanked in
    Quote Originally Posted by Keoke View Post
    rofl I've been faithful to NGK >40 yrs; once fouled, Champions didn't seem to be able to clean themselves off, no matter how Italian I got on them.
    http://www.britishcarforum.com/bcf/image.php
    57 Healey BN6L-942 Wine Red/Honey Tan
    99 BMW M Rdstr Cosmos Black Eurosport Twinscrew Supercharger
    01 BMW M Rdstr Steel Gray Performance Center (factory) Delivery
    11 X5 35i Sport Deep Sea Blue Metallic Wife's Turbo Hauler
  8. #8
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,137
    Thanks Thanks Given
    44
    55
    Thanked in
    Nyuk nyuk!
    Steve Gerow
    Altadena, CA, USA
  9. #9
    Jedi Knight DerekJ's Avatar
    Join Date
    Nov 2004
    Location
    Cotswolds, UK
    Posts
    1,458
    Thanks Thanks Given
    3
    Thanked in
    I once bought a set of 'bumble bee' wires with caps already attached, from one the UK major suppliers. The caps seemed too hard and plasticky and never fit as well as I thought they should. I removed them and now use NGK caps and plugs.
  10. #10
    Join Date
    Sep 2016
    Location
    Posts
    18
    Thanks Thanks Given
    Thanked in
    I wouldn’t assume they are genuine simply because they have Champion written on them. Like Lucas parts many are Chinese copies of variable quality.
  11. #11
    Join Date
    Dec 2012
    Location
    Jersey Shore
    Posts
    108
    Thanks Thanks Given
    30
    Thanked in
    Actually one of my concerns is that, even though they have the “Champion” name ... were they really manufactured by Champion?..... or a knock-off with the vintage look.
    I appreciate all the feed back, and glad this spurred some conversation. I have to say that I like the way that they look, but not too convinced that it is acceptable to have loose fitting spark plug caps from a performance/reliability standpoint.
    Thanks,
    Bill
  12. #12
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,137
    Thanks Thanks Given
    44
    55
    Thanked in
    Quote Originally Posted by BG 62AH View Post
    You already own them. Why not install them? You can test each wire with a timing light and see if it has a miss.
    Steve Gerow
    Altadena, CA, USA
  13. #13
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,137
    Thanks Thanks Given
    44
    55
    Thanked in
    This is the Moss "Made in England" cap. It clips on and the cap swivels on the plug.
    Steve Gerow
    Altadena, CA, USA
  14. #14
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,582
    Thanks Thanks Given
    1
    32
    Thanked in
    FWIW, Champion plugs are the plug of choice for aircraft piston engines (engine performance is a matter of some concern in aircraft). Champion oil filters are widely used as well.
  15. #15
    Luke Skywalker vette's Avatar
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,541
    Thanks Thanks Given
    12
    Thanked in
    I have found that any of the hard plastic or bakalite plug caps do wobble after they have clipped on the plug. I have found no loss of performance due to that on a street driven engine. But one issue of the open hard caps is that they certainly are not water or moisture proof. When I was on tour this past summer in the Smoky Mountains I found that each morning after a bit of a night time shower, the Healey started and idled fine but sputtered around awhile till everything warmed up and dried off. I am still using the original style Lucas hard caps. No water proofness here.
    About TV Shows-
    "...you really can't restore a car in 10 days. I don't want to watch a race where people have to restore it in a week. It's not going to drive, and those cars never work. In real life, it takes years to get it right. " Jay Leno.
  16. #16
    Yoda Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,046
    Thanks Thanks Given
    5
    13
    Thanked in
    I use 8 mm wires with a soft rubber boot that emits a suction cup-like noise when pulled from the (NGK) plug.
    Best--Michael Oritt
    1954 Austin-Healey 100 Le Mans
    1958 Elva Courier (FOR SALE)
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  17. #17
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,137
    Thanks Thanks Given
    44
    55
    Thanked in
    I had the hard caps for years and had some issues with the wires occasionally coming a little loose from the screw threads.
    Found a guy in upstate NY who has a business making wiring for classic cars (Duesenbergs, Packards, etc). He sold me some unmarked black metal-core wire and clamp-on clips inside of tight-fitting rubber boots. That's what I run now. Not sure it runs any better, but one less thing to fiddle with.
    I've been using NGK plugs since my first motor vehicle (Yamaha Trail 80).
    Steve Gerow
    Altadena, CA, USA
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
