Results 1 to 12 of 12
Thread: Moss Motors rear brake "set"
  1. #1
    Yoda Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,007
    Thanks Thanks Given
    Thanks Thanks Received
    8
    Thanked in
    I need to replace the brake shoes on both rear wheels. Moss's site refers to a "set" but does not tell me whether a "set" covers both wheels or whether I need to order two "sets". Customer Service is closed and I would like to place the order tonight--does anyone know the answer to this so I don't stay up all night wondering?
    Best--Michael Oritt
    1954 Austin-Healey 100 Le Mans
    1958 Elva Courier (FOR SALE)
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  2. #2
    Duane_Rhynard
    Re: Moss Motors rear brake "set"
    Quote Originally Posted by Michael Oritt View Post
    Michael,
    The picture on the website shows 4 shoes (Below), so common sense would dictate a rear set is 4 shoes!
  3. #3
    Jedi Warrior healeyblue's Avatar
    Join Date
    Apr 2012
    Location
    Lafayette, LA
    Posts
    703
    Thanks Thanks Given
    2
    Thanked in
    Just like when you buy brake pads for any car, they come with enough to do the entire job (ie front or rear). So yes it will have 4 shoes to do the rear
  4. #4
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,007
    Thanks Thanks Given
    8
    Thanked in
    Whew, now I can go to sleep with the reasonable expectation that four shoes are headed my way, though I'm not sure how much common sense counts for these days.
    Best--Michael Oritt
    1961 Ginetta G4
  5. #5
    Join Date
    Nov 2011
    Location
    Martinsville NJ
    Posts
    468
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Linings should always go on as a set (both sides) since there are variations in compounds, wear, and compression. Uneven braking can occur. Same for front pads.
  6. #6
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,007
    Thanks Thanks Given
    8
    Thanked in
    Though I plan to replace the shoes on both sides the right side is worn a lot more due to a faulty adjustor on that brake. A notch/shoulder has developed in it which causes the front static end of the upper brake shoe to ride against the drum even when the brakes are not activated. So after only 63 years of service I'll have to be replacing the adjustors as well.
    Best--Michael Oritt
    1961 Ginetta G4
  7. #7
    Yoda Randy Forbes's Avatar
    Join Date
    Feb 2003
    Location
    SW Florida (Sarasota/Bradenton area)
    Posts
    4,439
    Thanks Thanks Given
    8
    21
    Thanked in
    Boy, what cheap parts; you'd think they could make something to last!
    Although, having *just* turned 63 myself, I'm thing that a few of my adjusters are getting worn out too...
    I must agree with Bob; brake friction materials__pads/shoes__are always sold, and should be installed as axle-sets. Unless there is virtually no wear__as in less than a few months in service__I treat tire replacement the same way (my wife's X5 's tires have an unnatural, yet magnetic attraction to drill-screws, since there's still a lot of construction around here...).
    http://www.britishcarforum.com/bcf/image.php
    57 Healey BN6L-942 Wine Red/Honey Tan
    99 BMW M Rdstr Cosmos Black Eurosport Twinscrew Supercharger
    01 BMW M Rdstr Steel Gray Performance Center (factory) Delivery
    11 X5 35i Sport Deep Sea Blue Metallic Wife's Turbo Hauler
  8. #8
    Join Date
    Nov 2012
    Location
    Warrington PA
    Posts
    507
    Thanks Thanks Given
    Thanked in
    In PA you cannot change one side. HAS TO BE BOTH WHEELS.
  9. #9
    Join Date
    May 2013
    Location
    Australia
    Posts
    89
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Are you referring to brake linings or tyres as Randy mentioned? (Or both)?
    If tyres, can you take one wheel to a tyre shop for fitting?
    Danny
  10. #10
    Jedi Warrior pan's Avatar
    Join Date
    Nov 2005
    Location
    Ipswich, Australia
    Posts
    618
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    G'day again Mike, would you share the method that you use to replace the adjusters. I am about to undertake this job (after 64 years in my case) and am a bit concerned about how to go about it. The adjuster kit that I have is for a Landrover and are identical to those on my BN1, and by the way the kit does both sides!
    Fifty years in one 100, still going strong!
  11. #11
    Luke Skywalker RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,817
    Thanks Thanks Given
    10
    Thanked in
    As a side note: Old Brake Shoes make great Wheel Chucks.
    Ray(64BJ8P1)
  12. #12
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,007
    Thanks Thanks Given
    8
    Thanked in
    I installed the new shoes and adjusters today--it was the usual PITA getting the springs to stay in place while I levered the shoes over the wheel cylinders and adjusters but all went together okay and the new brakes work fine.
    Pan--installing the adjusters was simply a matter of removing the two bolts and washers from the rear of the backing plate, knocking the old adjuster out and putting the new one in. A bit of wheel bearing grease on each of the moveable pistons keeps things in place while getting the shoes seated. Be sure to turn the adjuster screw all the way out so that the pistons are in as far as possible which makes getting the shoes in place less difficult. Let me know if this answers your question.
    Best--Michael Oritt
    1961 Ginetta G4
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
