Home Made Healey Exhaust Headers from a BOX
RAC68
Hi All,
Last night a friend called me and described a program on the Velocity Channel showed the application of a number of restoration and upgrade changes to a 1965 BRG BJ8. Among the changes were stainless steel exhaust headers the host mechanic assembled as a replacement of the original cast units. All components for the headers seemed to have been supplied from a box with the host cutting and tack welding the parts to suit.
Does anyone know if my understanding is correct and there is a supplier of boxed components for design, assembly. and installation? If so, does anyone know the suppliers contact information?
Thanks and Happy Holidays,
Ray(64BJ8P1)
'Wheeler Dealers' season# 14 episode# 8 (I believe it was the 'finale' of the season). I think the muffler and kit Ant used were Magnaflow, but you could probably get similar from Flowmaster or others. I only watch it about 7 times a week, I'll see if I can confirm this info next time I watch it. Show is here, but it looks like you have to set up an account (in episode# 9 the co-host goes ape over the Healey):
https://www.velocity.com/tv-shows/wheeler-dealers/
Here's an example kit I got from a quick search:
https://www.jegs.com/i/JEGS/555/30671/10002/-1?CAWELAID=1710598596&CAGPSPN=pla&CAAGID=39714413703&CATCI=pla-293995373017&CATARGETID=230006180039220954&cadevice=c&gclid=EAIaIQobChMInuXE86aX2AIVgtlkCh3ZmQ3QEAQYBSABEgI3ZfD_BwE
red57
Header kits of mandrel bent tubing pieces have been available mail-order since the 50s-60s from JC Whitney and others. Used to see the ads in Hot Rod and other magazines. A lot of them had flanges to match various heads. I remember several guys who bought them but I don't remember anyone actually completing a set of headers..... Basically daydream material.
Dave
RAC68
RAC68
Hi Bob,
I was unaware I could get the Velocity Channel and haven't seen the episode. II also didn't know that these kits were available at all and not for Headers for the Healey.
Thanks Bob and all the best for a Great Holiday,
Ray(64BJ8P1)
HealeyRick
Like most things on these shows, it's easier on TV than in real life. First you'll need a flange matching the Healey exhaust outlets. I don't recall ever seeing one available and don't know where Wheeler Dealers got theirs. Second, you'll need to be able to figure out how to lay out all those mandrel bends to get them to meet together in the collector at the bottom. Not that easy. It would be nice to have a good band saw to make all the cuts and finally, you'll need some welding skill to put it all together, particularly if you want to do it in stainless. Personally, buying a set off the shelf would probably be easier if you don't do this kind of thing regularly
It would be an order of magnitude easier, and even if you pay yourself only a quarter ($0.25) an hour, probably cheaper too if you just get store-bought ones instead.
Sometimes however, there just aren't any headers on a shelf anywhere for your particular application, so make them you must. Be forewarned though, it's not simply a case of choosing some tubing because it is big__the tube diameter chosen should be equal to the area of the port__and then cutting them to some convenient length (the short tube length shown in WD's Healey would have a narrow power band and high up in the rev range, IMHO). In addition, the collector volume is arrived at via a formula as well; in the case of the headers I made for a Buick 3.8 V6 I put in an MGBGT, that volume was equal to two (2) cylinder's worth of displacement. The results are shown below.
Anybody that wants__or has to__to make their own headers, without scouring this website first, by a true pioneer of performance headers, would be an idiot.
https://www.headersbyed.com/+hcomments.htm
Just curious--I'm not (really) in the market for headers--what y'all think of the Denis Welch headers. Supposedly, they are close to what the Works Healeys used. Actually, I might consider some for the BN2, the off-the-shelf downpipes appear to not be bent correctly and the clutch pedal lever hits the downpipe when fully depressed (have been told the OEM ones did this too).
Of all the commercially available headers currently on the market** I would EXPECT that the ones from DW would be the most likely to be field developed (i.,e., produce a substantial improvement in flow). If I was in the market for a set, I'd probably buy them from DW (Dollar is still strong against the Pound...).
** used to be, no matter where you bought your 6-cyl Healey headers, they were made in Al Kirk's garage in/near Bessemer, Alabama. He stopped making them not too long after I to replace the original set I had due to a trailer unloading incident around the mid-90s.
steveg
I must have his last set. I bought mine used from them in early 2007. They said someone had returned them (they were no longer made) after failing to get them installed. Needless to say, they fit fine. I had them ceramic coated dark gray inside and out and they still look new 10 years later.
PS - Boy Racer Richard Mayor makes (or did make) a fine set of headers.
Have to say the DW headers look better. Not sure why Kirk went for the #1 & #6 branches the way they are.
dougie
Yes, Richard's headers were designed by a NASCAR fabricator and manufactured using a 6-cylinder chassis jig. They have thicker diameter steel tubing, all mandril bends, and beautifully tig welded. I think I got the last pair.
maxwedge5281
a few years ago i had a set of stainless headers made to accommodate a swap i was doing at the time...Porsche 930 with 700 plus hp ls7 motor. i had them built from a kit that was provided by the fabricator....various pvc tubing and some custom metal parts. i then assembled a header system from the various pieces in the kit to accommodate the space, chassis or whatever. the assembled mockup is then shipped back to the header fabricator and the headers are built.. i was very pleased with the result...a little pricey but well worth it to me!
Steve, sometimes you just get lucky! I referred someone to Kirk, only to find out that he'd stopped making them because he got complaint(s) that they weren't fitting; he'd been using the same jigs for ages! Maybe it went to the owner of a bent car, or the individual was short on imagineering?
Here's my current set fresh from Jett-Hot (cleaned/blasted & then internal/external coatings applied); except for some slight dulling of the shiny finish, they still look exactly the same.
I cannot recommend the application of the thermal barriers strongly enough (!) however, I do recommend that you always test-fit them to a car prior to sending out, so if any fine tuning needs to be done, there's no risk to the coating.
Pure Healey porn Dougie! It's a wonder that Basil didn't ban those lusty images ;)
And to continue along those same lines, there's now a readily available "kit" of snap-together PVC pieces (various tubing sizes and quantity of pieces) to speed up the process.
Very clever, though I've bought readily available headers for much less than these modeling kits cost, so unless you're in the business of custom swaps, not really cost effective. Although, if used carefully for ones own needs, there may be a demand for "lightly used" kits, passing between diy builder types.
V8 kit for 1-5/8" tube @ $775.00! https://www.trick-tools.com/icengineworks-1-5-8-inch-header-modeling-kit-240-piece-1625pro-7850
See the Trick Tools 2:42 minute video here: https://www.youtube.com/watch?v=0wIgQeYYLHA
When I made the headers seen in my initial post, I used some scrap pieces (32" long, as I recall) of CLX cable assemblies (offshore/marine grade aluminum-clad/PVC vinyl-covered electrical multiple conductor) that was the same 1-1/2" O.D. as the tubing I was planning to use. Once bent, it would retain its shape, and I screwed these to some mock-up flanges (9-layer marine plywood) and used screw-type hose-clamps to keep it all together. I towed the car and took my "models" to the local muffler shop and the guy came as close as he could to replicating the bends in aluminized tubing. Some of the back to back bends couldn't be done in his machine, so he came as close as he could, and then I cut, trimmed/mitered and welded them back together.
While it's not impossible to make homemade headers from a box of parts, you've got to really want to do it! There is no savings of time or money to be had by doing so, and it's a little above the average individual's natural skill set (not to mention the amount of patience required). Don't forget, besides the tubing work, you still need a set of flanges cut/milled (though I suppose a laser-cutter could make short work of that) plus collectors/transitions, connecting flanges, etc., etc., etc. It's a pain in can!
Now all that said, HOW do you suppose headers like these, made of stainless steel with gorgeous TIG-welded joints can be available__for BMWs no less__on ebay for around $100.00?!?! It bewilders me...
HealeyRick
To follow up on Randy's post, here's another option for building your own headers and you can even have them fab your custom design for you: https://www.stainlessheaders.com/customheaders But, it's pricey and is still going to be more expensive than something you purchase ready-made. I'm running some Sunbeam Tiger cast iron manifolds on my V8 swap and I know they are stealing a good amount of power, but nobody is making an off-the-shelf header for a V8 in a Healey. When I started looking at prices for a set of custom builts, I decided I could live with the loss of power.
maxwedge5281
rick that is where i had my headers fabricated. excellent workmanship and headers fit great....but expensive!!!
RAC68
RAC68
Hi All and Happy Holidays,
Thank you for your responses and the discussion. Just prior to my posting, my laptop seemed to have developed a short and burned the mother (board). I had used my granddaughter's Pink Atom powered 10" PC and she took it back (thank God).
Have a great Holiday,
Ray(64BJ8P1)
TFR1
These are definitely not from a BOX.
Picture is of a set copied from a period race car. Originals were damaged.
TFR1
AngliaGT Miata - ALMOST Made it Home Other Cars 7
wangdango Home-made ducting for BJ8 radiator? Austin Healey 11
JPSmit Land Rover Defender - and Home made special Spotted 1
Xte TIPS : Home made tool for the thermal sensor Austin Healey 7
JPSmit Home made axle puller Restoration & Tools 5
RickB Well my Midget made it home... Need Help! Spridgets 80
hondo402000 TR6 TR6 fan shroud, home made Triumph 7
Tabcon Home made sway bars. Racing 23
tweety Home made heater valve will it hold...... Spridgets 3
Trevor Jessie I made it home from the lake of the Ozarks... Spridgets 28
G Is this a home made valance guard? Triumph 7
W Home-made tonneau - has anyone tried? Triumph 15
JPSmit Home Made Rotisserie - I'm sooooo Happy Spridgets 15
Morris Home Made Leakdown tester Spridgets 17
simpzimmer Made it home: brakes Triumph 5
MattP Hooray! I made it home. MG 5
Patton The car made it home for it's birthday Austin Healey 2
philman Wedge TR7 finally made it home Triumph 7
Hamish Racing TR2/3/3A Aintree sprint (uk) home to the British GP Iain 1950’s Triumph 0
R TR6 I just brought this to its new home. It has been stored for 15 years, has only 21000 miles , and only 1000 sincw Triumph 12
AngliaGT Saw This When We Got Home Today Spotted 3
JPSmit Ms Triss is home again. Spridgets 12
drooartz Carried home on my shield... again Spridgets 17
7 General TR Its home! Triumph 7
R The long road home Spridgets 1
Basil TR2/3/3A On my way home from town - spotted this Triumph 9
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
JPSmit Ms. Triss is home! Spridgets 12
Lin A little "Stay-at-Home" Healey Nostalgia Austin Healey 10
JimLaney For Sale 2 MK IIIs :Free to good Home Spridgets Classified 1
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
Jim_Gruber Drove Bugsy home this AM Spridgets 15
waltesefalcon It's home! Other Cars 9
drooartz MGB Engine on the hoof - parts car comes home MG 8
JPSmit Home from Boarding School! Spridgets 11
D TR2/3/3A Home Again! Triumph 12
steveg HD8s easily rebuilt at home Austin Healey 4
drooartz Penny the Bugeye in her new home Spridgets 39
R Prepping to bring my 100 home Austin Healey 5
NutmegCT T-Series New home for an old TD MG 30
Jim_Gruber Bugsy II - Left for a new home this morning Spridgets 4
Marla TR4/4A Take the long way home Triumph 11
drooartz MGB An old friend comes home - I have an MGB again MG 27
Keith_M Look what came home Spridgets 14
steveg Odd problem but it got me home! Austin Healey 9
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
JPSmit Ms Triss is coming home today Spridgets 7
Bob McElwee Miss BT has a new home [probably a new name too!] Austin Healey 1
Mickey Richaud T-Series Home, James MG 4
