Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Undercarriage Refresh
  1. #21
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,283
    Thanks Thanks Given
    5
    Thanks Thanks Received
    7
    Thanked in
    Re: Undercarriage Refresh
    That's a nice looking undercarriage and I suspect it wasn't a local CT car to start with. Either that, or it was taken off the road in winter. Looks like there's more red oxide primer showing than surface rust. I'd probably neutralize the rust and just paint over what's there.
    Rick
  2. #22
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,287
    Thanks Thanks Given
    1
    9
    Thanked in
    Some (many? all?) OEW/black 100M chassis--most of the Ms were OEW/black--chassis' were painted black from the scuttle forward. I believe our M was painted like this, as the engine compartment was black, and I now wish we'd done it that way for the reasons mentioned.
  3. #23
    Join Date
    Dec 2017
    Location
    Tolland, CT
    Posts
    8
    Thanks Thanks Given
    Thanked in
    There's an unbelievable amount of dirt thanks to leaks. I've been scraping the dirt off with a putty knife then cleaning off with brake cleaner. It's a huge mess, but I think it will look great when I'm done.
    Should I do a final pass with soapy water before painting? And no it's not an original CT car : )
  4. #24
    Darth Vader steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    2,705
    Thanks Thanks Given
    9
    19
    Thanked in
    This worked well for me when I redid my engine compartment last summer:
    Spray with kerosene, work with bristle brush. Spray with Scrubbing Bubbles. Wash off with pressure washer. Repeat as necessary.
    Kerosene seems to have the ability to leach the grease and oil out of old crud, leaving water-soluble dirt in its place.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  5. #25
    Luke Skywalker RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,625
    Thanks Thanks Given
    5
    Thanked in
    Hi Matt,
    I trust you will be doing your cleaning when it gets a little warmer and after the snow storms move up the cost this week. Although I have used Kerosene as Steve suggests and not tried Steve's Scrubbing Bubbles chaser, I did use Dawn Dish Detergent to follow any chosen Gas-type heavy gunk cutter to assure the paint would stick ... everywhere. The main thing I have found is to have everything dry before spraying paint.
    Good Luck,
    Ray(64BJ8P1)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
