Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Undercarriage Refresh
  1. #1
    Join Date
    Dec 2017
    Location
    Tolland, CT
    Posts
    8
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hello - I have a question. I'm going to have my Healey 100 painted this winter. It was an amateur restoration so there are some minor body issues I want taken care of and I want new paint. I'll also be getting a new interior.
    I have a lift and looking under the car it appears that it could use a bit of a refresh as well. I think proper standards is to have the underneath painted the same as the car, but I'm not going to rip the car apart so I'm looking for an easier solution. Wagner (https://www.wagnerspraytech.com/prod...tocoat-series/) has a sprayer that I could use, but I don't want it rubberized.. maybe just some black paint (the car is black)... though it wouldn't be glossy. I just want some protection and for it to look cleaner. There's also some 3M and Eastwood spray cans that are available. Thoughts? Suggestions?
  2. #2
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,205
    Thanks Thanks Given
    1
    4
    Thanked in
    Re: Undercarriage Refresh
    The real issue will be getting things clean enough to retain paint; these cars' bottoms have been oil-soaked for over 60 years. I'd use Dawn dish soap, then go over with a volatile solvent that doesn't leave any residue, then scuff as much surface as you can. Sounds to me like a 'rattle can' finish would suffice, but you'd want a primer/sealer under it.
  3. #3
    Join Date
    Dec 2017
    Location
    Tolland, CT
    Posts
    8
    Thanks Thanks Given
    Thanked in
    Yeah my thoughts exactly. A lot of time trying to prep and mask/tape areas off.
  4. #4
    Darth Vader steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    2,639
    Thanks Thanks Given
    4
    8
    Thanked in
    When I painted my engine compartment, an old-motorcycle fan friend suggested using kerosene to remove the crud. It works great!
    Spray it on, work it with a bristle brush, then spray with Scrubbing Bubbles and wash off with a pressure washer. Might have to repeat.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  5. #5
    Jedi Knight DerekJ's Avatar
    Join Date
    Nov 2004
    Location
    Cotswolds, UK
    Posts
    1,402
    Thanks Thanks Given
    Thanked in
    I would definitely recommend painting it body colour. I think the cars look odd if the floor or engine bays are a different colour to the car. Always makes me suspicious for some reason.
  6. #6
    Join Date
    Mar 2003
    Location
    Hampshire in the UK
    Posts
    1,588
    Thanks Thanks Given
    4
    Thanked in
    If you can get the grease and the major surface rust off the metal then I would go for two coats of Epoxy Mastic - at least that is what it is called on this side of the pond, it will be a semi gloss in finish and sticks like the proverbial, you will need some warmth to get the cross link working. Over here it comes in black and a sort of red and I think may be other colours now. As your car is black then it would be ideal IMO.
  7. #7
    Join Date
    May 2004
    Location
    Fingerlakes in upstate NY
    Posts
    472
    Thanks Thanks Given
    Thanked in
    What they said about clean! Then 2 part epoxy, or 2 part urethane, or POR-15.
    Dale
    BJ7 frame up restoration of "the car that would not be restored"; began Dec. 2005, est. complete 2023
  8. #8
    Join Date
    Dec 2010
    Location
    san luis obispo california
    Posts
    2,073
    Thanks Thanks Given
    Thanked in
    If you end up using spray cans... Set them in hot water till they are warm. They will spray much better than at room temp.
    A wise man knows he knows not. Lao Tsu
  9. #9
    Jedi Knight Healey Nut's Avatar
    Join Date
    Sep 2013
    Location
    Ottawa Ontario
    Posts
    927
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Get it super clean and scuffed and then use small detail rollers and brushes and use paint on truck bed liner .
    "If it aint broke ....dont fix it "
    " Thats not an oil leak ..........its a special automatic British rustproofing system "
    Best Healey in show ABCD Ottawa 2013
    Best Healey in Show Boot n Bonnett Kingston 2013
  10. #10
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,241
    Thanks Thanks Given
    4
    5
    Thanked in
    Once you get it clean, you're probably going to find at least surface rust that you're going to have to neutralize or eradicate before painting. You may be able to neutralize the rust and get some black color on it in one step with this: http://www.eastwood.com/eastwood-bla...over-rust.html
    Rick
  11. #11
    Join Date
    Dec 2017
    Location
    Tolland, CT
    Posts
    8
    Thanks Thanks Given
    Thanked in
    Thanks for all the input. I start on Friday!!
  12. #12
    Yoda NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    9,696
    Blog Entries
    1
    Thanks Thanks Given
    1
    11
    Thanked in
    Matt - how 'bout a photo or two?
    Tom M.
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  13. #13
    Join Date
    Dec 2017
    Location
    Tolland, CT
    Posts
    8
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by NutmegCT View Post
    Tom M.
    For sure. I'll photograph my steps and post my progress.
  14. #14
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    2,639
    Thanks Thanks Given
    4
    8
    Thanked in
    This brush-on Permatex product dries into a black primer. I used it on some suspension pieces. Used Eastwood Rust Encapsulating Primer spray on engine compartment and frame areas with surface rust. Search for this by Permatex 81775.
    Steve Gerow
    Altadena, CA, USA
  15. #15
    Join Date
    Nov 2005
    Location
    SoCal
    Posts
    9,234
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Total newbie question here - is body color the correct finish for the underside?
  16. #16
    Join Date
    Dec 2010
    Location
    Posts
    2,073
    Thanks Thanks Given
    Thanked in
    Yes it is!
  17. #17
    Join Date
    Dec 2017
    Location
    Tolland, CT
    Posts
    8
    Thanks Thanks Given
    Thanked in
    IMG_3136.jpgIMG_3137.jpgIMG_3139.jpgThe before pictures....
  18. #18
    Join Date
    Dec 2010
    Location
    Posts
    2,073
    Thanks Thanks Given
    Thanked in
    Frame looks great from here, nice clean crossmembers.
  19. #19
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    2,639
    Thanks Thanks Given
    4
    8
    Thanked in
    Quote Originally Posted by elrey View Post
    Ditto. Wish mine looked that smooth!
    Steve Gerow
    Altadena, CA, USA
  20. #20
    Luke Skywalker RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,573
    Thanks Thanks Given
    2
    Thanked in
    Hi All,
    As I understand, the correct color for the for all body metal (frame, engine compartment, interior) is the body color and in my case my Healey was always painted Old English White (OEW) with black upholstery. However, I was never happy with the OEW engine compartment in contrast to the metallic engine or how the white would appear between some seams of the black interior panels. Additionally, I never liked the look of the OEW frame or how dirty the under fender would look with normal driving.
    When deciding to refinish my car in the 1980s, I decided to retain OEW on all exterior panels but to paint frame, suspension and engine-compartment a standard Black semi-gloss Ford frame paint. This black shows off the green metallic of the engine much better while not showing off any oil drips. Additionally, the black paint of the cabin, frame, and suspension is, in my opinion, more fitting and highly compatible with my Healey's black interior as well as under-car components (including under fenders) and points up my wire wheels (chrome or silver painted) and Old English White body paint.
    Although I don't have the perfect pictures to show my point, the first presents how the black wheel-well presents the wires and how the black exhaust and frame do not take away from the body line. Additionally, the second presents how the black frame and engine compartment present the engine and other components. Now imagine how the pictures would be presented if all was painted OEW.
    Yes, my preference and not original but, in my opinion, presents the original with a better contrast and is much easier to maintain.
    Ray(64BJ8P1)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
