TR2/3/3A TR3 Overdrive Transmission Verification
Moosca
Is there an easy way to verify if the transmission on a TR3 is an Ovedrive Transmission, or do you have to pull the tunnel?
CJD
You should have the electrical switch to the left of the steering column. The commission plate on the firewall will be stamped with "LO" at the end. Both of those tell you the car originally had the OD. The verification that it is still there would be to look under the car...the OD has a large drain plug behind the tranny that is very visible. If you can't get under the car, then look for which side the speedo cable originates. If it comes up on the left, it is a non-OD. If it comes up on the right and crosses the firewall under the battery box, then it is an OD tranny.
Moosca
Moosca
The Stamp says LO, the switch has been replaced by a turn signal toggle (so no OD switch), but the speedo cable comes out of the right side of the transmission cover. I will try to crawl under and look at the plug. Thanks!
TR3driver
Great Pumpkin - R.I.P
Look under the car if you can; a DPO may have gotten the other things wrong. Here's a view of the OD drain plug
And a non-OD
G Wanted TR3 Overdrive Transmission Triumph Classifieds 2
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
D TR2/3/3A TR3 Overdrive to transmission mating problem Triumph 8
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
M TR2/3/3A TR3 Overdrive filter drain plug Triumph 7
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
S TR2/3/3A Triumph tr3 overdrive wiring Triumph 9
Got_All_4 TR2/3/3A Looking for advice in driving a TR3 with overdrive Triumph 6
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
S TR2/3/3A tr3 overdrive-toast Triumph 6
Q TR2/3/3A Speedo Gear Drive On Tr3 Overdrive? Triumph 0
O TR2/3/3A TR4 overdrive in TR3 Triumph 4
O TR2/3/3A TR3 Overdrive Weight? Triumph 6
G TR2/3/3A Tr3 Access Needed to Replace Speedometer to Overdrive Triumph 2
M TR2/3/3A TR3 overdrive switch Triumph 1
TRclassic3 TR2/3/3A TR3 overdrive switch Triumph 3
HerronScott TR2/3/3A Cheap TR3 overdrive in Allentown PA? Triumph 14
T TR2/3/3A TR3 w/overdrive speedo cable routing??? Triumph 2
T TR2/3/3A TR3 overdrive question Triumph 5
S TR2/3/3A "Hard" Overdrive Engagement - TR3 Triumph 11
Mark Jones TR4/4A Anyone looking for an overdrive for a TR3 or TR4 Triumph 4
prb51 TR2/3/3A Tr3 and overdrive - opinions please Triumph 15
