Eastwood Surface conditioning tool
Bayless
It looks pretty handy to me but for that money I think my DA will do just fine.
TomMull
Agree, nice but pricey. The drums are not cheap either. You can get 10 flop discs for your angle grinder for less than one drum. But I do like the idea of a much larger contact area.
Tom
DavidApp
I was thinking it may be an easier way of getting my tub ready for paint. Sandblasting it seems a bit daunting. One of the claims is the lack of heating in the work area.
Depends on how long the drums hold up. The expandable drum for sand paper does seem very high as does the spiky drum.
David
LarryK
Just be careful of the type of grit wheel you use, can scratch metal.
Popeye
Bronze
In my -very limited- experience, I seem to always fall back to sandblasting. The hard part is transporting parts, as someone who only owns small cars. A U-Haul pickup plus trailer and miles is $100, sandblasting a few hundred - depending on how much. If you live in a wide open area, you could have blasters come to you - often not an option for a city dweller.
Trading several days of sanding, supplies, and then still not getting into all the nooks and crannies... leads me to professional blasting,
JPSmit
I keep coming back to blasting as well - though carefully as I have had a zealous blaster ruin some panels.
I am intrigued by mobile dustless blasting as it goes on wet and seems to be much easier on metal + they come to you.
This is in your area.
https://uglyblaster.com/
DavidApp
I gather they add something to the water to prevent flash rusting. That place is about 50 miles from me. May call to see what they would charge to come out and do it.
If I sand blast the tub I will do it myself.
David
NutmegCT
I'd think that unless you either (1) won't need blasting at all, or (2) somehow save over $200 in blasting costs, this $200 tool is just another thing to take up shelf space after having a few hours of fun. If you're already able to do the blasting yourself, at no cost, the tool *might* be a time saver.
Frugal Tom
DavidApp
The time saving was what I was hoping for. Blasting is not the most pleasant task to have to do so anything to speed up the work is a plus. In some areas it may speed up the work.
Also I gather on flat panels like the bonnet sand blasting can cause some distortion. They claim the Surface Conditioning Tool does not heat up the metal.
David
Bayless
I think any kind of abrasive can heat the metal if not used right.
Popeye
Bronze
Paul, that is beautiful!
Maybe I should clarify my preference for blasting: On "smooth" or continuous curves like shown by Paul, flapper wheels or similar are great. I find the problem comes when there are corners and bumps, which a flapper wheel can't reach. Or if the pitting is "deep" but harmless. "Deep", for example, on a frame, where there is significant metal thickness, and cosmetics are less important. Flapper wheel grinding to bare metal could remove a lot of metal.
Back to the original question, could you do a TR3 tub with a flapper wheel? I suppose yes, but the corners will be difficult to get to, and any spot weld bumps. Perhaps augmenting with hand sanding, a Dremel tool, or one of those multipurpose tools to get in all the nooks and crannies?
DavidApp
On reviewing several youtube videos not by Eastwood I may go the flapper disc route. The SCT may not reach into a lot of areas on the tub.
David
PAUL161
Where did you find the box of 100 Discs? E Bay?
David
Yes David, ebay, they come in finer grits also, I like a 120 grit, you use more of them but they create a more polished finish. A coarse grit is fine for heavy stuff if you don't apply much pressure. Expensive if you buy one at a time, as in Lowes or Home Depot. PJ
TRMark
Bronze
I use my own form of "dustless" blasting. I use a pressure tank blaster and glass media. I hold a water nozzle set to mist in front of the blast nozzle. I spread some cheap tarps on the driveway. I have a fenced concrete apron area in front of my shop. The water seems to drop the spend glass and paint onto the tarp. I wait a few days for the water to evaporate then sweep the tarps. After blasting I blow off the piece with compresses air and apply Eastwood After Blast. I don't know of any method besides blasting to clean some projects. Manure spreader wheel were my last blast project.
steveg Soaking in vinegar vs Eastwood Zinc paint Austin Healey 12
tomshobby A nice surprise from Eastwood Company Restoration & Tools 2
B Eastwood leadwork DVD Restoration & Tools 2
T Eastwood Aluma Blast Paint Triumph 11
Don_R POR-15 vs Eastwood Encapsulator Triumph 19
KiKi Eastwood Body Solder Restoration & Tools 5
T Eastwood forum - waste of time Triumph 25
TR4 ZDDP Additive from Eastwood Triumph 41
Basil Eastwood DVD Set Restoration & Tools 2
J Eastwood alumablast paint Triumph 2
angelfj1 EASTWOOD - Electroplating System Tin Zinc Triumph 8
A RUST: Eastwood, POR15, KBS or ??? Austin Healey 8
Lin Garage Lifts [was "Eastwood Midrise lift"] Austin Healey 14
S Anybody tried Eastwood's Tin Zinc Electroplating? MG 4
B TR6 Crankshaft long seal surface Triumph 5
L Best Polish to remove surface scratches Austin Healey 12
MG Lily Best way to safely remove minor surface rust? Restoration & Tools 5
Jim_Gruber Surface Rust Removal Spridgets 21
B Best shop floor surface? Triumph 21
K Cleaning up exterior surface of SU's? Triumph 8
bighealeysource surface crack in water outlet elbow on BN2 Austin Healey 3
RickB Surface rust treatments - hard to reach surfaces? Spridgets 9
WidespreadPanic Floorpan surface rust - how much is too much? Triumph 13
I Surface Mail Service Triumph 1
Lin Pulley and belt configuration for air conditioning Austin Healey 2
drambuie Air conditioning your Healey [Great installation] Austin Healey 10
I General air conditioning questions Triumph 4
justin_mercier Wedge TR7 Air conditioning help / books/ manuals? Triumph 16
W Re-conditioning vinyl hood Spridgets 2
T Air Conditioning Temperature Jaguar 2
T 1989 XJ6 air conditioning Jaguar 1
bighealeysource AIR CONDITIONING IN A BIG HEALEY Austin Healey 12
George Zeck Side Curtain Re-Conditioning ??? Spridgets 14
DNK Air Conditioning Going Bye-Bye Triumph 5
jjbunn Air Conditioning MG 15
C MGB MGB convertible—28,096 miles—Air Conditioning MG 16
AUSMHLY Air conditioning in a Healey...see photo Austin Healey 30
P 92 XJS Air Conditioning Questions Jaguar 8
mgbmedic MGB MGB Air conditioning MG 30
T Wedge TR8 air conditioning parts?? Triumph 3
Webb Sledge Air Conditioning? Triumph 78
