Results 1 to 19 of 19
Thread: UV water filter?
The Pub is: Forum to generally shoot the breeze. It is NOT: a debate forum (NO Politics, religion, or controversial topics.) Keep it clean, fun and lite!
  1. #1
    Yoda NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    9,847
    Blog Entries
    1
    Thanks Thanks Given
    6
    Thanks Thanks Received
    17
    Thanked in
    UV water filter?
    I wondered if anyone is using an undercounter or whole-house UV water treatment system.
    For various reasons beyond my control, my well water tests always come back positive for bacteria. Not E. coli, but coliform bacteria none the less. Chlorine treatments work for a few weeks, but the bacteria returns.
    Other than the infinitesimal bacteria count (one in 100 mL, zero E. coli in 100 mL), my water tests excellent regarding minerals, sediment, chemicals, etc.
    UV is recommended for decontamination of bacteria in well water - so I wondered if any BCFers use such a system.
    Thanks.
    Tom M.
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  2. #2
    Join Date
    Mar 2002
    Location
    Sacramento
    Posts
    1,753
    Thanks Thanks Given
    Thanked in
    Re: UV water filter?
    I also have a well and use a reverse Osmosis system with UV. I chlorinate every 6 months, usually when we are going somewhere so it sits down there for a few days. The system has 3 filters and with the reverse osmosis, no bacteria can get through. The UV came with the system, I did not have it on the previous system. So all drinking water comes out of the one facet, We do not use it for the whole house. But, I do have a charcoal filter for the whole house.
    Wells are more work but then, have you ever tested city water, maybe it has bacteria also.
    Jerry
  3. #3
    Jedi Warrior SD Bugeye's Avatar
    Join Date
    Jan 2015
    Location
    South Dakota
    Posts
    530
    Thanks Thanks Given
    Thanked in
    Couple of things to keep in mind Uv bulbs typically are 254 195 nano meter wave length to be effective
    as the y age the frequency change rendering them to being a pretty blue light
    10 months of burn time then change them .
    activeated carbon is good for chlorine removal and turbidity and taste
    the draw back with home carbon filters is you can’t steam them or backwash them
    the best thing to do,is size them as close as possible to the us piont post carbon you want to be ideally about 10 GPM per cubic foot.that will remove chlorine and chloramines and keep the laminar flow to a minimum
    They can be a area where bacteria tends to grow as there is an abundance of organic there
    so bigger is not always better
    change it at least bi annually also check chlorine break thru with a chlorine test kit.
    and the more you use the better idle carbon is bad carbon.
    as for the RO element typical home units are CA elements they work best at approx 1-2 PPM chlorine.
    inexcess of that or no chlorine will shorten the life
    if your shock chlorinating your well don’t alllow the high PPM to,reach the RO element.
    Door handles,Bootlid,Glovebox all fads
    59 sprite
  4. #4
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    9,847
    Blog Entries
    1
    Thanks Thanks Given
    6
    17
    Thanked in
    Thanks gents.
    Jerry - does your RO system sit under the sink? run on 120 volts?
    Do you know the make/model of the unit?
    Thanks.
    Tom M.
  5. #5
    Administrator Basil's Avatar
    Join Date
    Dec 2000
    Location
    Turn left at Albuquerque
    Posts
    21,448
    Blog Entries
    7
    Thanks Thanks Given
    18
    13
    Thanked in
    We have a RO system, but it's not UV, it's a Kinetico RO system and we have it in the kitchen pantry. It only feeds the drinking water at the refrigerator. We're on city water but it's very hard (which is why we also have a softener). I've never had our water tested for bacteria, only for mineral contaminants.
    "The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails.."
    -- William Arthur Ward
  6. #6
    Join Date
    Mar 2002
    Location
    Sacramento
    Posts
    1,753
    Thanks Thanks Given
    Thanked in
    mine is under the sink and was bought off amazon. dont know the brand, it does run on 115v because I bought the unit that has a pump this time. lower water pressures limit the process, the pump speeds it up.
  7. #7
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    9,847
    Blog Entries
    1
    Thanks Thanks Given
    6
    17
    Thanked in
    Thanks gents. I'm waiting for a new water analysis result, but after one neighbor dammed the creek and the water table rose, and another neighbor decided to use liquid manure on his hill-top field ... I'm figuring the test will come back positive for bad stuff.
    I'd never even thought about bacteria, until a few years ago when my cat decided not to drink the water in his cup. I had the water tested, and results showed E. coli. No way to prove the link to neighbors' activities, but I'm getting tired of wondering, and shock treating the well with bleach so often.
    Thanks.
    Tom M.
  8. #8
    Join Date
    Dec 2000
    Location
    Posts
    21,448
    Blog Entries
    7
    Thanks Thanks Given
    18
    13
    Thanked in
    Quote Originally Posted by NutmegCT View Post
    Thanks.
    Tom M.
    Liquid manure - yikes!
  9. #9
    Yoda PAUL161's Avatar
    Join Date
    Jan 2005
    Location
    Locust Grove, Oklahoma
    Posts
    8,772
    Thanks Thanks Given
    5
    Thanked in
    We have city water, but drink water in the house from the refrigerator which is filtered. The frige will indicate when the filter needs changing, at 40 bucks a clip! Saying that, when I'm out at the barn, I drink water from the hydrant/freeze protected faucet even out of the hose at times. I know, I should have been dead 10 years ago according all the pros on the subject, but I'm still kicking, so I guess our water isn't all that bad. I've been drinking water out of a hose since I was a kid, even spring water out of a stream, also out of a stream of glacier water in glacier national park and never got sick. My wife doesn't agree with my habits on the subject, but at 78 I aint worried about it. Just sayin. PJ
    Remember, Never Forget
    We Live In The Land of The Free
    Because of The Brave
  10. #10
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    9,847
    Blog Entries
    1
    Thanks Thanks Given
    6
    17
    Thanked in
    Paul - don't change a thing!
  11. #11
    Join Date
    Jan 2015
    Location
    South Dakota
    Posts
    530
    Thanks Thanks Given
    Thanked in
    A poorly maintained water purifying system is more of a health risk than your garden hose
    we have created more issues than they are with
    I”m an SME for Suez
    i drink out of the garden hose the tap water from the Missouri River
    unless there is truly an issue with your local water source don’t bother with purifying your water
    under sink water systems there more trouble than there worth unless you in enjoy laying on your back under a sink.
    and bottled water eh won’t hurt you but really. Why bother unless your water has a bad odor or taste..
    Life’s short don’t sweat the small stuff drink beer!
    if you truly are concerned have your water tested before you spend a dime on any kind of treatment
    you could exasperate the situation.
    there is no sense in creating a home for bugs in your perfectly good menards 3/4’ Rubber HD garden hose.
    59 sprite
  12. #12
    Yoda waltesefalcon's Avatar
    Join Date
    May 2002
    Location
    Fletcher, Oklahoma
    Posts
    4,861
    Thanks Thanks Given
    24
    3
    Thanked in
    My dad had a very good friend who was a survivor of the Bataan Death March and he always attributed his survival to having grown up in SW Oklahoma heat, and drinking water out of stock tanks and streams. He said that he never once got sick and as a result had an easier time keeping weight on his frame than many of his fellows who came from places with a milder climate and treated water.
    Cheers,
    Walter
    52 International L110
    61 International C112
    68 Cadillac Coupe DeVille
  13. #13
    Join Date
    Jan 2005
    Location
    Posts
    8,772
    Thanks Thanks Given
    5
    Thanked in
    Quote Originally Posted by waltesefalcon View Post
    My goodness Walter, wonder if that's why my weight stays around 170? I think along with a lot of activity helps also. Since being retired, I've told the wife that I was thinking of going back to work, just to get a rest!
  14. #14
    Join Date
    May 2002
    Location
    Fletcher, Oklahoma
    Posts
    4,861
    Thanks Thanks Given
    24
    3
    Thanked in
    Well Paul, my guess is that you are just healthy. On that note though, I do know that when I go to Mexico I can drink the water without adverse side effects, I attribute that to having grown up drinking well and creek water. I still will drink out of streams when I go hiking.
    Cheers,
    Walter
  15. #15
    Darth Vader John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    2,894
    Thanks Thanks Given
    7
    1
    Thanked in
    1 Post
    When I was a grad student at Berkeley, one of the other students was from Mexico. When he came to Berkeley, he drank the water and received adverse side effects. I concluded it's all what you're used to.
    John, BN4
  16. #16
    Join Date
    Jan 2015
    Location
    South Dakota
    Posts
    530
    Thanks Thanks Given
    Thanked in
    Yup your body has to shift gears...
    lol!
    59 sprite
  17. #17
    Join Date
    Dec 2000
    Location
    Posts
    21,448
    Blog Entries
    7
    Thanks Thanks Given
    18
    13
    Thanked in
    Quote Originally Posted by SD Bugeye View Post
    lol!
    My clutch keeps slipping!
  18. #18
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    31,901
    Thanks Thanks Given
    5
    2
    Thanked in
    Quote Originally Posted by Basil
    "I hear and I forget. I see and I remember. I do and I understand."
    I GROK.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  19. #19
    Join Date
    Mar 2002
    Location
    Sacramento
    Posts
    1,753
    Thanks Thanks Given
    Thanked in
    I use a filter on my house well because:
    1. arsenic in the area
    2. Lots of gold mining done around here, more mercury and stuff around here
    3. The county recommended a filter??
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
