bt7 head surprise
  • Thread starter Deleted member 21878
  • Start date
got my head and block back from the machine shop. while blowing out all the passages i found this in the one coolant passage. fullsizeoutput_17b.jpg had to break it a few times to get it out. first i thought it was something from the casting. still not sure. it was hard to break and pretty brittle.
CraigC
It looks like one of the wires that support/strengthen the cores when the block/head were cast. Not uncommon.
gonzo
Drone Dog, I plan to follow your engine build if your choose to share. Will this be built for moderate performance? Webers, Headers, Fuel Injection? This is going to be fun! Good luck and keep letting us know your progress and pitfalls. GONZO
Gonzo
you give me way too much credit. this engine will hopefully be built to "run." i think taking this engine to that next level really takes some planning and i am not there yet. this is my first attempt at such a project. i have done a number of other cars to one degree or another but none to this degree. of course i am retired now so i have a lot more time to do more. and i really enjoy doing it.
having said that i am also aware that this car will never be a top end Healey. i would have needed to do a lot more than i am doing and spend a lot more money than the car would probably ever be worth or i can afford. my goal for this engine, as well as the car, is a nice driver. to me the fun is in the build. if not for the internet i am sure i would not have taken on such a project. hence all my silly questions.
but i will be happy to share all i can. i certainly get enough help from others.
at this point i have gotten my crank, block and head back from the machine shop. my original hope was the engine would be in fine shape and i would just need to do some minor work to get it running. but when checking the main bearings, i knew that was not the case. the crank was turned to 10 over on the main and rod journals. the cylinders looked really good so we just reamed the top and honed them. they are standard bore. originally i thought they had liners in them but discovered they did not. just looked that way from the bottom of the engine.
at this point i have ordered bearings, rings, and a host of other parts to start this rebuild. i ordered them thru Tom's toys in oregon on the end of year sale. with Christmas coming i knew i was going to be very limited on time over the next couple of weeks. So right now i am just trying to get prepared. first thing is i wanted to get some paint on the engine parts before too much rust starts to form. So yesterday and today i have been painting. (some parts i had painted while waiting for the machine work to get done.) i realize i will probably have to hit it all again once assembled but i wanted to get some paint on now.
thats about it for now. i realize there will be some surprises. (see thread on cam bearings) but that is part of the fun. And expect lots of questions to come.... for instance i just read somewhere that the head bolts should not be run down to the manual spec but hand tightened. they could crack the block if torqued. not there yet so i have not worried about it. one step at a time.... ha
after thinking about it, i guess i do have four planned modifications for the engine.
1) convert to negative ground. i have a new electronic fuel pump from SU pumps.
2) alternator: i ordered the conversion kit from Hendrix. i also purchased a Delco alternator. both are painted and ready to go.
3) spin on oil filter conversion / also from hendrix
4) pertronix ignition and coil.
Rob Glasgow
Those are all great modifications. I have done 3 of the 4 you listed. (still have a generator). Put one more on that list for sometime, now or in the future, a 3.54 rear differential. That's the best thing I've done in the past 50 years of Healey ownership.
One of the wonderful things about all the photos members post is seeing their work spaces. Always a joy seeing what they hang on their walls and how neat or messy their work space. Certainly adds to the enjoyment of watching someone else's rebuild.
LarryK
I did the head on my 80 Spit and the head on my GT6 and both had stuff in the passages, almost thought it would have over heated the GT6.
gonzo
You might consider a gear reduction starter. Turns engine over faster than stock lump. Running one of these for about a year now without issue except that I'm getting tired of the sound it makes. Too modern and hyper. Just reinstalled the original lump over the weekend and it's still up to the task of starting "on the button". One somewhat lazy wrrr and vrooom! I also finished a engine compression check with it installed and there were no issues - then again I had none before the GRS was installed. Keep at it Drone Dog, a good part of a restoration is the journey and satisfaction of a job well done. Take your time and enjoy. GONZO
D BT7 head manifold studs Austin Healey 7
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut For Sale BJ8 and BT7 parts for sale Austin Healey Classifieds 62
CLB62 1962 Austin Healey BT7 Mk II Austin Healey 15
F Heater pipe and air duct routing BT7 Austin Healey 3
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
