TR2/3/3A radio mounting plate
friar mike
Hi this is my first post here I have a 1955 tr3 I am in the process of a full off the frame restoration.
I noticed the glove box hole had a plate in it bolted in and covered with upholstery so I pulled it off and took the upholstery off and found a square hole in it like for a radio now this car did have a radio at one time but not now.
This plate is die cut and the mounting studs are the same as the Guage panel uses.
This is not homemade also where the glove box door hinge screws go the holes are in the steel but the dash covering has never been punch through so screws have never been in and the dash covering is original.
So far I can find no information on this as far as I know the only radio mount was under the dash on the tunnel I looked for screw hole in the tunnel and there in no holes so it didn't have a radio there.
I would post photos but I don't know how to on this site.
Got_All_4
Welcome! I was just going to ask for pics. Don't know of any other radio mounts then the under dash. To post a pic go to Go Advance button bottom right corner and it's pretty straight forward from there.
TR3driver
Great Pumpkin - R.I.P
Early cars did have the option of a tube radio, with the control head mounted through the cubby box; a large square box of electronics mounted separately behind that, and a big speaker located in the RH side kick panel. This was before the tunnel mount, though I'm not certain of the change point offhand. The hole in the kick panel was also punched even on cars without the radio for quite a while.
Here's a photo album from WillE
https://s613.photobucket.com/user/WillE_1234/slideshow/TR2/?albumview=slideshow
PS, Welcome to the asylum!
F
friar mike
Yep that's it!
I kinda thought the was the case.
This tr I tried to buy in 1973 I didn't even have a license yet fast forward 4 months ago some how she came back to me so I own it now but it hasn't aged well and I should have me head examined it's going to need to have about 60% of its body replace.
Who ever bought this car new he ordered it with everything he could including the hard top it has never even had a soft top on it.
Well I am going to start a page on its story and restoring soon.
Sorry I still not see how to post photos and I have posted photos on many other sites so I have done it before I am just not seeing it here.
TR3driver
Look for this icon in the bar above the area where you type. On my screen, it's the 3rd from the right (YMMV). Clicking that should give you a pop-up window where you can choose either "From Computer" or "From URL". Choose "From Computer", then click the "Browse" button. Select your file, click "Open", then "Upload File(s)". The result will often be a thumbnail, but folks can click on that for a larger version (size is still limited, though).
brgrmyster GT6 GT6 radio mounting plate? Triumph 5
KVH Radio Mounting Hardware Triumph 5
Darrell_Walker Wedge Wedge radio mounting Triumph 16
H mounting brackets for "original" radio box Austin Healey 2
Bruce_B Mounting Radio in dashboard need trim kit Spridgets 0
zoohow radio and console mount Restoration & Tools 1
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
J TR2/3/3A TRIUMPH Radio? Triumph 13
S Radio Antenna Spridgets 5
D Removing Old Radio Austin Healey 4
T TR2/3/3A Question on old radio from my TR3 Triumph 9
Got_All_4 TR5/TR250 Pros and Cons to Wiring The Radio Direct Triumph 6
E Alpine radio for a US Model Db7 Volante Other British Classifieds 0
Hangtown Healey Barbie Clock-Radio Austin Healey 9
M General MG OEM Radio wiring help MG 4
pkmh Radio Knob Design For A 67 BJ8 Austin Healey 16
red57 Positive ground radio Austin Healey 17
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
T how to have music/radio when driving Spridgets 33
7 Strange A/C - radio problem Other Cars 7
Jim McCauley TR6 TR6 Radio recommendation Triumph 4
M Fitting a modern radio Austin Healey 9
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
1 MGB '66 MGB radio measurements MG 3
6 Spridget Radio/Speaker Case Spridgets 4
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
Tim Tucker TR4/4A BENDIX Radio Model: 5SMTR manual? Triumph 2
T Wanted Wanted: BE Sprite Original Motorola Radio Spridgets Classified 8
H Vintage Radio Austin Healey 9
Zitch TR4/4A Original Radio knobs Triumph 12
M S1 e type radio console Jaguar 2
wangdango BJ8 radio delete plate? Austin Healey 2
Got_All_4 TR2/3/3A TR3 radio console Triumph 30
Marvin Gruber Becker Mexico radio Austin Healey 7
kennypinkerton MGB Radio console removal question MG 4
D Radio! Other Cars 0
Zitch General TR WTB - Triumph AM radio. Triumph 11
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
Scotsman General TR Radio Triumph 4
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
G original radio 1961 e series jaguar Jaguar 3
TulsaFred Bugeye radio in-dash Spridgets 10
B orginal BMC radio Austin Healey 9
Mink TR4/4A Radio plate/dash support orientation Triumph 6
C TR2/3/3A Triumph radio installation date code Triumph 7
Gliderman8 TR6 Stereo radio? Triumph 4
R TR4/4A Assembling the interior - dash support and radio plate screw holes don't match up Triumph 4
catfood 100/4 Radio consule Austin Healey 2
S Radio / Speakers Spridgets 12
