TR2/3/3A Brake Fluid
Redoakboo
When I bought the car, the owner was using DOT 3 synthetic. Is that still a good product to continue using? I plan on bleeding the clutch slave cylinder as what I have gotten out so far is pretty black.
TR3driver
Great Pumpkin - R.I.P
This is an often debated topic, with no clear winners. Personally, I much prefer DOT 5 silicone. It doesn't turn black, doesn't corrode brake components, and won't eat paint when it does leak (due to worn-out seals, etc). But it does have disadvantages too. You can read more about pros & cons at
https://www.buckeyetriumphs.org/technical/Brakes/Fluid/Fluid.htm
That article references several technical papers, which you can find at
https://drive.google.com/open?id=0B2H2NJt34OffdnhWS19scjlNUU0
I particularly enjoyed the Browning paper, as it shows that conventional (DOT 3/4/5.1) fluid absorbs not only water, but salt; and can do so right through the hoses! It's no wonder the stuff becomes so corrosive over time!
I've seen this multiple times (although never quite this bad). This was the clutch slave on TS13571L when I started reviving it from a 34 year hibernation.
bobhustead
They don't "mix". If the question is whether the system needs to be flushed of all 3 before starting the 5, there is some disagreement on this forum. The instructions on my fluid container said something like 'add the 5 and bleed til purple is coming out the bleeders'. I did and it has been fine for 5 years.
TomMull
I did the same although I just finished my second year.
I would also mention that the DOT 5 appears to be a poorer lubricant and my newly rebuilt and honed master cylinders are a bit slow to return. Not really a problem with the brakes but I can't "sped shift" with the clutch. I don't remember having the problem with rebuilt cylinders using DOT3 so I can only assume the DOT 5 contributes. I do plan to polish the bores before next season and continue using DOT5.
Tom
poolboy
Empty the reservoir first, would be my recommendation.
I absconded with a turkey baster for such duties.
6 Brake Fluid Spridgets 1
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
B General MG Brake fluid MG 7
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
G Brake fluid missing Austin Healey 6
Joe Schlosser Brake Fluid Spridgets 5
steveg Silicone brake fluid conversion - existing system Austin Healey 41
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
Rut Brake fluid Spridgets 11
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
L 100/6 BN4 Brake fluid Austin Healey 17
M Losing Brake Fluid Austin Healey 8
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
petnatcar BRAKE FLUID CONTAINER for BT7 Austin Healey 0
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
tomshobby brake fluid leak? Spridgets 1
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
C Brake fluid? Austin Healey 10
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
DNK Copper in Brake Fluid Other Cars 2
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
K Synthetic brake fluid again? Triumph 3
