clutch slave cylinder
Administrator
Boss
You posted your question in the "Forum Navigation Help" forum - that's where you ask questions about navigating in the forum. I am moving this post to the Triumph Forum.
Redoakboo
Just finished bleeding the clutch slave cylinder on my 57 TR-3. I have a bleeder jar with a plastic tube and a hole in the top. Put your box end wrench on the bleeder valve, connect the tube, have someone in the car depress the clutch petal to the floor while you open the valve, close the valve, raise the clutch petal. Do this several times until all the air is out of the system, make sure you maintain the fluid level in the resovoir.
Dick
Lukens
newreply.php
I bleed my clutch slave backwards (from the slave to the master cylinder)
CJD
newreply.php
With the supply tubing connected to the lower side of the slave cylinder, wouldn’t that leave a bubble in the slave cylinder? If you get rid of the bubble in the slave...then it should work for the master cylinder.
KVH
I find it best to have a helper, but the one-man rig sold by Griott's is supposedly very good. I own one, and have used it, but quite frankly, I've got nothing to compare to, and I'm uncertain whether it's resulting in the same tight clutch my wife's foot achieved. It almost seems too simple.
Rut
It seems like the clutch hydraulics are a pita to bleed on every LBC and I started putting remote bleeders on the slave cylinders a few years ago. It allows access without getting under the car and gives the air bubbles a place to go even while sitting. It’s no more than a flexible hydraulic line screwed into the highest port on the slave cylinder...I used a Speed bleeder on mine, but a regular one works a treat. This is the one on my 70 MGB.
Rut
TR3driver
Great Pumpkin - R.I.P
On the TR3s, I've been "self bleeding" for a long time. You have to first get enough fluid in the MC for it to work (usually only a problem if it has been freshly rebuilt); but all it takes is loosening the outlet fitting and working the pushrod by hand for that to happen.
Then tighten the fitting, get in the car and pump up the clutch. Hold the pedal down for a few seconds (maybe 10 or 15) then release. Wait a few more seconds, then repeat. Generally 3 cycles of that is enough to drive the car, so take a drive. It still won't be perfect, but will improve as you drive.
cmjb11
I have a 1974 Spitfire and I was wondering if there is a way to bleed the slave cylinder without removing the interior Bell Housing Cover. Can I do it from under the car?
K New Clutch Master/Slave Cylinder Austin Healey 1
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
BobHaskell For Sale Clutch Slave Cylinder Bleeder Extension Austin Healey Classifieds 13
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
B MG midget Clutch slave cylinder Spridgets 5
WillR MGB new clutch slave cylinder MG 3
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
TomChar TR6 '74 Clutch Slave Cylinder location Triumph 8
G MGB Clutch Slave Cylinder MG 34
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
J T-Series clutch Master cylinder or slave? MG 8
Boink Clutch Slave Cylinder dribble... Spridgets 20
L 1275 Clutch Slave Cylinder to BE Clutch Line Spridgets 14
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
Darrell_Walker TR4/4A TR4A clutch slave cylinder adjustment Triumph 2
Hairyone clutch slave cylinder Spridgets 14
M clutch slave cylinder? Triumph 5
T TR2/3/3A TR3 clutch slave cylinder Triumph 14
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
T TR4/4A TR4A clutch slave cylinder Triumph 9
B T-Series Clutch slave cylinder MG 15
mountainman tr 3 clutch slave cylinder Triumph 7
T Any tips on bleeding the clutch slave cylinder? Triumph 6
Bruce_B Anyone have a picture of Clutch Slave Cylinder.... Spridgets 4
JPSmit Qucik Question #1 Clutch slave cylinder Spridgets 2
Michael Oritt Clutch slave cylinder ID help needed Spridgets 3
Michael Oritt Clutch slave cylinder ID help needed Racing 3
MadRiver Speedbleeders for Clutch Slave Cylinder Triumph 3
6 clutch slave cylinder Triumph 2
tony barnhill Clutch Slave Cylinder Spridgets 17
roofman TR6 Tr6 clutch slave cylinder replacement Triumph 11
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
L T-Series Clutch Slave Cylinder Tubing MG 5
danielnorton After Marke slave cylinder for clutch hydraulics? Spridgets 20
SherpaPilot Clutch Slave Cylinder Mount Position Triumph 4
O Clutch Slave Cylinder Travel Triumph 5
T Clutch slave Cylinder HELP Triumph 3
M TR4/4A TR4 CLUTCH SLAVE CYLINDER Triumph 2
Z Clutch Slave Cylinder Rebuild Austin Healey 3
Z Clutch Slave Cylinder Rebuild Spridgets 2
Slider748 Clutch slave cylinder question. Help! Triumph 8
F clutch slave cylinder Austin Healey 12
W Clutch Slave Cylinder. Triumph 2
Alan_Myers TR4/4A TR4 clutch slave cylinder - stuck! Triumph 14
