TR2/3/3A Carburetor Rebuild
ckeithjordan
Hi All,
I’m having Joe Curto rebuild my carbs off my 1957 TR3, while they run OK, they do leak and have been sitting stored for almost 30 years. I’ve attempted to fix the leaks by replacing the jet seals, but figure I might as well get the whole shebang rebuilt and spiffed up while the car is dormant (I also need to replace other rubber parts under the bonnet and check the cooling system).
My question is this: When Joe sends back my carbs, what else do I need to do/repair/replace in order to make sure everything is running correctly? Timing? Condensor, points, plugs? New vacuum tube (mine is a metal/rubber/metal pipe)?
Thanks in advance for the collective advice.
charleyf
Keith,
Many owners subscribe to the adage that "if is isn't broke don't fix it". But after 30 years I would be suspect of the fuel pump. Sometimes those things work okay but they also have a rubber component that gets hard over time and then does not function. Next the fan belt and lots of lube on anything that can be lubed. Then change all of the fluids ( don't forget to clean out the gas tank). Once it is running then you can sort out what electrical parts might need replacing. In some cases the old parts might actually be better built than a new replacement.
ckeithjordan
ckeithjordan
Charley,
Thanks. I have already plans to replace the rubber parts and check out the cooling system. I was asking more about the tune-up pieces. The suggestion about the fuel pump is a good one.
poolboy
If you know how to do an ignition tune up, I'd say do it....points, plugs, condenser, distributor cap, rotor, and wires
TR3driver
Great Pumpkin - R.I.P
I'd suggest getting a copy of Practical Hints (which is effectively the owner's manual) and going through the periodic maintenance items it gives.
After 30 years storage, IMO it would also be a good idea to disassemble, inspect, clean and lube the distributor. However, if you don't want to go that far, at least hook up a timing light and verify that the centrifugal advance is working as it should. It's easy for them to get gummy over the years (or simply worn out).
Here's a later edition of PH; I don't have the earlier ones scanned yet. There are a few minor differences (like your car probably has a dipstick filler for the gearbox, instead of a plug on the side) but the service intervals and such should be good.
https://drive.google.com/open?id=0B2H2NJt34OffNjQ4MTkyNjItZTVmYi00M2U2LWJhYWUtMjEyZDgxMzUyNzUw
ckeithjordan
ckeithjordan
Randall,
Thanks for the suggestion. I have an early copy of the “instruction manual.” Scanned, too, if you want it for your on-line reference library (which has been helpful).
I have a dizzy replacement parts/upgrade kit from TRF, which I plan to use. I’m not sure about the ease of removing and cleaning of the distributor, though.
TR3driver
Sure, I'll take a copy.
There is some skill and effort involved with disassembling the distributor, but not much. Hardest part is driving out the pin that holds the dog to the shaft, preferably after making witness marks so you can reassemble in the same orientation. It should only fit one way, but it's best to mark it anyway, IMO. Also make a note of which way the rotor points before you remove the dizzy, and don't turn the engine while it is out.
Loosen the pinch bolt and pull the distributor housing up (it's OK to wiggle it some). Don't remove the pedestal unless you absolutely have to (so you won't lose the position of the drive gear against the cam).
The original Mills pin has a slight taper to it, it will be easier to remove if you drive on the small end. But it's possible it's been replaced with an ordinary split or roll pin, so if you can't see which end is smaller, just pick one.
I suggest buying a cheap pin punch in the right size, and then cutting it off just below the taper to make a "stubborn pin" punch. You can use that to get the pin started moving, the shorter length will make it much less likely to bend or break.
ckeithjordan
ckeithjordan
Randall,
PM sent.
sp53
Does the engine have proper oil circulation? Have you spun the engine over after it has set for 30 years?
steve
TFB
I like to do as much myself as I can but when it came to the distriburor it made more sense to me to send it out to Jeff at Advance distributors.
He is cheapest for the rebuilt vacuum advance,and when you put that savings toward the rebuild its not much more than doing yourself.
He also curves the advance to your motor specs.
I got the whole deal,rebuild with points(electronic also avail.),cap and wires and coil and it was very reasonable with about 2 week turnaround .Just a thought.
Tom
ckeithjordan
ckeithjordan
The engine is fine, except for minor oil and coolant leaks, due to sitting for so long. I’ve driven it several times.
I plan to go through everything and replace all of the “soft” parts this winter. The carbs were leaking around the jets, which I’ve fixed by replacing seals, but felt like I wanted to have them rebuilt not knowing what the PO actually did (he did do a F/O restoration). I also plan to have the engine rebuilt by Macy’s next winter 2018-2019.
ckeithjordan
ckeithjordan
Tom,
Thanks for your distributor suggestion. I’ll check out Advance Distributors.
ckeithjordan
ckeithjordan
Tom,
If I may ask, what was the cost of your distributor rebuild?
TR3driver
Does Jeff still change the initial advance setting to 12 BTDC? Might be an issue if you ever try to hand-crank the motor.
TFB
Tom,
It was five years ago so don't remember exactly but I think the dist.rebuild was 125 and the vacuum diaphragm was less than half a new one.At the time the cap and wires and Bosch blue coil were also competitively priced.
My old unit was beat up and it was nice to drop in a fully rebuilt unit.
Check out his website andI think you can get a quote.
Tom
SASSAMON
Jeff at Advanced Distributor rebuilt my 24D this past summer. Total cost including return shipping was $163. He recommended an initial 16 degree BTDC setting with the vacuum disconnected.
The distributor looks new and I am very happy with the results.
TR3driver
Just be warned, 16 before is plenty to cause a kickback when you're trying to crank by hand. IMO that's the reason the original curve calls for only 4 BTDC.
ckeithjordan
ckeithjordan
I have to ask, aside from the hand crank kick-back, what other differences would one notice 16 vs 4 degrees BDTC? Why the "great" discrepancy (difference)?
poolboy
The 4* ATDC is the effect of having the vacuum retard active and working at idle.
TR3driver
Vacuum retard was only on later cars, not a 57 TR3.
TR2-4 used 4 BTDC (not ATDC) as the factory (static) ignition timing, and then had a very aggressive centrifugal advance so the timing was advanced much more than usual as the engine came off idle. The purpose, I believe, was to make sure the timing was late enough to avoid kickback when hand cranking. With the spark occurring significantly before TDC, all it takes is for the cylinder to be full of combustible mixture and the crankshaft to be moving very slowly, to cause the cylinder to fire and force the crankshaft to turn backwards.
You'd have to check with Jeff for details, but I believe he installs a slower advance curve, such that the total advance is about the same at normal operating rpm, even starting with 16 BTDC static. (Or maybe just a pinch more, the factory total advance is fairly conservative.)
Just for grins, here is a comparison of the centrifugal curves for a couple of TR2-4 distributors, and a TR6 for comparison.
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
bigbadbluetr6 TR6 TR-6 Carburetor rebuild kit Triumph 6
PAUL161 SU Carburetor Rebuild Kits MG 16
bluemiata90 TR2/3/3A tr3 carburetor rebuild question Triumph 9
J Carburetor Banjo Seals Austin Healey 11
zoohow TR6 Carburetor Conversion kit Triumph 2
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
P Zenith Carburetor Triumph 2
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
A Spitfire Weber Carburetor Triumph 0
B gas leak underneath the carburetor Restoration & Tools 2
A TR6 Carburetor help Triumph 5
G TR6 Hacked carburetor? Triumph 6
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY SU Carburetor Synchronizing Kit on eBay Austin Healey 16
C TR6 Carburetor Throttle Linkage Triumph 10
FlyingCat Spitfire No Gas to Carburetor Triumph 18
FlyingCat Spitfire Which carburetor is the best? Triumph 9
F TR6 Carburetor issues at low rpms webers Triumph 23
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
D TR2/3/3A '59 TR3A SU carburetor Triumph 4
AUSMHLY Front carburetor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
G Gasket sequence manifold to carburetor Austin Healey 4
F General MG Help needed with su dual carburetor identification MG 4
KVH TR4/4A Carburetor float bowls Triumph 8
M BN1 carburetor fuel line Austin Healey 9
fpstude TR2/3/3A TR3 Carburetor Adjustment Triumph 6
D S.U. HD8 Carburetor Drawing Austin Healey 6
svtmikey GT6 C.D.S.E.V carburetor question Triumph 5
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
Lutz Kramer Carburetor gaskets Austin Healey 8
B BT7 carburetor - choke - fuel questions Austin Healey 5
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Keith_M carburetor woes Spridgets 17
C HD6 Carburetor Spacer Blocks Austin Healey 4
C Carburetor Removal on a BT7 Austin Healey 7
C Carbon Deposits in Carburetor Austin Healey 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
