TR2/3/3A runs excellent but starts hard after use
2billydavies
hey everyone,
been awhile since I've posted but i'm at a loss and need a starting point. my 58' TR3a runs absolutely perfect. fires right up (initially), runs perfectly... doesn't miss a beat. I have zero complaints with the way she's been running this year since my rebuild.
However... after she's warmed up she doesn't start very quickly at all if I shut her off. It takes many, many cranks to get her started back up and I just don't understand why. Sometimes (like lastnight) I'm afraid she isn't going to start at all.
Any ideas on where to begin searching for the problem? Originally I thought vapor lock... but i'm just not believing it. I've never had an issue with that before, ever. but i just don't know at this point. It sounds like maybe it's flooding her out but after poking around I just don't see anything leading to that.
Ideas/suggestions?? i should add that this ONLY happens after shes warmed up after use. no issues at all when starting the first time of the day or shes been sitting a while. very weird.
thanks so much! happy holidays to everyone reading...
TR3driver
Great Pumpkin - R.I.P
Are you holding the throttle about 1/3 down, no choke? If you do get it started hot, does it blow black smoke at first?
Looks like the high today in St Pete was 80F ... my guess would be percolation. Heat from the exhaust manifold (both radiant and conducted by air) toasts the bottom of the carbs, which of course is where the fuel jets are located. If they get hot enough to vaporize some of the fuel, it will blow vapor out into the carb throat and intake manifold, resulting in a very rich mixture.
Few years ago, I went on a club run where we climbed a moderate (6%) grade for a few miles then stopped for a "biology break". Every single car struggled to get started afterwards, you never saw so muck black smoke!
I installed one of Joe A's heat shields, which helped a great deal (but didn't entirely solve the problem). It's been suggested that adding more insulation would help more; my plan is to rig the electric fan so it runs for a bit right after a hot shutdown. Worth noting that MGA and Healey both came with heat shields as original, so the concept is at least period correct :smile:
https://www.the-vintage-racer.com/i...buretor-components/product/33-tr3-heat-shield
I did have to make some small adjustments: the hole for the vacuum advance line wasn't quite big enough for the compression nut, so I opened it up just a bit with a Dremel and mounted stone. A fine rat tail file would work as well.
And the studs were just a bit short with the extra thickness of the shield and an extra gasket. Longer studs would be a better solution, but instead I removed the lockwashers and used some thin lock nuts instead. They work, just barely. (Ignore the extension sticking out, I was actually taking a photo of how to change the starter.)
FWIW, here's what the front carb looked like. The rubber seal for the float bowl was so toasted that the burnt rubber was flaking off.
CJD
If it starts well cold, but not hot...usually a sign of rich. If the floats are good and choke functioning right and not sticking, then try leaning the idle mixture a couple flats or so.
NutmegCT
A naive suggestion, but for years I've heard it works.
If it floods when warm, wouldn't the fix just be opening the throttle 100% (pedal to the floor) to clear it?
Tom M.
pdplot
That worked with a conventional carburetor. Don't know if it would work on an SU or Stromberg. Same with pumping the gas pedal. No accelerator pump.
poolboy
Tom M.
That would open the throttle disc, but I don't think it would make the air valve rise.
PeterK
Had the same problem with my 58. I added a length of Thermotec heat sleeve tubing around the fuel line around the thermostat area to the carbs. Problem solved.
Bayless Onslo the Sprite runs Spridgets 4
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
B TR2/3/3A It runs, again Triumph 3
D For Sale 1955 DAIMLER CONQUEST RUNS NEEDS RESTORATION. Other British Classifieds 1
M Midget runs inconsistently Spridgets 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
F TR6 1975 TR6 runs lean Triumph 11
FlyingCat Spitfire Runs, but not well Triumph 26
B Fuel pipe runs BJ8 Austin Healey 2
D TR2/3/3A Alternator dial runs high Triumph 5
D Its Runs! Spridgets 6
D Lilly test runs Austin Healey 4
C runs better without air cleaners?? Austin Healey 19
KVH General Tech TR4A Runs Terrific Triumph 2
Tinkerman TR2/3/3A It runs! Triumph 8
B T-Series 51 td runs rich MG 17
Gundy Runs a bit...then quits Spridgets 18
HealeyRick Runs a Bit - Then Quits Spridgets 23
K Hard Start, runs poorly when cold Spridgets 10
gbtr6 TR6 Help! Starter runs with ignition in on position Triumph 18
drooartz MGB-GT It runs! MG 6
C Ship deliberately runs aground carrying Jaguars and Land Rovers, but why? Jaguar 0
M TR6 TR-250 CC engine runs great, then nada, wait > 2 days, then runs great again, repeat Triumph 7
B Everything runs better with this mod - all models!!! Spridgets 7
DanLewis Runs on 3 cylinders at idle, but all 4 at higher rpms??? Spridgets 25
D TR6 Blower runs off and on Triumph 4
N Runs Rough Under Load Spridgets 15
Sarastro T-Series It runs! MG 8
R engine runs cool Austin Healey 16
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
martin_burtt TR6 TR6 - runs but no power under load? Triumph 11
af3683 TR2/3/3A Set Static Timing on TR3B - Car Runs Poorly Triumph 27
T She runs! She won't stop running! Triumph 2
C '72 Midget Runs On 2 Cylinders at Highway Speeds Spridgets 73
N After 30 years, it runs! Austin Healey 7
S TR2/3/3A TR-3 hard to start, but runs well once started Triumph 5
G Well, it runs and drives Triumph 5
V Fuel pump runs continuously! Spridgets 18
livinginthepast After a long winter's nap - BE runs around town... Spridgets 7
Wizardd MGB '77 MGB runs for a bit, then shuts down MG 28
bighealeysource BN6 runs rough on restart after running great Austin Healey 7
C My car runs unevenly...... Triumph 4
DART IT RUNS!!!!!!!! Other British Cars 3
jlaird New. She runs but. Spridgets 7
Westfield_XI MegaJolted 1380 starts and runs Spridgets 6
livinginthepast Runs good...starts missing...and then.. Spridgets 10
mikecyc72usa Finally, it runs! Triumph 8
S Jag barely runs in cold weather Jaguar 7
Cottontop ALERT ! Healeys Return to Bonneville Speed Runs Austin Healey 23
