BT7 stator tube
  • Thread starter Deleted member 21878
  • Start date
Trying to fish the wires down the stator tube. What is the trick? I tried to get a rigid no8 wire down the tube to fish the others thru. But I hit something that stopped it.
Healey Nut
If you have an adjustable steering column then the stator tube is a tube within a tube so you are hitting the joint , keep trying or get an electrcians fish tape
Lin
Have you made your wires slightly different lengths? You can remove the bullet connectors and reinstall (crimp or solder) them after the wires are through the tube.
Lin
Small stator tube is out. I am just trying to get a stiff wire thru the long tube. It hits something close to the end or lower part of the tube. Do I need to remove the olive to run this down? Or should I run a fish wire up the tube?
Did you get the tube down through the hole in the front of the steering box? If not, it's likely the tube is misaligned with the hole in the back side of the steering box, and your wire is butting up against the hole. Make sure the tube protrudes from the hole in the front of the steering box. The trafficator wiring should be staggered, so that you can wrap thin wire tightly around the terminals and feed the wire then pull the wiring through.
Is the end of what you're pushing down the column rounded? If you're using a stiff wire, for example, then double back the end about 1"-2" but don't flatten the "eye" completely flat, leave it rounded.
A rounded end is more likely to rise up and pass over an obstruction, rather than to butt up against it.
Twirling the wire is another tactic, using LIGHT pressure to continue pushing.
I spent more than three (>3) decades running wires (from 20-22 ga to 500MCM) so to paraphrase a popular insurance commercial: I know a thing or two, because I've done a thing or two!
steveg
I pushed a length of bailing wire (with a female bullet connector attached) up the tube and used it to pull the stator wires down.
Removed bullets 2 - 4 from stator wire and put heat-shrink tubing around the loose wires. Easy to pull through the tube:
i will try pushing something up the tube later today. just tough with the grill in and i would hate to take that sucker out again.... my lower stator tube does protrude about 3/4" below the steering box. i will try make a little loop on the end of my fence wire.
well i got it. i had to run my wire up from the bottom and hook to my harness. then i braided the wires and covered in shrink wrap. heated up the wrap and pulled them thru. my hub does not quite pull up tight to my steering wheel. appears the boss is not deep enough to let it come all the way in. it may be they want to make sure the blinker switch does not hit the screws? anyway here it is.fullsizeoutput_17a.jpg
Thanks for the suggestions. with this done i was able to connect the battery and see what works.. (new wiring harness) everything worked fine except my tag light and my driving lights. i will chase that down later. should not be too complicated. Now on to getting the windshield in.
Is that, by any chance, a Lempert steering wheel with a Moto Lita hub? Michael Lempert told me he had to machine Moto Lita hubs to fit his wheels.
steveg
That's interesting - I have a Moto Lita hub from 1999 and my Lempert wheels have fit perfectly. Maybe MotoLita changed the design slightly.
Picture 2 above looks like the 3 grub screws in the hub need to be backed out enough to push the trafficator backing plate in fully, then loosely tightened to retain it.
I had the screws out totally trying to push the unit in. The wheel came from AH Spares and the boss came from Moss.
Good story. I ordered the steering wheel Tuesday evening from AH thinking I would get it after Christmas. But it showed up Friday. 3 days from England.. impressive. And the freight was not much more than from a us supplier.
I am going to measure the original boss and see if they are the same depth. It is definitely in the boss that is holding it out.
my backing plate is all the way up against the lip inside the boss. So i either have to make the lip deeper, build the steering wheel out, or leave as is.
bob hughes
Why don't you talk to AH Spares ? Ah just noticed that the hub came from Moss and the wheel from AH spares.
You can not be the first to come up with the problem, unless it is a one off and the steering wheel is incorrect.
In my opinion the best possible solution to your problem - you could make up an aluminium spacer complete with fixing holes that is thicker than the one you have at the moment that bolts the wheel to the hub, done properly it could be a neat answer.
Now considering that you have parts from two different suppliers then probably neither of them would help, an alternative to my first suggestion would be to make a spacer that fits under the wheel, against the hub i.e. kind of building the hub out, the general finish on the flat surfaces would not matter too much as long as the edge was polished up, the bolts would need to be longer possibly.
:cheers:
i did think about building out the wheel either by a spacer behind the wheel or by a thicker front one. also measured the original wheel to the flat part the backer plates sits against. it is about an 1/8 to 3/16 deeper. Not really an AH spares issue. the problem is in the boss. Moss says it works with this wheel and they actually the cover plate with the kit. i will check with them to see if they have any suggestions.
John Turney
Are you sure the tube of the back of the trafficator isn't bottoming in t slot in the stator tube? That happened to me a I had to extend the stator tube more out the front of the steering box.
i thought the small tube went inside the lower tube? but i also measured the distance to the lip the backing plate will hit. i am pretty sure it is in all the way... as far as it will go anyway.
steveg
DD - Following John T's thought...
For grins, why don't you loosen the olive nut on the front of the steering box and pull the stator tube about 1/4" toward the front of the car and see if your trafficator then seats properly.
The steering wheel and its outer ring have nothing to do with this issue - it's all about the relationship between the trafficator and wheel hub. From your pic, the wheel clearly bolts up to the hub properly.
What I wonder is how could Moss be selling a hub that doesn't fit a standard trafficator - just don't see that happening.
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut For Sale BJ8 and BT7 parts for sale Austin Healey Classifieds 62
CLB62 1962 Austin Healey BT7 Mk II Austin Healey 15
F Heater pipe and air duct routing BT7 Austin Healey 3
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
F Help need reinstating my heater - BT7 Austin Healey 7
