BJ7 end couplings for fuel line
Roberte
Member
Ineed to replace my fuel line and perhaps it is cheaper to purchase tubing locally than the $115.00 Moss price. However I would need the end couplings attaching to the pump and the end connecting to the tube leading to the carbs.
Any info on size of tubing needed and where couplings are available would be appreciated.
Thank you,
Robert
RestoreThemAll
Speak with David at the British Car Specialists. It is a special fitting.
RestoreThemAll
Also, Classic Tube will make you up some pre bent lines.
steveg
You could purchase a 25 ft roll of 5/16" cunifer or steel tubing inexpensively on Amazon or from FedHill trading. Cut off the banjo fitting at the pump, leaving enough for a stub. Use 5/16" ID fuel rubber hose to connect the pump to the pipe and the pipe up front to the carb connection.
gonzo
The BJ7 squared body fuel pump accepts female fittings for input and output - so no banjo fittings here. Creating a new steel and/or cunifer fuel line to run the length of the car from fuel pump to inner left fender of engine compartment is a good idea; however to properly connect the rubber fuel lines to the pump, a barbed, banjo-type or similar fitting is needed. Knowing the fitting's specs to properly seal to the fuel pump is a challenge. Is it an AN-type fitting? GONZO
Tompol
Hi guys,
I'm going to reuse original fittings and 5/16" Cunifer line, the only problem is how long is the line for BJ8 going from the fuel pump to the front carb hose.
My original line consist of terribly spliced pieces of steel lines and rubber hoses, total mess and fire hazard impossible to measure even approximately.
Any information about the line length will be greatly appreciated.
Tompol
Great suggestion Steve, I still hope somebody did it or doing lines a have a measurements. Maybe someone has lines before installation and can measure it?
Soon I will have to figure out the length to be able to braze original couplings on.
Thanks again
B BJ7 back end rebuild Austin Healey 1
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
W For Sale Hardtop for BJ7/BJ8 on BaT : No Reserve Austin Healey Classifieds 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
