TR2/3/3A "56 TR3 Engine Verification
Moosca
Hi, I'm trying to figure where I can get a list years of engine numbers to see if numbers match. Right now I am looking at a 1956 small mouth, with an engine number of TS10516E, looks like that may fall into the range for that car which is TS10175 L. Thank you for any help.
Geo Hahn
Those numbers (engine number slightly higher than commission number) are very typical and the difference (engine 341 greater) sounds very likely to be correct/original.
But 'very likely' is the best you're going to get short of ordering a build certificate for the car: https://www.britishmotormuseum.co.uk/archive/heritage-certificates
The issue is that engines were not necessarily used in numerical order so the difference in numbers varied. The spread itself occured because Triumph sold some engines outright and also sold engines to Morgan for use in their cars - both adding to the difference in the numbers.
Moosca
Moosca
Thanks, this car appears to be very original, so the engine is probably too. Thanks for the quick response!
TR3driver
Great Pumpkin - R.I.P
FWIW, TS13571L originally had (and still does) TS13986E
Moosca
Moosca
Thanks, how about a 1960 TR3 TS54596LO with Engine #TS 52216E? And where can I locate a list of these numbers?
Thanks!
Geo Hahn
There is no list that I know of.
But there are registries and such that show the commission numbers and engine numbers for some of the cars. These can at least show you what some near-by cars had in the way of number combinations.
Here's one: https://www.trregistry.com/start/registry/html/
Of course not all entries show engine numbers, some entries may have had their engines replaced and even with the accurate numbers the spread between the two numbers will vary quite a bit because engines were not used in strict numerical order.
For example - here is a nearby entry that shows a comparable spread to the numbers you mention:
https://www.trregistry.com/start/TR3/reports/indivdata.php?vin=TS54270LO
Also note that is a '1959' whereas the one you ask about was a '1960'. Model year didn't mean much back then and was typically the year the car was first registered - irrespective of when it was built. Many TR3As (esp in the year 59 & 60) carried over to the following year before they were sold & registered.
Moosca
Moosca
Thank you very much. So I understand the LO means overdrive. Where would the OD switch be located? Yes, I am new on these early TRs. I've owned one Spitfire and three TR6's but all the switches would have been located on the shift knob, I'm not sure with this car.
TR3driver
The 'L' is for left-hand drive (steering wheel on the left), only the 'O' indicates factory overdrive. The OD switch should be to the left of the steering wheel, with a rather large tear-drop shaped body and a smallish toggle sticking out the front of it. You can kind of see one in this shot
However, a lot of things can happen in 58 years. You may find the switch missing, or even the entire overdrive.
TR3driver
Can certainly be done, but not simple. To get somewhere close to right (like an automatic transmission) would probably require a microprocessor with information on throttle position, manifold vacuum, rpm, etc.
You can buy logic devices that will, for example, automatically disengage OD when you change gears, but that doesn't seem useful to me. I often just leave the switch on when I'm just puttering around town, so it only takes 3 shifts to get into top gear.
Moosca
Moosca
Thank you sir, this gent says the set it up so that it automatically engages, so maybe he bypassed the switch, kind of like leaving the switch on?
Geo Hahn
The other issue with that is how the system (whatever it is) would know when you wanted OD. Overdrive isn't just for high speed driving, it also provides useful gearing such as 3rd gear OD which often ideal for twisty mountain roads.
In varying city traffic (e.g. freeway slow-n-go) you may want to switch back and forth between 3rd to 3rd OD in lieu of the 3-4 shifts in a standard gearbox.
Geo Hahn
...maybe he bypassed the switch, kind of like leaving the switch on?
May have - but you don't want to do that. Usually it would be harmless as the lock-outs on the gearbox cover would prevent the OD from engaging in 1st or Reverse -- but the penalty for allowing that to happen is high enough you do not want to solely and always rely on those lock-outs.
Moosca
Moosca
Thank you, If it is wired this way, what would be the simplest way of disabling the OD until I get it figured out? Is the a fuse?
TR3driver
Hard to say without seeing what has been done. The original setup did not involve any fuses, but it would fairly easy to disconnect at the relay on the back of the battery box (under the dash).
There are other "automatic" setups; I believe AH originally used a system where the OD would engage when you let off the throttle at a fairly high rpm (or maybe it was high manifold vacuum); then disengage when you change gears. I don't know if there was a way to override that when, for example, 3rd direct is a little too tall for a twisty mountain road, but 2nd direct is too low for the straightaways.
jfarris
I also have a 56 TS10193L with engine TS10543E.
I haven't seen anyone mention that engagement of the OD in reverse gear with ultimately break the weakest link in the OD/transmission.
TR3driver
More accurately, moving the car backwards with the overdrive engaged will cause damage. This is true even if the gearbox is in 4th gear and you are, for example, rolling backwards down a hill.
Normally the OD is automatically disengaged in reverse by the action of the lockout switches; but there are various possible faults. So if you ever start to backup and feel some resistance (feels kind of like trying to back over a curb), DON'T FORCE IT! Find and fix the problem, or if necessary call a tow truck. Even a tow is lots cheaper than repairing the OD after the sprag clutch has come through the rear housing.
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
Pool Dad 1960 TR3 engine serial number Triumph 14
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
W TR2/3/3A Novice TR3 Engine Rebuild Triumph 47
J TR2/3/3A TR3 engine build Triumph 12
doc50 TR2/3/3A How to verify TR3 engine numbers Triumph 20
6 TR2/3/3A Engine in my TR3 Triumph 15
M TR2/3/3A TR3 engine hood wanted Triumph 7
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
Kleykamp TR2/3/3A TR3 lower engine parts?? Triumph 2
Got_All_4 TR2/3/3A Tr3 engine trany pull Triumph 6
Brinkerhoff TR2/3/3A TR3 free engine parts to forum members Triumph 6
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
Kleykamp TR2/3/3A TR4 engine into TR3 crankcase vent tube? Triumph 16
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
mt10flyer TR2/3/3A 1959 TR3 engine rebuild problems Triumph 14
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
5 TR2/3/3A TR3 engine building tips needed Triumph 5
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
D TR2/3/3A tr3 engine Triumph 6
H TR2/3/3A Cant get my Tr3 engine to start. any advice? Triumph 29
V TR2/3/3A TR3 Engine Noise Triumph 33
NutmegCT TR2/3/3A TR3 engine question Triumph 6
MGTF1250Dave TR2/3/3A Questions about Breaking in a refreshed TR3 Engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
O TR2/3/3A TR3 Engine Miss Part 2 Triumph 11
O TR2/3/3A TR3 Engine Miss Triumph 5
K TR2/3/3A TR3 Engine block marking? Triumph 4
G TR2/3/3A TR3 Rear engine seal issue Triumph 13
T TR2/3/3A TR3 engine ground Triumph 9
O TR2/3/3A TR3 engine removal Triumph 5
Bremer TR2/3/3A Hypothetical: Big bore TR3/4 engine Triumph 13
MGTF1250Dave TR2/3/3A TR3 Engine Noise Identified Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
MGTF1250Dave TR2/3/3A TR3 Engine Noise Up-date Triumph 11
C TR2/3/3A tr3 engine numbers Triumph 23
MGTF1250Dave TR2/3/3A TR3 Engine Hoisting Fittings Triumph 5
MGTF1250Dave TR2/3/3A TR3 Engine Noise Triumph 26
T TR2/3/3A TR3 floor replacement. Engine in or out? Triumph 3
K TR2/3/3A TR3@70mph engine seemed to "flatten out" or..... Triumph 10
A TR2/3/3A TR3 engine removal Triumph 9
GBRandy TR2/3/3A TR3 Engine Bay Color Triumph 5
