Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Death by Electrocution
  1. #21
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    905
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Re: Death by Electrocution
    A source for an appropriate sized pulley is a electric motor repair shop. When putting an alternator on my TR4 I had a repair shop rebuild a unit for me. At the owners suggestion he provided a smaller diameter pulley so that the unit spins a bit faster. He had several sizes available to fit the wide belts we use on our cars.
    Charley
    Charley
    1962 TR4
    1963 TR4
    1959 TR3A A work in progress.
  2. #22
    Join Date
    Oct 2011
    Location
    Wellington New Zealand
    Posts
    79
    Thanks Thanks Given
    Thanked in
    Just bought an ASE pulley. It's sent to Portland Oregon then shipped by NZ Post to Wellington New Zealand, so thankyou to whomever suggested it. All I've got as a reminder was a shortcut on Chrome.
    I just have to go over all my notes re wiring. My mechanic owes me a favour as I did an IT job for him so I'll get him to buy me an alternator with the correct shaft diameter.
    Jim
  3. #23
    Join Date
    Oct 2017
    Location
    Park City Utah
    Posts
    5
    Thanks Thanks Given
    Thanked in
    Hi All,
    I just wanted to post my final update on the electrical mystery that began 9 days ago...To quote Gene Wilder in "Young Frankenstein" IT LIVES, IT LIVES' yes, I finally got to what appears to be the bottom of it and it turns out that both the ammeter and the control box were fried, which one was first I'm not sure, but I'm guessing it was the control box. (the strap on the A terminal became a "fused link" wether it liked it or not.) I'm guessing it had a lot to do with the ammeter and the control box being 56 years old. After replacing both, checking connections and grounds. (finding many were loose or having poor connection) all now works, including gauges, lights and all devices I see so far. You guys really helped, and I learned a lot about British wiring and Lucas (the God of Darkness), much of which I shall no doubt use on this and other cars around here.
    Cheers,
    Rob
    the "Other cars:
    1968 Land Rover 2a "Bug Eye"
    1967 Mini Cooper S
    1964 356 C Porsche Coupe
    1966 Toyota Land Cruiser FJ45 pick up
    1967 VW Type1 Sunroof
  4. #24
    Yoda Geo Hahn's Avatar
    Join Date
    Sep 2001
    Location
    Mt Lemmon, Arizona
    Posts
    9,204
    Thanks Thanks Given
    4
    Thanked in
    Quote Originally Posted by TRrover View Post
    ...To quote Gene Wilder in "Young Frankenstein"...
    Or the original...
    Either way, it is a great feeling to get that sorted without fire & smoke.
  5. #25
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    905
    Thanks Thanks Given
    Thanked in
    [QUOTE=TRrover;1069316]Hi All,. You guys really helped, and I learned a lot about British wiring and Lucas (the God of Darkness), much of which I shall no doubt use on this and other cars around here.
    Cheers,
    Rob
    Rob,
    Actually as I understand it Lucas is only "The Prince of Darkness". Think how much more trouble we would be in if he were actually a God.
    Charley
    1962 TR4
    1963 TR4
  6. #26
    Join Date
    Jul 2017
    Location
    Hiawassee, Georgia
    Posts
    6
    Thanks Thanks Given
    Thanked in
    Hi All,
    Cheers,
    Rob
    I would be concerned that you haven't yet found the cause. The damage to the control box and ammeter could only be caused by excessive amperage where something shorted to ground. If I were you, I would trace all of the wires and look for a sporadic short someplace. One of my TR3s once had a short in the wiring to the tail lights. I would occasionally hit a bump in the road and it would short out and the area where the short was occurring was not obvious.
  7. #27
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,216
    Thanks Thanks Given
    2
    10
    Thanked in
    Quote Originally Posted by glcaines View Post
    I had a similar problem with my previous TR3A. One strand of wire had broken at a bullet connector and was sticking out underneath the sleeve. Hit a bump, and it would touch the body underneath, shorting out the headlights. In my case, it was the headlight switch that acted like a fusible link and opened up first (although not until after a lot of wiring insulation has melted).
    Randall
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
