Results 1 to 8 of 8
Thread: Gasket Sealer on Intake/Exhaust Manifold Gasket.
  1. #1
    Join Date
    Dec 2012
    Location
    Jersey Shore
    Posts
    102
    Chats
    Doing some winter project work. Pulled the intake and exhaust manifolds off and found that when a previous repair was made, the mechanic used gasket sealer on both sides of the intake/exhaust manifold gasket. Not under my ownership.
    I was planning on reassembling with a new gasket, but have never used gasket sealer on my TR6 i/e manifold gaskets.
    Doesn't seem to be a reason for it, any suggestions or opinions appreciated.
    Thank you.
    Thanks,
    Bill
    1975 Triumph TR6 & 1962 Austin Healey 3000 BJ7
  2. #2
    Darth Vader Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    2,686
    Chats
    Re: Gasket Sealer on Intake/Exhaust Manifold Gasket.
    Bill--
    It may not be necessary but it can't hurt. I use Ultra-copper for high-heat applications such as this.
    Best--Michael Oritt
    1954 Austin-Healey 100 Lemans
    1958 Elva Courier
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  3. #3
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    5,638
    Chats
    Strictly speaking... I believe use of sealant on the manifold gasket is discouraged. However, on my Triumph engines I have used sealant on the manifold gaskets. That is because my Spitfire and GT6 have/had aftermarket headers that I could never dress flat.
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
  4. #4
    Jedi Knight dougie's Avatar
    Join Date
    May 2008
    Location
    Portland, Oregon
    Posts
    1,355
    Blog Entries
    1
    Chats
    Quote Originally Posted by BG 62AH View Post
    Thank you.
    I use Locktite Copper Hi-Temp gasket spray https://www.amazon.com/Loctite-37583.../dp/B003XZARRK on both the exhaust and intake manifold on my race motors. It makes a solid seal and allows for easy removal.
    Dougie
    '65 BJ8 3000 MKIII GN.29
    '57 100-SIX MM Vintage Racer GN.1 #414
    Team Healey PDX
  5. #5
    Join Date
    Dec 2012
    Location
    Jersey Shore
    Posts
    102
    Chats
    Guys, thank you. In reflection I like the idea of using a high temp sealer. Appreciated.
    Thanks,
    Bill
  6. #6
    Jedi Trainee red57's Avatar
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    329
    Chats
    In the late '60s when I was taking a vo-tech auto mechanic class I remember specifically being told not to use gasket sealers on these type gaskets - the asbestos-type side bonds to the head and waffled metal side is supposed to allow a small amount of movement/slippage due to the differing expansion rates of the head and manifold. So, I have always installed them dry.
    Doing a little quick research I found the Moss has developed their own gaskets for their supercharger kits and specifically say leave them dry.
    Fel-Pro site also specifically says to install dry.
    Not too sure it makes a huge difference but thought I'd throw it out there. I think you have been doing it right all along.
    Dave
  7. #7
    Join Date
    Mar 2003
    Location
    Hampshire in the UK
    Posts
    1,533
    Chats
    Not required really
  8. #8
    Join Date
    Dec 2012
    Location
    Jersey Shore
    Posts
    102
    Chats
    I appreciate your help, thank you.
    Thanks,
    Bill
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
