Off Topic Photobucket Fix
Geo Hahn
I just learned about a Photobucket fix that appears to work. You can edit you prior posts with blocked Photobucket pics and add '~original' after the 'jpg' in the URL.
Now the URL within the
will read like this: https://i1214.photobucket.com/albums/cc499/Ahwahnee18/TR4/ODDiode.jpg~original
I just tried it on this thread and my photos reappeared:
https://www.britishcarforum.com/bcf...olenoid-rubber-boot&highlight=overdrive+diode
Sometimes I try to reference a prior post I have made and run into the Photobucket ransom demand - this at least lets the original poster clean that up.
NutmegCT
George - that's a great work around. Where'd you find the idea?
It seems to work only if done by the original Photobucket owner of the image, but at least the owner can make the photos visible. I wonder if viewer of a post can see the image, by copying the image url and adding ~original.
(Wonder when Photobucket will block this work around too ...)
Tom M.
Geo Hahn
Geo Hahn
The idea came from a VW forum which got it from another forum, etc.
It seems to work only if done by the original Photobucket owner of the image, but at least the owner can make the photos visible. I wonder if viewer of a post can see the image, by copying the image url and adding ~original...
Possibly not. I tried modifying the URL from Randall's photo in that same thread but could not get the PB photo to appear.
Edit: Okay, it seems it does work if you are getting the usual PB block image:
But not if you are looking at the one with the cat:
I do not think that the original PB used has to be the one who makes the change - but certainly on BCF the original poster (or a mod) are the only ones who can do it.
TR3driver
Great Pumpkin - R.I.P
My apologies for the confusion. In that particular case, I discovered that I made a mistake when installing the diode. I still believe the concept is sound, but the way I wired mine won't do any good. So I deleted the photo. I thought I had explained why, but somehow didn't do that. So with the photo no longer on PB, pretty much nothing anyone does will make it appear.
Good tip about the ~original; but I have a suspicion they will discover and block that loophole eventually as well. So I plan to continue slowly abandoning PhotoBucket and moving to Imgur (until they make the same decision, of course). If you want, you can look through what I've done so far at https://tr3driver.imgur.com/
Or if you find a particularly interesting post of mine without photos, let me know and I'll fix it.
NutmegCT
In my innate paranoia, I'm thinking it's not long 'til we find ourselves having to pay extra for a *lot* of 'net things we're becoming used to - and dependent on.
:gloom:
CJD
I have no problem paying for services...so long as it's reasonable. PB charging $400 for the privileged of linking pics is just a bit steep.
3798j
Bronze
Found this on another forum that I hang out on:
"If you're using Google Chrome, go to the three dots on the right side of the screen and click them. A drop down should appear. Hover your mouse over "More Tools," and when the next drop down appears, click on extensions. Go to the link towards the bottom that says "Get more extensions." In the search box, type "Photobucket Fix," and hit enter. Click the install button and once it's done, you should be able to see photobucket pictures again.
For FireFox users, click on the three bars on the right side of the screen, then click on add ons. Click search for "photobucket hotlink" and click install. Same result."
I'm a firefox user...it worked perfectly.
NutmegCT
Jay - I just installed it. Not sure how it works yet.
Does it let me post a link to a Photobucket photo so everyone can see it?
Or does it just let me see other people's Photobucket photos?
Thanks
Tom M.
3798j
Bronze
Sorry Tom, I didn't explain this "fix". It allows one to view photobucket photos on forums...not to post them.
NutmegCT
Thanks Jay. The developer didn't give details either.
Can you point me to a post with a Photobucket photo so I can test?
Thanks.
Tom M.
3798j
Bronze
Haha Tom...I did nothing (other than to pass it along). It was from a poster on britbike.com who then passed it along to garagejournal.com...where I saw it.
NutmegCT
Jay - you might want to start a "Photobucket" thread in Pub, linking to this Triumph thread. Lots of folks might be interested in learning about this fix.
Tom M.
ghawk16
Yep...I downloaded that link into Chrome a couple of months back and now I can see the Photobucket pics. Glad someone was able to find that link cuz I forgot where I saw it. Must be the same forum I hang out on! Or...it's just getting around! HAHA
D photobucket image help FORUM Navigation Questions 2
PAUL161 Photobucket users Restoration & Tools 1
CJD General TR Photobucket Triumph 46
M uploading photos from photobucket. Triumph 1
TimK Using Photobucket.com to post photos on BCF Austin Healey 2
O testing photobucket Triumph 12
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tr6nitjulius General TR DYI don't park on bare concrete fix Triumph 1
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
T TR6 Carb. Float Chamber Fix Triumph 5
A TR2/3/3A how do i fix this hood line? Triumph 5
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
UmmYeahOk GT6 What do I need for a speedometer fix? Triumph 16
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
W radiator spigot fix Austin Healey 11
K TR2/3/3A Rebuilt steering has creative fix for NA worm bearing! Triumph 4
Scotsman TR4/4A How to fix sagging rear end. Triumph 8
M_Pied_Lourd TR2/3/3A The Newest Bug to Fix...Now with Video! Triumph 43
M_Pied_Lourd TR2/3/3A The Newest Bug to Fix... Triumph 15
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
Joe Reed MGB Another easy fix....upper radiator bracket MG 5
P MGB Vinyl window scratch/haze fix ? MG 3
S TR2/3/3A green fiberglass fix it stuff Triumph 9
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Elva164 Help me fix the Cortina! Lotus 9
W Emergency rotor fix Austin Healey 2
mailbox General Tech Fix, replace or rewire? Triumph 8
J Finally a fix for the SU pump Austin Healey 5
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
DanLewis Would a Panhard bar fix this problem? Spridgets 11
Mink TR4/4A Help me fix my reverse lockout... Triumph 3
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
R Smitty Speedometer Cable Fix Austin Healey 1
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
J TR6 looking forgood shop to fix my tr6 Triumph 2
X don't fix it if it ain't broke Spridgets 1
R Fix The Austin 1800 Other British Cars 10
K Clutch fork fix Re: the 1/4" bolt repair. Triumph 10
H sloppy shock arm fix Austin Healey 4
S How to fix Vapor locking from happening Triumph 42
tinman58 TR2/3/3A Tr3 trans fix Triumph 3
Xte How to fix my new BJ8 SS exhaust system ? Austin Healey 5
regularman What is the permanent fix for rear wheel seals Spridgets 14
regularman I found the fix for the stromberg on the 1500 Spridgets 6
bighealeysource ideas on how to fix dents on frame Austin Healey 15
L Simple fix for leaky tappet cover Austin Healey 0
