MGC What are these connection wires?
69MGC
Hey guys
Started to remove my damaged battery box and discovered these connector, not connected to anything.
Anyone have any idea what they go to? The lead into the bat box. Could have something to do with the batteries (doesn't seem likely) they could have been put in there by the previous owner. Who knows! This car has seen some hard times.
Thanks for your help.
Kev
Mickey Richaud
Hey, Kev -
First guess is maybe a battery trickle charger/tender. Any idea where they go from there?
Mickey
Mickey Richaud
Platinum
Yup. Original fuel pump wires, Black ground, white, as power. Looks like they were stuffed in the battery box to get 'em out of the way. Odd "fix" to just run another wire rather than find out what the problem was.
Platinum
D Water Valve Connection Austin Healey 4
Sopwith_Camel MGB missed connection MG 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
T TR6 Air vent rod connection Triumph 1
D 62 tri-carb fuel line connection Austin Healey 10
S TR2/3/3A clutch pedal connection hole Triumph 9
D TR2/3/3A Main ground connection Triumph 2
B Outer steering column connection to the steering box Austin Healey 6
warwick-steve Rear Brake cylinder connection Austin Healey 12
D TR2/3/3A Vacuum connection at Carb Triumph 23
I Spitfire 78 spitfire carb connection help Triumph 8
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
F What to do with breather pipe as my new air filters have no connection for one? Austin Healey 31
K TR2/3/3A Remote starter to alternator connection.... Triumph 10
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
C Overdrive throttle switch rod connection picture Austin Healey 3
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
J 1/4" BSPP Fuel Line Connection, Hose from Steel Line to Carb Austin Healey 2
M ignition coil high tension lead connection Spridgets 10
germanmichel BT7 Steering Box - Tube connection Austin Healey 3
Lukens TR2/3/3A Petrol pipe connection to tank. Triumph 9
R TR2/3/3A TR-3 Fuel Tank Outlet Connection Triumph 6
rggav female 1/2-20 to 5/16 hose barb for fuel line connection MG 5
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
M Fuel Line to Tank Connection Question [pics] Triumph 2
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
B BN7 Fuel tank/line connection Austin Healey 3
W help identify a wire connection Triumph 5
M Connection the Engine to Gearbox [pics] Triumph 27
af3683 Choke Cable Connection to Rod Assembly Fork Triumph 7
johnrip Wedge TR7 pacesetter header connection to stock exhaust Triumph 2
richberman brakes line connection question Austin Healey 18
W HIF44 carb... throttle cable connection Spridgets 9
R ARP head and connection rod studs? Spridgets 15
davester Loose manifold to exhaust connection MG 3
JPSmit Family Connection Spotted Spotted 1
Norman Throttle connection Austin Healey 2
D TR6 Looking for some TR6 wiring connection info Triumph 15
Westfield_XI Denso alternator connection question Spridgets 5
drooartz Choke cable connection? Spridgets 8
D Spitfire Elec wire connection for wiper - 71 Spitfire MkIV Triumph 1
texas_bugeye Alternator Connection Spridgets 1
Nelson Choke cable connection? Spridgets 5
jdubois TR2/3/3A TR3A fast idle cam connection? Triumph 26
19_again choke connection 67B MG 9
George Zeck Turn Signal Light Bulb & Connection ..... Spridgets 1
19_again connection at water temp gauge MG 7
DART Speedo to Trany connection Austin Healey 2
bluemiata90 TR2/3/3A TR3 OIL PRESSURE LINE CONNECTION---HELP Triumph 4
R Coil connection question Spridgets 22
