How to undo a flange nut..?
Ian R
I'm trying to renew the oil seal on the front of the differential but I cant undo the flange nut.
I've tried a breaker bar with a length of tube to extend the leverage and I've tried an impact gun.
Has anyone got any suggestions how to undo it..?
What size impact driver? A 3/4" would probably work @ 90PSI or higher; otherwise, you need a longer breaker bar or tube. It it's rusted on, penetrating oil and a little heat should help.
I
Ian R
I only have a 1/2" impact wrench. No sign of any rust...I've had a breaker bar with a 3ft scaffold tube on it but was reluctant to give it too much grunt in fear of breaking something...(the diff that is..not part of me..!).. I've tried a little heat on the nut but am unsure how much I can heat it without cooking something...
The only thing you'd cook would be the seal but, presumably, if you have the nut off you'd put in a new seal on principle. Penetrating oil, heat and your impact wrench cranked to 11 should do it.
gonzo
Impact driver on removal, but on install would it be necessary to set a preload. Could this be achieved by indexing the nut with flange before starting, followed by tightening nut to match index on install. Or, alternatively set nut to a torque value? GONZO
red57
Gonzo,
Not necessary to worry about bearing preload - that is set with spacer and shims like front wheel bearings. These do not have the "crush sleeve" that American cars mostly have. Just tighten the S**t out of it (I am not aware of a torque spec but the last time I had a dif. set up the old pro said about 150#).
Dave
twas_brillig
try lots of penetrating fluid. If you can borrow or rent a 3/4" impact (and appropriate socket), that is best.
A small story: about 20 years back, we'd bought a used car and I dragged my 18 year old son out to help break the wheel nuts loose (over his 'why' objections) . I had an el cheapo 1/2" drive impact that got most of them off, plus borrowed a 1/2" Ingersoll Rand impact; etc. etc. etc. The final wheel nut did not want to come loose. Dan (my son) was over 200 pounds at the time, and we put him on the end of my unbreakable Craftsman socket and unbreakable Craftsman breaker bar and a five foot snipe (i.e. we're at least 1000 foot pounds of torque here) and he climbed on the end of the snipe and bounced and... the socket broke. Replaced the unbreakable socket with an impact socket, and we got it off - he figured the old man wasn't as crazy as he appeared.
Try heat; try penetrating fluids of your preference; order a new main seal as you'll need it anyway. And whenever you get work done that means the wheels come off - or buy a used car - take off the wheel nuts and torque them properly, as even road side assistance couldn't have gotten that last #$%^&* wheel nut off. Doug
bob hughes
Ian - If you are working from the top with the Wheels (handbrake engaged and in gear for belt and bracers) on the ground, there should not be a major problem, I used a 4' breaker bar on mine with an extension bar into the tunnel and it worked a treat. It is doubtful that you would break anything.
:cheers:
I
Ian R
Done it..!
Soaked in penetrating fluid overnight, borrowed a better quality impact gun & cranked my compressor up to the max.
Thanks to you all for your input.....
bob hughes
Ian
Now you have to find a torque wrench to do it up again, unless you have one already :congratulatory:
Though you could use that impact gun that you borrowed - are they controllable ? I have no experience of them.
:cheers:
I
Ian R
Ian
:cheers:
Mine only go upto 120 lb.....luckily my neighbour lends me engineering tools and I lend him construction tools...fair exchange...!
R General TR Spring collar flange thickness options Triumph 2
M Spitfire Triumph spit flange/hub removal Triumph 13
glemon General Tech Differential flange removal Triumph 11
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
steveg Side Curtain Flange question Austin Healey 5
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
K TR2/3/3A TR3A top cover to mounting flange "strap"? Triumph 10
jsfbond Flange bent? Triumph 6
Andrew Mace Post-War Other Herald: thoughts on manifold flange studs and nuts Triumph 5
Bob_Spidell Exhaust Flange Gaskets Austin Healey 8
TR4nut TR2/3/3A Question on reinstalling pinion flange on TR3A Triumph 8
E BE axle flange hub screws Spridgets 7
C Need Info on air intake flange for midget mkII 65' Spridgets 5
Tinkerman Rear tranny flange retaining nut removal. HELP!!! Triumph 8
M UH OH! Pinion flange nut? MG 6
I rear axle to differential flange bolt grade? Triumph 8
newmexTR3 TR2/3/3A TR3A Exhaust flange gasket tips Triumph 8
DeltaAir423 Anyone have a pinion flange wrench? Restoration & Tools 7
vette Trans Tunnel Floor Flange Austin Healey 3
RickB Exhaust flange blew out again this morning MG 33
RickB Exhaust flange blowout on way home from work MG 6
eschneider Help! Stainless exhaust flange needed Restoration & Tools 1
Baz Exhaust flange Spridgets 15
prb51 TR2/3/3A TR3 drive shaft flange issue Triumph 1
A Exhaust Flange Spridgets 3
6 rear axle flange bolts Triumph 4
jerrybny Yoke flange question Triumph 2
Jake Axle flange MG 3
T Help removing the rear drive flange Triumph 2
guzzul Spitfire Help! Spitfire 1500 exhaust flange studs broken. Triumph 16
B MGA Where to Buy, What to Buy? Axle Nut MG 8
C Steering Arm Castle Nut Torque Austin Healey 5
R Vixen 2500 Lug Nut Size? TVR 5
B General MG Crankshaft Nut Removal MG 4
drooartz Modifying castle nut Restoration & Tools 3
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
G Stator Tube Nut and Olive Austin Healey 9
dbenichou289 TR2/3/3A Shifter knob jam nut Triumph 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
jfarris TR2/3/3A Castellated nut on the pinion Triumph 9
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
AN6-TX Hex Nut 2BA? Austin Healey 4
