The Prince of Darkness on the dash board finally conquered
bob hughes
Guys
I have been working over the past couple of years to illuminate the instrum:cheers:ents in the dash with LEDs. The Speedo and the Rev Counter were the easy ones using wedge type LEDs and wedge bulb holders. The fuel gauge and the oil and temp gauges were the difficult ones.
I manufactured a cap with a 2 inch hole in it to go over the fuel gauge and installed an LED lighting strip inside it. My earlier thread showed the result of all that, albeit very bright due to the camera work.
Today I finalized the work on the oil and temp gauge. I used the same idea of a cap but had to cut a slot in the edge of it to allow the cap to go over the oil and water lines first. I installed a hinged 'gate' on this one to close the slot once it was over the back of the gauge, worked a treat.
I now have all the gauges glowing nicely in the dark with the two on the outside showing a delicate shade of blue - Mmmmm nice!
The indicator light is so bright that you can see it in broad daylight - handy 'cause the noise from the indicator relay is so faint it is lost in the roar of the engine. :wink-new:
:cheers:
steveg
Guys
:cheers:
A picture's worth 1000 words!
B
bob hughes
Steve
I would post a picture but I can not straight from my computer, I have fallen out with Photobucket since they have started charging so I need another method.
:cheers:
NutmegCT
Hi Bob - I clicked that link, but it only works if you're signed in to Google Photos (so most of us probably won't see the photo).
Why not upload the photo directly to your post -
Click Reply. Above the Reply box, you'll see a row of icons. Third icon from the right is a square. Click the icon and you'll see Insert Image. Choose From Computer, then Choose File, then Upload. Once it appears in your reply, double-click the image if you want to make it larger.
Voila!
Example:
steveg
Here are the uploading steps to large picture at bottom of post. Click on the "Insert Image" icon (Insert Video is next icon to the right):
Select your pic and upload:
Double-click pic for this:
Select size and click "OK":
Voila!:
This is a test:
B
bob hughes
Thanks Steve
Read your PM before checking post. This is the Ring/cap with a strip LED installed inside, around the edge, The 'gate' is open ready to install it over the instrument. I am trying to get a representative image so that the effect can be seen correctly, my earlier images were too bright and not representative of the real thing.
:cheers:
B
bob hughes
Even more success - ish
Much better than my attempt when I had installed the LED in just the fuel gauge. The lighting is more subdued and represents the real thing - almost.
:cheers:
NutmegCT
Bob - congrats on the lighting work. It's hard to tell brightness from a photo (as cameras and phones these days often adjust bright and dark automatically).
Are the two outer gauge faces actually that much brighter than the two inner gauges?
Thanks.
Tom M.
B
bob hughes
Nutmeg
Not really I think that it is the difference in the colour that makes it look that way, the speedo and the rev counter also look the same in reality but they there appears to be a difference between them in the shot.
:cheers:
H Lucas Prince of darkness Austin Healey 4
B Prince of darkness conquered in the cockpit Austin Healey 17
D Thwart off the Prince of Darkness.... Spridgets 17
bthompson The Prince of Darkness strikes again. Spridgets 8
C The Prince of Darkness strikes. MG 4
lbc_newbie More fun with the Prince of Darkness Spridgets 9
davester The Prince of Darkness strikes! Dead starter MG 15
JPSmit The Prince of Darkness strikes again Spridgets 5
ooman About the Prince of Darkness... Austin Healey 1
Webb Sledge The Prince of Darkness Finally Strikes Triumph 15
Nunyas The Prince of Darkness stikes once more... MG 9
jaybird The Prince of Darkness... MG 7
MGTF1250Dave Lucas, the Prince of Darkness MG 20
D Prince of Dimness Spridgets 4
HealeyRick Prince Charles Had A Healey? Austin Healey 7
F Prince of Daarkness Spridgets 18
Jim_Newman The 'Prince" has struck Austin Healey 16
G The Prince of Darness has struck MG 13
C The Prince has found me Triumph 10
19_again The Prince lives on MG 14
LuckyLuke Protection for the Pince Lucas of Darkness Austin Healey 21
C Curse from the price of darkness. Spridgets 12
Hegg Lucas, the Pince of Darkness, and my Elan +2 Lotus 10
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
