Overdrive question..?
Ian R
Are all A Type Laycock overdrives the same and fit a 100/6.
The BN4 I'm restoring has had its overdrive removed for some reason and a
non overdrive box put in. I would like to change it back.
Healey 100
You will have to change the complete transmission with another one that includes the OD. I believe the main shaft on the non-OD tranny is quite different from the OD version, so it is not a matter of just adding an OD to back end of your non-OD transmission.
Years ago I did change another 100/6 with a non-OD transmission. It was not difficult and it worked OK. But it is harder today to find a rebuildable 100-6 transmission with an OD.
PS you probably have one of the non-OD Healeys that were built that way from the factory, there were some. I understand these came with a lower numerical rear axle which is a plus whether you make the conversion or not.
British_Recovery
Bronze
Gearboxes can be swapped, but adding an overdrive to your existing 'box would require additional modifications. The main shaft, for example.
John Turney
A BN4 that came with overdrive will have an "O" in the serial number. No "O", no overdrive.
I
Ian R
It was originally built with an overdrive it has the "O" in the chassis number, is recorded on the heritage certificate and still has the wiring & switch gear.
I've been offered an unused "A" Type overdrive at a fraction of the listed price but he is unsure what vehicle it was actually intended for. I realise the main
shaft has to be replaced but as part of my restoration I will have the gearbox overhauled I thought this would be the time to do the change.
So, back to the question "are they all the same"...?
Bob_Spidell
I'm getting ready to tear into my BJ8's OD, so I've been studying the parts catalog, and I've stayed at a Holiday Inn before--bad US TV commercial reference--so I'll go out on a limb and say, with a couple exceptions, they should be interchangeable. In particular, the gearbox->OD adapter plates vary (DWR has them). Earlier Healey ODs have a different brass drain plug with a (very handy) square stud for wrenches, whereas later one have a notched perimeter that requires a special wrench (or hammer and drift). The actuating piston sealing mechanism--rings vs. O-rings--varies between models, but they appear to be interchangeable. Healeys used a smaller, weaker accumulator piston so that OD engagement wasn't as traumatic, but some substitute the larger accumulator and spring--found, for example, on TR4s--for quicker OD engagement. I just had a conversation about gearboxes and ODs with Tom Monaco at Tom's Import Toys (https://tomsimport.com/), and he said the TR ODs they overhaul usually have more wear/damage to parts like thrust washers due to the more dramatic engagement. Driver technique can determine wear as well:
https://www.quantumechanics.com/
I would try to contact these people (above), as maybe with a photo or two they could identify the OD you are considering buying.
To the best of my recollection, any Healey overdrive unit will fit on any__side or center-shift__Healey XMSN that has the ovd-specific mainshaft and adapter plate.
It has been my most recent experience that the 100/6, specifically mine (5/14-15/1958 build date) requires an overdrive with exposed solenoid linkage. When I attempted to fit an overdrive with an enclosed solenoid linkage, it did not clear the chassis.
I'm not sure when the change-over date was, but it would stand to reason that cars before that date *might* run into interference there.
This is an early style with exposed linkage (solenoid not yet mounted).
Another 100/6 unit.
I'm at a momentary loss for a good picture of the later type overdrive (somewhere, I have a picture of the fresh Quantum Mechanics ovd NOT fitting into my car...) but here's a bonus TR3 trans with a very similar overdrive; primary difference is the tail housing/mount, but many of the internals interchange, though they may be of different ratios, so some components would have to be swapped in sets.
I
Ian R
Thanks for all the info and pictures...(very helpful)..
I think I'll take a chance and buy the overdrive I've been offered, if it's wrong I can
always move it on.
I will get a specialist to do the overhaul / conversion for me.
Thanks again to all......
D TR2/3/3A Overdrive question. Triumph 49
KVH General TR Overdrive Up-date and Clutch Question Triumph 2
K Overdrive Screen Replacement Order Question Austin Healey 4
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
D TR2/3/3A TR3A overdrive question Triumph 6
D TR2/3/3A how to question for overdrive Triumph 29
C BN1 Overdrive drain plug question Austin Healey 0
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
6TTR3A TR2/3/3A TR3A overdrive relay question Triumph 3
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
K Overdrive pressure question Austin Healey 4
S TR4/4A overdrive question Triumph 1
oxford overdrive question Austin Healey 5
B Overdrive Oil Pump Installation Question Austin Healey 10
TR3TR6 TR6 Question about a TR6 J overdrive Triumph 12
stretchit2 Overdrive Question Austin Healey 5
A TR5/TR250 Overdrive question Triumph 12
M Exhaust fiasco & overdrive question Austin Healey 7
bighealeysource Overdrive question on BN2 Austin Healey 3
nevets Overdrive electrical diagnostics question Austin Healey 5
D A type overdrive question. Triumph 3
H overdrive solenoid question Austin Healey 4
J Overdrive Question Triumph 9
bighealeysource Overdrive fusing question on BN6 Austin Healey 10
J Overdrive transmission question Triumph 4
S Spitfire 76 spitfire overdrive test question Triumph 5
Coyote1 Overdrive wiring question Triumph 8
B Overdrive speedo cable question Triumph 6
TR3TR6 TR4/4A TR4 Transmission Question [non overdrive] Triumph 11
G How sweet if was AND overdrive question Triumph 22
Tinkerman TR2/3/3A Overdrive Switch question. TR3A, Problem Solved! Triumph 10
TR3TR6 J-type overdrive question Triumph 5
PAUL161 72 Overdrive rear oil seal question. MG 0
71tr J-type Overdrive Pressure Port Question Triumph 2
Monark192 MGB-GT 67 BGT - Overdrive Trouble Shooting Question MG 0
Monark192 MGB-GT 67 GT Overdrive trans oil change question. MG 6
7 question after testing a J type overdrive Triumph 5
roofman Spitfire 1975 Spitfire overdrive question Triumph 6
T MGA MGA overdrive - that is the question MG 23
T Overdrive question - electrical Triumph 14
N And Another Overdrive Question MG 6
T TR2/3/3A TR3 overdrive question Triumph 5
6 Overdrive Escutcheon Question: Reversed? Austin Healey 1
curtis 100 overdrive question Austin Healey 5
Bob McElwee Overdrive Operating Valve Question Austin Healey 6
TR_Jim GT6 GT6 overdrive question Triumph 3
S Overdrive Question Austin Healey 2
