Results 1 to 4 of 4
Thread: bn6 drum brake front hubs
Forum to discuss Austin Healey Sports Cars
  1. #1
    Jedi Warrior maxwedge5281's Avatar
    Join Date
    Aug 2013
    Location
    easley, south carolina
    Posts
    518
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    can the front hubs from a 1958 bn6 with drum brakes and steel wheels be used on a 1959 bn6 with disc brakes and healey bolt on wheels???
    1959 bn6 sbc zz4 with aod transmission....... 1959 bn6 inline 6 250 chev engine and tremec 5 speed.......Porsche 911 all aluminum 434 cubic inch dart sbc engine 930 4 spd
  2. #2
    Darth Vader Marvin Gruber's Avatar
    Join Date
    Jan 2003
    Location
    Florence, Al
    Posts
    2,956
    Thanks Thanks Given
    Thanked in
    Re: bn6 drum brake front hubs
    Don't think so. I believe the axle shaft size is different. You have to go a little deeper and change kingpin out as well. Ran into that when I put put disc brakes on my brothers 100/6.
    Marv
  3. #3
    Join Date
    Jan 2015
    Location
    Martinez, Ca
    Posts
    202
    Thanks Thanks Given
    Thanked in
    No. There is no provision for mounting the rotors.
  4. #4
    Darth Vader steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    2,698
    Thanks Thanks Given
    8
    18
    Thanked in
    Denis Welch &, AH Spares sell the adapter plates for mounting calipers on the older-style swivel axles. You can get them in the wider bolt pattern to fit the later Type 16 Girlings, 4-piston Girlings or 4-piston Toyota calipers.
    The Moss catalog makes it look like the kingpin is the same throughout. My BJ8 swivel axles fit onto my BN6 kingpins no problem.
    The main thing would be acquiring disc rotor-compatible disc wheel hubs from BT7/BN7 onward.
    I believe there's an older post in the archives where Randy discusses what he went through for the conversion.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
