Results 1 to 7 of 7
Thread: Pre-60k sloping rear needed
  1. #1
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    128
    Chats
    Hi guys-
    My pre-60k TR was raced and wrecked at some point, and the then-DPO slapped on a post-60k rear body half. I was over in JPs garage on Friday taking measurements off his car to fab a new rear interior, and he suggested I first check with yall to see if anyone has an extra one lying around. None of the big 3 here nor even Kilmartin down under have them for sale.
    Only really looking for the interior, as the raised plinths are easily removed, but a whole rear would of course work too. Thanks, Jim
  2. #2
    Obi Wan M_Pied_Lourd's Avatar
    Join Date
    Oct 2008
    Location
    Newmarket, Ontario,Canada
    Posts
    2,243
    Chats
    Re: Pre-60k sloping rear needed
    Hi Jim,
    Did you check Rimmers? I know they have them listed. Might check there.
    https://www.rimmerbros.co.uk/Item--i-GRID200720
    Looks like they are supposed to get stock December 15th...
    Cheers
    Tush
    81 Alfa Romeo Spider Veloce, 81 Triumph TR8
    73 Triumph TR6 CF4874UO, 68 Triumph TR250 CD5228LO
    60 Triumph TR3A TS69891LO, 60 Triumph TR3A TS64870LO
    59 Triumph TR3A TS44836LO
  3. #3
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    128
    Chats
    Quote Originally Posted by M_Pied_Lourd View Post
    Hi Jim,
    Cheers
    Tush
    Thanks. Just signed up to be notified. Jim
  4. #4
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    2,506
    Chats
    That is cheaper than I thought it would be. Heck getting one out of an old car would be a lot of work. I will look out back and see if the one I got is worth it, but I thinking getting new is your best bet.
  5. #5
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    865
    Chats
    Jim,
    I do have the interior piece that you are looking for. The piece is in good condition except for about 1 to 1&1/2 inches along the drivers side of the prop shaft tunnel. It is rusted badly and rusted through in several places. That would be most of the distance along that tunnel piece. Replacement would entail the portion that is normally above the floor plus the 1" that is bent under the floor. All of the rest of the piece is solid and not dented that I can see. This piece came to me via a frame that I needed. The body had been hacked up to make the unit into a dirt track racer. I kept the few body parts that were on the frame, but have no use for this piece.
    If you are interested I can get you some pictures and the cost to you will be shipping plus about $15.
    Charley
  6. #6
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    128
    Chats
    Thanks Charley! PM sent.
  7. #7
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    128
    Chats
    Thanks Charley. What a great resource BCF is!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
