TR2/3/3A Mixing MT-90 with Hypoid Gear Oil?
mrv8q
Should I do this? 1 quart of the Red Line didn’t quite fill the TR3 gearbox, and I have plenty of the StaLube 85W 90 in the garage. Can’t get the MT-90 locally, otherwise I’d just go get it.
Interwebs are mum on this subject, though I think I know the correct answer...
dklawson
The rule of thumb and best practice is not to mix oil types. If your gearbox is "close" to being full, drive the car gently and limited distances until you get more of the MT-90.
TR3driver
Great Pumpkin - R.I.P
Compatible meaning nothing really bad happens. But you also lose at least some of the advantage of the better oil.
Kind of like mixing Thunderbird in your single malt. Won't kill you, but might not taste very good either :smile:
I'm with Doug, order another bottle and drive with it a bit low until it gets there. But IMO there is no need to baby it as long as its just an ounce or two low. The "full" level includes a reasonable margin for leakage between refills.
mrv8q
mrv8q
Thanks, all. Thanks to our friends/ overlords at Amazon, they promise I’ll have another bottle today. I wasn’t keen on mixiy, so this worked out. Changing the gearbox oil was a “while I was in the neighborhood... “
I did a quick rebuild of the clutch master cylinder and am going to replace the hydraulic hose, all to cure an occasional balky-shifting gearbox. Fingers crossed...
dklawson
We no longer have our Spitfire but one of the modifications I made to it was the addition of an access hole on the side of the tunnel cover. I fit a large rubber grommet type plug into the hole. Whenever I wanted to top up the gearbox oil I'd peel up the carpet, pop out the rubber plug, then remove the fill plug and fill away.
mrv8q
mrv8q
I smiled at the Thunderbird reference as well. I actually used to sell it in a previous lifetime. 1.59 back in the day?
My gearbox takes 6 pumps over the original quart to fill... go figure. At least I know it’s full.
I plan to fill and bleed the new clutch master cylinder on the weekend, drop it from the jacks, and see how nicely my new refurbished clutch system works. Fingers crossed...
Definitely a good idea about an access hole, Doug. If I have to go back in, it’s on the list.
TR3driver
Do they still make T-Bird Randall, maybe in Cal plus I thought the gearboxes drank 30 W non-detergent
I haven't a clue about the Tbird; but if Gallo still makes it, I'll bet they sell it nationwide. Don't recall ever seeing it on a shelf here in CA; but then I don't spend a lot of time in the kind of places that usually sell it.
Triumph did originally recommend motor oil for the gearbox (although there is an early TSB suggesting that gear oil is OK too, without overdrive). But then, about the time the TR3A was (unofficially) introduced, they switched to specifying GL4. Ken Gillanders once wrote that an ex-factory engineer told him that they were having too many countershaft failures, and the GL-4 provided better protection. S-T and later BL continued to specify GL4 through the end of TR6 production, so evidently they felt it worked.
Personally, I really like the MT-90. Doesn't change OD performance much, but makes a noticeable improvement in the main gearbox IMO; in the form of easier, more positive shifts. My synchros are getting somewhat worn now, but with almost 200,000 miles since the main box was overhauled (1997 IIRC), I consider that pretty good service.
TR3driver
GL4 is a performance standard for gear oil; so it can be any of the gear oil weights. 90 is probably most common, ISTR MT-90 is actually rated 75W90 but Redline also offers MTL which is 75W80. I've also got a jug of 140 weight GL4 in the garage.
mrv8q
mrv8q
Just to button up this post... bled the clutch master cylinder, dropped the car off the jacks, and took it for a spin around the block. Car seemingly shifts fine, can’t tell any difference yet.
Going for a 50 mile round trip tomorrow morning, so that will be the real test. WooHoo, glad to see the car at its appropriate height in the garage.
TRMark Body Filler Mixing Board on the cheap Restoration & Tools 2
Jeepster Mixing stainless and mild steel exhaust Austin Healey 5
R Mixing spark plugs Triumph 10
T Mixing one and two post fulcrum brackets Triumph 3
B Mixing autobody products? My 2 Pence Restoration & Tools 0
T mixing oils Austin Healey 6
Webb Mixing Brake Fluid Spridgets 16
F Bugeye hypoid leak from paper hub gasket. Spridgets 7
rkep01 Cornhead grease vs hypoid gear oil Spridgets 6
R SAE 90EP Hypoid gear oil MG 2
L T-Series Gear box servicing cap. MG 5
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
S For Sale Differentail gear sets available. Spridget, Morris Spridgets Classified 12
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
C Spitfire gear selection Triumph 10
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
DocDup1 TR4/4A Second Gear Bushing Triumph 6
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR2/3/3A Gear shift knob Triumph 8
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
AUSMHLY BJ8 Gear Shifting Austin Healey 5
R Bugeye reverse gear Spridgets 6
TomMull TR2/3/3A 1st gear again Triumph 3
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
