100 X Brace Color?
simon1966
I have a question about the X brace that sits behind the grille and in front of the radiator, should that be body color or black? On my car they are body color. It has been suggested that this is incorrect and that they should be satin black so that they are less visible? I would be interested in opinions on this? I am fairly certain that body color is correct, but want to get some more expert input.
Rob Glasgow
Not sure about the 100, but on my BT7 they are hand painted flat or satin black as to not be visible on a white car. I doubt they painted it on a black car.
simon1966
simon1966
After a bit more research, what I am hearing is that most of the cars the X brace was body color, but that there are some exceptions, apparently white cars and some others had the X brace hand painted satin black. If any real experts can confirm that it would be great.
steveg
Anderson/Moment -- 100s, P.29, caption - vertical panel and x-braces painted body color. P.147 for the convertibles, left column upper: brush-painted flat black except for the black cars. Roadsters - P.75 rt column, upper: brush-painted flat black except for black cars
Duane_Rhynard
+1
Internet Photo
My Original Tri-carb
elrey
Was wondering the same thing. My tri carb has only the single running/ flashers. Perhaps the doubles were for a country with more stringent regs. My car is a U.S. market Ivory White with the X brace black as well.
Duane_Rhynard
3000 MK II tri-carb with separate side lamps and flashing indicator lamps ? Never see that before.
It is a German Export, cars for Germany and Sweden had separate lights on both the front and rear! Both the front and rear shrouds were modified to fit the lights! My research indicates there were less than 100 German and Swedish tri-carb exports with this configuration.
Thanks,
Duane
Healey Blue (aka healey blue) also has a BT7 like that; also has steering column lock and octagonal hub nuts, several years before the US required them (January 1st, 1968).
simon1966
simon1966
Thanks for the input, we drifted away from the main topic a bit :chuncky: Pretty clear to me that for the 100, the X brace is body color except for some very specific exceptions.
healeyblue
Randy
The German delivery car is the BJ7. The BT7 was a tri carb. Too many letter combos that sound the same to keep them straight.
Duane_Rhynard
Clearly! At least I consistently get them wrong... ;)
Randy,
You were very close, since the BN7, BT7, and the BJ7 all came in the glass two light configuration for Germany and Sweden!!!
Thanks,
Duane
BN7
BT7
BJ7
Sure like that red one!
I'd always been partial to the 2-seater, ever since R&T's article on all the Healey variants in the early 70s (June '72?). It's no wonder I fell for BN6L/942 when I saw it in Ray's shop (Healey West) around the Christmas Holidays 1977. He had it strategically parked next to the parts counter__which served as the cocktail bar__and the more I looked at it (along with the more I drank) the more I knew I had to have it. Seeing this, Ray knew he'd set the hook when he said "I'll finance it."
The rest has been a continuing history.
Getting back on topic, though my car was originally Healey Blue/OEW, and then silver by the time I bought it, the cross-piece was still painted a mat-black. I had cut it out sometime in the 80s to fit an electric fan, or it'd be Wine Red today (that's dark enough to not show through the grill).
MikeAH100M
If I remember the numbers, most 100's were two tone. Mine was originally Reno Red over Black but repainted several times and is now Healey blue. I can find Red, Black and several others colors on the X brace. So when we say that the X brace should be "Body color", which color would that refer to - the Red on top or the black in the cove?
catfood
I think from memory the two tone only came 'factory fitted' in the BN2. All the BN1's were originally solid although a lot of owners added the second colour retrospectively. I am happy to have my memory corrected as I don't have my books handy to check!
I think you are correct, though I don't have evidence (the Moment/Anderson book might say, but mine's in another city right now). I've read/heard that only 100Ms came from the factory in two-tone, and the vast majority of them were white/black (ours was).
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 4
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 7
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
3 100 Clutch Freeplay Austin Healey 7
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
T 100-Six Clutch Recommendations Austin Healey 5
J Owners of my 100-4 Austin Healey 1
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
H 100-6 Interior Installation Austin Healey 4
