Results 1 to 12 of 12
Thread: Tailpipe sniffer
  1. #1
    Join Date
    Sep 2015
    Location
    Michigan USA
    Posts
    41
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Tailpipe sniffer
    Have any folks tried using a tailpipe sniffer to set the mixture on our TRs? Which one did you use and how did it go?
    60 TR3A TS66043
  2. #2
    Join Date
    May 2012
    Location
    Robbinsville, NC; Everglades City, Fl
    Posts
    505
    Thanks Thanks Given
    Thanked in
    Re: Tailpipe sniffer
    There is a prescribed procedure that is based on real conditions at the needle and jet. It has worked well for over 70 years. Why try something else?
  3. #3
    Yoda poolboy's Avatar
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,590
    Thanks Thanks Given
    2
    Thanked in
    The problem with a sniffer or just one A/F sensor is that it can only report the combined effect of your carbs...One could be adjusted rich, the other lean, the results appear normal.
    DRIVE 'EM IF YOU GOT 'EM
  4. #4
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,001
    Thanks Thanks Given
    2
    Thanked in
    Many years ago, I tried using an O2 sensor mounted into the exhaust manifold. It was the "narrow band" type, and as a result returned basically no useful information. The original SU carbs simply do not hold the mixture at the theoretical ideal mixture no matter how you adjust them; and the sensor I had (same as used in most modern cars) was not responsive either at the richer mixture that produces best power; or the leaner mixture that produces best fuel economy. But the slightest movement of the throttle would change from one extreme to the other.
    As far as why, as I've written before, any change in how the engine breathes can cause a change in what needle is required to produce optimum mixture. That is why there are so many needles available, almist every car used a different needle. So bigger liners, a bigger exhaust, exhaust headers, a different cam and so on all may need a needle change for best performance.
    There are also various defects, like a worn jet, that can cause the normal adjustment procedure to not produce best mixture. In retrospect, I believe that is the reason that my Dads TR3A would always overheat, and eventually swallowed a valve. It cruised so lean, and EGT was so high, that it eventually eroded an exhaust valve stem until it failed. At the time, we blamed it on the 4.1 axle and no OD, but I've since run that combination on my own TR3 and it did not overheat under the same conditions.
  5. #5
    Join Date
    Sep 2015
    Location
    Michigan USA
    Posts
    41
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by bobhustead View Post
    I have never felt that I am getting the mixture right when I use the procedure. It says things like "turn the nut one flat, and see if the RPMs go up or down". OK, I turned it one flat. No change in RPM. Then 6 or 8 more flats. Still no change. I don't seem to ever get the results that the procedure says I should. I usually just mess around for a while and give up. Seems to run OK, although lately wanting to stall during warmup.
    60 TR3A TS66043
  6. #6
    Join Date
    Sep 2015
    Location
    Michigan USA
    Posts
    41
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by poolboy View Post
    Sure, but wouldn't you just shut off one carb while adjusting the other one?
    60 TR3A TS66043
  7. #7
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    4,495
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Quote Originally Posted by Snowkilts View Post
    It sounds like your needle/jet are worn. If the carb is in good condition you will eventually kill the engine by turning the nut upward. If the needle/jet are worn, then the sniffer will have no better luck.
    I’m not sure how you could turn a carb off? If you closed one completely, then you would have to open the other more to prevent the car from stalling. If you open the throttle more than the normal idle speed, then you are adjusting the carb at a larger opening, and once you reduce the opening to run on both carbs the mixture will, again, be wrong for the reduced setting.
    John
    1955 TR2
  8. #8
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,001
    Thanks Thanks Given
    2
    Thanked in
    When I get that, it almost always means that something else is wrong. Valve lash & ignition timing are the usual suspects, but I've also seen it with valve timing off by a tooth.
    Randall
  9. #9
    Join Date
    May 2012
    Location
    Posts
    505
    Thanks Thanks Given
    Thanked in
    I don't know how you could shut one carb off. If you could, as Randall said, everything else that is happening at the time you set it affects mixture. What happens, then, when you put the "off" carb back in the circuit. These carbs are not capable of perfect adjustment and the adjustment you do get is idle only. You don't look for the speed change by simply moving the nuts. Too gradual. The change you want is a bit of speed increase when you lift a carb piston a very little bit with a screwdriver. Your car is never going to idle at 500 RPM like some books say.
  10. #10
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,590
    Thanks Thanks Given
    2
    Thanked in
    Pull your spark plugs after a extended drive, but one that doesn't involve a bunch of stop and go or extended periods of idling.
    Get it out on the highway for 20 miles and bring along a spark plug wrench and a camera if you want to show us.
  11. #11
    Join Date
    May 2017
    Location
    Garrison, NY
    Posts
    162
    Thanks Thanks Given
    Thanked in
    I agree. Forget the mixture at idle. It's my experience that if the mixture is adjusted at idle the car will run lean at speed. The idle should be set at least at 750RPMs or it will stall because it's too rich.
  12. #12
    Join Date
    May 2006
    Location
    Kansas City, Missouri
    Posts
    280
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    I use an old Sun exhaust gas analyzer on both my TR3A and Austin-Healey 3000.
    I always set the rocker arm gaps, point gap/dwell, and timing before attempting to set the carbs.
    I get great results that last years.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
