TR2/3/3A 3.45 Diff ratio?
karls59tr
I always get this confused. Would this Diff be good for better acceleration or better top end if replacing a 3.7 Diff with no overdrive? :encouragement:
gecoughenour
Better top end. The gear ratio is how many times the propeller shaft, i.e, the engine (unless your clutch is slipping badly) turns for each revolution of the axle shaft. In fourth gear, the axle would turn 1000 RPM at 3450 RPM engine speed versus 3700 RPM engine speed with the 3.7 ring and pinion.
TomMull
Yes, but you will pull longer in each gear. More noticeable might be earlier downshifts when pulling uphill. Fair trade off, IMO, for losing a couple of hundred rpm at speed. Mostly speculation on my part as I still have the 3.7:1 Tom
charleyf
I have been using the 3.45 gears now for more than 5 years in the TR3&4. The only slowing of acceleration would be seen in a racing situation. When I am street driving and get a green light I am no slower than my friend with his TR6. As I am following him in this situation. He slows to shift to second and I have to back off because I am still accelerating in first. The big disadvantage is on a hill. I do have to change to a lower gear sooner. Another disadvantage is in following my fellow TR's downhill. When using the gears to retard speed I have to brake more often if following another TR.
The actual speed increase in fifth gear (I use a Toyota 5 speed) is about 3-4 mph.
My overall feeling is that I do like them but don't feel it is worth the cost of switching. If you need to replace a 3.7 then this is a viable alternative.
Charley
sp53
Ok help me out here, but please do not laugh or laugh in your coffee and have it come out your noise. Anyways, I thought those ratios were the number of teeth on the ring and pinion like for example 37 teeth on the ring and 10 teeth on the pinion. Would be a 37 to 10 or 3.7 to 1.0
steve
K
karls59tr
steve
Actually that is correct. So 3.45 to 1 would be 34.5 to 10....wonder about the 1/2 tooth?:playful:
parkerg1
steve
I could be all wet, but I believe the 3.45 is 11 and 38 tooth..
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
T Diff Ratio BJ7 Austin Healey 5
B diff ratio British Motor Corp 3
K TR2/3/3A TR3 Diff Ratio for Highway Driving ? Triumph 5
5 Diff ratio Austin Healey 6
John Moore Diff Gear Ratio Spridgets 25
G What diff ratio does a '79 have? Spridgets 8
Z BN1 Diff Ratio ID on Housing Austin Healey 2
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
Darwin GT6 Diff Help Please Triumph 2
skystryd Trans and Diff Spridgets 7
M TR4/4A Diff comparisons Triumph 2
N TR6 Triumph Diff which model??? Triumph 1
pbraun Wanted 3.9 diff for sprite Spridgets Classified 5
steve00136 MGB Diff refurbish MG 6
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M TR4/4A Diff Conversion Triumph 3
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
B best diff British Motor Corp 5
wangdango '67 XKE rear diff? Jaguar 2
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
69MGC MGC Diff Oil MG 1
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
drooartz Diff pinion nut Spridgets 10
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
R TR2/3/3A Lockheed diff setup Triumph 6
Boink 3.9 diff and pinion seal Spridgets 2
Boink 5 speed vs. 3.9 diff - either or both? Spridgets 165
Michael Oritt 3.54 diff for sale Austin Healey 1
drooartz Diff pinion seal Spridgets 8
Rut Diff plug tool Spridgets 7
Geo Hahn General TR Diff Pinion Seal Triumph 5
Geo Hahn TR2/3/3A Paint Dab on Diff Cover Triumph 6
A TR4/4A Changing rear diff seals Triumph 15
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
JFS Wedge Diff Cover Gasket Adhesive Triumph 10
G Diff and trans oil Spridgets 8
C TR4/4A Diff gear wear Triumph 10
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
K TR2/3/3A 4:1 Diff in a TR3? Triumph 3
steveg Limited Slip GM Healey Diff Austin Healey 4
DerekJ 11:39 Diff for sale. Austin Healey 0
H Noisy diff in BJ7 Austin Healey 2
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
