62 / BT7 carb questions
  • Thread starter Deleted member 21878
  • Start date
IMG_0263.jpgstarting pulling out the carbs and parts today. the PO had them rebuilt.
2 questions)
1) i always thought the SU carbs with the brace on the neck did not use vented caps. the ones on these carbs have a hole in them. am i correct there?
2) what do you all use for vent pipes on the carbs and how do you run them?
Thanks
Keith_M
Hi TL,
If I'm reading your question correctly, the vent pipes are for overflow and should be connected to tubes that run down past the manifolds and empty on to the ground. I've never actually seen the correct tubes or routing, but I just ran flexible fuel line down through appropriate places (away from the exhaust manifold). Maybe someone else has more information.
Keith
Keith
Thanks. so you just used a clear fuel line?
Keoke
steveg
I've used both clear neoprene and black vinyl. They both became distorted and brittle from the heat. I made permanent pipes from 3/16" brake line tubing, joined to the Healey stubs with short lengths of rubber tubing and clipped to the inside of the fender with a Moss dual pipe clip 585-595:
thanks. i will look in to that. i have some old brake lines left over. guess some soft copper tubing would do the same thing.
speaking of heat. i read somewhere that having the exhaust manifolds done with a ceramic coating keeps a lot of the heat in the pipe and can reduce heat in the engine bay by 25%. has anyone tried that?
... speaking of heat. i read somewhere that having the exhaust manifolds done with a ceramic coating keeps a lot of the heat in the pipe and can reduce heat in the engine bay by 25%. has anyone tried that?
Yep. Only succeeded in reducing the weight of my wallet by 25%. But, seriously, the heat in the engine bay was probably reduced by coating the manifold and wrapping the downpipes, it just didn't produce any noticeable improvement in performance or vapor lock. You might see something on a dyno, but high-heat paint looks as good and is a lot cheaper.
steveg
I have tube headers ceramic coated inside and out. They are quieter - much like the cast iron manifolds; they aren't as hot that way either. Gets rid of the tinny sound tube headers make.
Ditto.
A dozen years later, they're a bit duller, but no areas are flaking off. They were coated in/out from new, before they were ever run on the engine, and I think that has a lot to do with coating integrity.
thanks for the info. using the stock manifolds. i had some POR15 left over and have used that. never had great luck with it staying on for a long time. but i never had a way to blast the manifold before. i blasted these, did not touch them and i used metal prep on them before painting. i got some time before they will go on so i am putting them in front of the heater in the shop to help cure the paint before i mount.
i would look to have them coated if i thought they would really help with the heat situation.
I found one of those elbows today in one of the boxes. Going to loo for a couple more now.
guess they did not worry about extending down below the manifold....
elrey
The flexible vent tubes on my 62 / BT7 mkII don't extend any further than the BN7's. When the needles went bad I switched to Grose Jets [ball bearing] and they never vented gouts of raw fuel again.
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D Rough running BT7 3 carb HELP Austin Healey 13
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb BT7 triple carb question Austin Healey 15
D BT7 Tri carb Backfire Austin Healey 2
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
