TR6 Brake caliper question
ichthos
Can someone tell me how the piston dust covers go on? Does the lip go toward the piston or face the pads? How are they held in place? Thanks for your help.Kevin
charleyf
The lip fits into the groove at the top of the cylinder in the caliper. You need to fit the bottom or lip portion of the dust cover into the groove and then push the piston down into the caliper. You are not likely to get it the first time.
Charley
rjc157
Just did mine you have to push the piston down first when you put the wire clip in you have to start at the bottom where that lip is in order to hold it in place
poolboy
There are 2 versions of calipers..The early 16P did not have the spring clip...Around 72 or 73 the 16PB was inroduced which did have a spring clip boot retainer.
Geo Hahn
If the non-clip type is the same as used on the TR3 & 4 (and I believe it is) I get the boot onto the piston by blocking the opposite piston hole, installing the boot and resting the piston to be installed centered on top of it. I then introduce modest air pressure into the caliper thru an old brake hose (bleeder closed) and the boot lightly inflates and 'wants' to pop up around the piston. Helps to have everything a bit wet with brake fluid.
First one make take a couple of tries (a special wiggle is involved) but soon they pop on in a second. A helper to control the air is useful.
martx-5
Having been in the caliper rebuilding business in another life, we used to install the boot around the piston first. Push it down toward the bottom, and then wiggle the lip of the boot into the groove in the caliper. The groove has to bee scrupulously clean. Usually rust gets in there which prevents easy entry of the boot lip. A machinist's scribe or similar can be used to scrape around the groove to get all the junk out. Even after glass beading or blasting some stuff still might remain. Liberal use of some sort of lube (we had special slick stuff) or brake fluid helps.
Here's a video on how we did it...start at the 4:00 minute mark.
Geo Hahn
Slick - I'll try that way next time.
Either way it is a good feeling when the piston suddenly finds that sweet spot and slips in. Good idea too that you pulled it back out a few times to be sure everything seated correctly.
I
ichthos
Thanks for the help. I rebuilt the front end a number of years ago, but apparently did not put the dust covers on correctly. I have the older type caliper that fits in the grove without a clip, but I had failed to pull it up over the piston.
Kevin
K TR2/3/3A Brand new brake caliper question... Triumph 8
SCguy New Toyota brake caliper conversion question. Triumph 3
C AH3000 BJ8 Brake Caliper question Austin Healey 7
B E-Type brake caliper rebuild question Jaguar 4
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
B TR2/3/3A Caliper brake line Triumph 10
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
K TR2/3/3A Front Brake Caliper Shims Triumph 3
K TR2/3/3A Brake caliper hold bolts? Triumph 1
K TR2/3/3A 62 TR4 Brake caliper? Triumph 5
C TR6 Leaky brake caliper Triumph 6
Jim_Stevens TR2/3/3A Brake caliper corrosion Triumph 5
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
tr3guy TR2/3/3A Brake caliper with ?ball bearing? Triumph 5
R Correct Brake Caliper colour Austin Healey 9
T General Tech Brake caliper - piston stuck Triumph 4
HealeyRick Brake Caliper Upgrade Austin Healey 120
M_Pied_Lourd TR2/3/3A Brake Caliper Piping Triumph 2
T TR2/3/3A Wanted: Tr3a lft frnt brake caliper Triumph 3
Michael Oritt GT6 GT- 6 Brake Caliper/Mounting plate information needed Triumph 4
T TR6 Brake caliper lock after some driving Triumph 3
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
M TR2/3/3A "59" tr-3a brake caliper Triumph 3
K TR2/3/3A TR3A Brake caliper thread chaser? Triumph 2
K Is there more than one type of 16P brake caliper? Triumph 14
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
Jeepster New BJ8 - brake caliper fouls on wheel spokes Austin Healey 3
Darrell_Walker Wilwood brake caliper bleeders Triumph 12
B brake caliper color Triumph 5
doughairfield TR4/4A TR4 Brake Caliper Re-Assembly Triumph 9
S MGB-GT mgb gt brake caliper rebuild kit? MG 2
M Dunlop Brake Caliper correct color? MG 2
Phil73 Brake caliper issues Triumph 5
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
B brake caliper shims Triumph 16
M_Pied_Lourd TR2/3/3A TR3A Front Brake Caliper Choice Triumph 5
I TR6 TR6 - how many brake caliper shims? Triumph 26
TR6oldtimer TR6 TR6 Brake caliper part. Triumph 6
prb51 TR2/3/3A FYI TR3 Brake Caliper Seals/Pistons Triumph 0
jjbunn Wanted: 16P LH Brake Caliper Triumph 21
T TR2/3/3A TR3b brake caliper options Triumph 4
S TR6 tr6 brake caliper rebuild Triumph 3
