Brake shoes won't move back after releasing handbrake
warwick-steve
After leaving my BT7 on my slightly inclined drive I can usually free wheel it down and into the garage. Just now the car did move down but slowly and I had to really push it into the garage.
Having jacked the car up I found that the ns rear wheel will hardly move and guess that the shoes have not released. How do I release them please?
The handbrake does in any case need adjusting as the handbrake lever needs about 10 click before it holds. Once I release the shoes I will through the handbrake linkages and check the springs and shoes etc but first I need to release the shoes.???
Advice please
Cheers
Steve
Get (at least the rear) up on jackstands if you can (safely), and check that the linkage can move freely. If it does, one or both shoes may have become stuck to the drum, esp. if the car sat for a while. Back the adjuster out a few turns, but not all the way out if you can help it. Then, it's a matter of banging on the drum with some sort of non-marring hammer; a lead knockoff hammer would be good, or one of the lighter hammers with plastic faces. Bang the drum (heh) on all sides and from behind, being careful not to chip or crack it, and hope for the best. Some light heating might help, but you'll likely spoil your paint.
aero3113
I had this happen once on a car I owned. I just hit the drum a couple of times with a hammer and it freed it up. Never had a problem after that. Once it does free up, lube the pivot points.
warwick-steve
warwick-steve
Thanks guys
The shoes are not totally locked on as I can with some effort turn the wheel ( slightly easier forward than backwards). I will do as you advise.
Cheers
Steve
SteveT3000
If it's still binding after you have backed off the adjuster you may need to remove the clevis pin out of the lever to allow the shoes to retract if the linkage is seizing somewhere.
johnea
Maybe your rear brake hose needs replacing. They can act as a one way valve when they get older, keeping some pressure on your brake shoes . . . .
Take a good look at the return springs that go across from shoe to shoe when you have the drums off. I was sent a set of replacement springs that were unacceptable; they were too long, and the "hooks" were way too long to be hooked into the shoes, so I had to reuse the originals.
Even with the hand brake, these springs do the duty of retracting the shoes.
The tip for checking an (internally) swollen hose is a good one too, but should affect both sides equally__unless one side is drawn up tighter with the adjustment than the other...
warwick-steve
warwick-steve
Thanks Randy
Just managed to release the shoes by backing off the adjuster. However, I do plan to check over the complete handbrake linkage and shoes over the next few weeks. I had planned to fit new springs if I needed to fit new shoes so your comment about the spring length is useful
Cheers
Steve
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
DornTRoriginal For Sale 9 Inch Brake shoes from TRF Triumph Classifieds 5
certifiedcarnut 948 front brake shoes warning Spridgets 5
maxwedge5281 rear brake shoes Austin Healey 11
B T-Series MGTD brake shoes. Are there leading and trailing shoes? MG 1
E rear brake shoes Austin Healey 1
I Relining brake shoes Spridgets 19
RickB Source for brake shoes - 78 Midget? Spridgets 8
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
Andrew Mace Revelation about brake shoes Triumph 4
mgbmedic Wedge TR7 Rear Brake Shoes Triumph 7
Dan_Willert Brake shoes rub MG 9
bcbug midget rear brake shoes adjusters Spridgets 4
Hairyone bugeye rear brake shoes Spridgets 5
bigjones Installing rear brake shoes Spridgets 40
JohnnyMead TR2/3/3A TR3a Brake Shoes Triumph 3
jlaird Question-rear brake shoes Spridgets 7
S Brake Shoes Austin Healey 3
DNK Rear Brake Shoes Triumph 14
jdubois Anybody use Porterfield R4-S brake pads/shoes? Triumph 9
healeyboz Brake shoes Spridgets 3
M Car doesn't like my shoes [Brake fluid in cockpit] Spridgets 28
RedTR3 Installing new rear brake shoes Triumph 5
V looking for mg brake shoes MG 1
A TSI--kevlar brake shoes?? Triumph 10
I BN1 Brake Saga Chapter 4 : Wrong size shoes !? Austin Healey 2
J TR2/3/3A TR3 Brake Shoes Triumph 5
R brake shoes Austin Healey 2
Michael Oritt Elva front brake shoes and cylinder kits Other British Cars 67
B Brake shoes dis-bonded Austin Healey 7
S MGB-GT GT brake shoes MG 3
F porterfield brake shoes [need cores] Austin Healey 4
6 Brake Fluid Spridgets 3
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
