Results 1 to 5 of 5
Thread: Lucas Prince of darkness
Forum to discuss Austin Healey Sports Cars
  1. #1
    Join Date
    Aug 2004
    Location
    The Netherlands
    Posts
    166
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hello
    After various problems and lack of time the 100-6 is finally running and driving on the road again. I made the first ride yesterday for approx 20 miles without problems. However today there were some issues. One with fuel supply for which i will open another thread and tis one about the electrics.
    As it was becoming dark i noticed, that the parking lights and rearlights didn't work. Strangely enough the headlights did. When I parked the car ( the light switch was off but the ignition still on. The rearlights started to burn. Even when i took the inition key off the lights kept burning. I have switched off the master switch to "stop"the lights burning.
    Are there any ideas what the problem could be and how to solve it
    Harry
  2. #2
    Join Date
    Aug 2016
    Location
    Greensburg, PA
    Posts
    105
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Re: Lucas Prince of darkness
    Since the power for the lights doesn't run through the ignition switch the position of the key is irrelevant. I would double-check the wiring at the light switch first and even the switch itself. Use a continuity tester to make sure the three positions of the switch are indeed working as they should.
  3. #3
    Yoda Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,046
    Thanks Thanks Given
    5
    13
    Thanked in
    Harry--
    I'm reading into your first paragraph that you have recently done some substantial work on the car. Perhaps some new wire connections were made and/or old ones changed but I would look at the components you worked on and see if they lead you to where things might be astray. This is probably not a Lucas issue.
    Best--Michael Oritt
    1954 Austin-Healey 100 Le Mans
    1958 Elva Courier (FOR SALE)
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  4. #4
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,136
    Thanks Thanks Given
    44
    55
    Thanked in
    Having recently installed a new wiring harness, I cannot recommend Tom's large color wiring diagrams too highly! They make this kind of troubleshooting relatively easy!
    Tom's Import Toys, that is.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  5. #5
    Join Date
    Jun 2013
    Location
    Newcastle
    Posts
    72
    Thanks Thanks Given
    Thanked in
    Did the wiring harness smoke? If it did don't forget to top it up with genuine Lucas smoke!image.jpeg
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
