Wire Wheels and Top installed
aero3113
I finally have my wire wheels and top installed. Once I had the correct hubs to convert from bolt on hubs up front, the install was pretty straight forward. I had the rear hubs redrilled by a local machine shop to 4.5" to fit the Ford rear end. The top also wasn't as bad as I thought it would be to fit. Overall I'm very happy with the outcome and the car looks so much better without the wide tires and centerline wheels!
55modified
What kind of steering set up do you have there?
aero3113
aero3113
I'm not 100% sure, it was installed when I bought the car. Maybe from a sprite I think.
maxwedge5281
coming along nicely and looking good keith!
CLEAH
It would be great to know, or maybe another picture of the rack. About the only thing I would like to change about my car is the steering.
HealeyRick
The biggest drawback, for me anyway, is I've yet to see an upgraded steering system that allows use of the original turn-signal function.
As my original trafficator still works (only taken apart to be cleaned/lubed twice in the last 40 years) I'm reluctant to do away with it. I suppose with some clever engineering, a 4-circuit slip-ring could be adapted/fabricated, and hidden somewhere under the dash, but you still have to get those wires out from the center of the column...
aero3113
aero3113
Here are some more pics, hope they help. If anyone knows what the rack is from, please let me know.
6ECB5060-F289-45C4-84B5-497D8C70B1A0.jpeg3D4F76B6-296A-4B8C-8D36-91E9D357AC31.jpeg2884052D-AA36-4326-84AB-3AFB39A89694.jpeg85F2E4DF-C16A-49FC-BE02-4208AA5B0A38.jpeg
On that note, has anyone installed the DWR improved box? They claim it's 'the next best thing to rack-and-pinion?'
CLEAH
Randy, I agree. Ultimately, like a lot of things Healey, this is a study in compromise. Better, more precise steering? Self canceling turn signals? Take your pick, you can't have both. I 'm used to a toggle for turn signals--that's what's on my Sprite, and that is what was on the BJ8 originally when we bought it. There was a toggle screwed to the steering wheel in place of the trafficator! Eventually my dad wired in a buzzer so we would not be driving around with the turn signal going. I was embarrassed by the buzzer. Eventually he sourced a used trafficator and all was well. But I think I would trade off in favor of the steering.
CLEAH
And on yet another note, does rack and pinion do anything for slow speed heaviness? I know my Sprite steering is very light and a delight to use, but of course the car is very light. Rick's electric rack and pinion is really intriguing--possibly because having just turned 55 I am probably officially really old so power steering sounds good to me!
HealeyRick
Here's my WAG, based on a little experience with Sprites and big Healeys. A rack and pinion would probably take all that slop that is inherent in the big Healey's worm and roller out of the equation. But you still have that heavy lump of a motor hanging over the front end weighing down on the steering and tires, making the steering slow. I know when I put the lighter V8 in the BJ7 it made the steering much quicker and lighter. Perhaps a power assist on the steering would make it a little lighter and quicker. The rack and pinion (non-power) kits I've seen for the Healey require quite a bit of work as the steering column will pass through the radiator without some jiggering around. I've never heard of anyone putting an electric rack on a Healey and don't know what clearance issues there would be (not to mention a complete lack of originality that could easily be seen). For those of us that have driven Sprites, the big Healey handling has always been a let-down.
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
P TR5/TR250 Wire wheels width Triumph 8
D Wire Wheels and Air Leak Austin Healey 16
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
C What to do about my wire wheels Restoration & Tools 6
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
Rut TR4/4A MWS wire wheels Triumph 9
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
tahoe healey Wire Wheels Austin Healey 22
Got_All_4 For Sale Triumph Austin Healy Jaguar 15"x5.5" Complete Wire Wheels Set & Hubs Triumph Classifieds 1
HighAltitudeTR3 TR2/3/3A Balancing Wire Wheels... Triumph 4
maxwedge5281 wire wheel conversion to road wheels Austin Healey 21
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
Zimmycobra For Sale Original 1966 TR4A 60 Spoke painted wire wheels Triumph Classifieds 0
B wire wheels and broken spokes Austin Healey 19
trglory TR2/3/3A Wire Wheels Triumph 15
AUSMHLY Dayton vs. Dunlop wire wheels Austin Healey 11
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
B wire wheels tire breakdown Austin Healey 23
S TR4/4A wire wheels Triumph 4
trotti Chrome Wire Wheels Austin Healey 5
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
B TR2/3/3A Wire wheels on TR3 Triumph 8
2 TR2/3/3A Dayton Wire Wheels Triumph 4
BN6_2197 185/80 tires on 15'' wire wheels in Germany Austin Healey 10
S TR2/3/3A cleaning wire wheels Triumph 6
Marvin Gruber TR5/TR250 TR250 wire wheels, 60 or 72 spoke? Triumph 6
PAUL161 T-Series New Wire Wheels Mounting MG 11
PAUL161 General MG Chroming Wire Wheels MG 9
maxwedge5281 wire wheels to steel wheels...bn6 Austin Healey 0
drooartz MGB-GT Fighting wire wheels MG 19
T TR2/3/3A TR3A Wire Wheels Basic Questions Triumph 23
RJS TR4/4A Questions: new tires on old wire wheels Triumph 10
S TR2/3/3A Wire Wheels Sealing Triumph 17
P Restore original wire wheels or buy new? Austin Healey 7
K BMC paint colour code AL1 [wire wheels] Austin Healey 1
wangdango Competition wire wheels? Austin Healey 6
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
MikeAH100M Sprite Rear Axle with Wire Wheels Spridgets 11
DerekJ Ever seen wire wheels like this before? Austin Healey 5
Zimmycobra Hendrix Wire Wheels Triumph 5
B Wire wheels? FORUM Navigation Questions 3
Zimmycobra Powder Coating wire wheels? Triumph 10
