TR2/3/3A Value of a Complete Motor disassembled?
karls59tr
Bronze
I have a complete disassembled TR3 motor that I would like to sell. Block,crank,cylinder head etc.All parts have been cleaned. I realize that everything depends on condition but everything looks useable. It comes with two sets of pistons...one set is 83mm and the other set is 86mm. Anyone have a guesstimate of what the motor might be worth?
charleyf
Karl,
To me it sounds like you have a complete motor needing a complete rebuild. The fact that the parts have been cleaned does little to nothing for getting those parts ready to put back into an engine. If you had a local buyer I would guess you could ask $300 to 500. Or you could sell it in parts and possibly get more. The value in a rebuilt engine is in the $2,000 or so that it takes to grind the crank, rebuild the head, replace the pistons and liners and change out all of the bearings.
Charley
K
karls59tr
Bronze
Karl,
Charley
That's what I figured. Around $500 seeing as how it's not just an oily seized up lump from a barn. Mind you I did sell a cylinder head locally for $400. Supply and demand I guess.
M_Pied_Lourd
Karl,
Just as an FYI, there is a local guy to me here in Ontario who has been trying to sell a disassembled TR3 block on Kijjiji for $500 for several months. No takers yet...I sold a clean complete block but In unknown condition about 7 years ago for $300. So, I am thinking $400 would be around the going price.
Cheers
Tush
Geo Hahn
May be a tough sell.
When a local guy who dealt in used Triumph parts was closing out his business he was giving away 4 cylinder TR blocks - but couldn't get takers for most of them.
If someone really needs one then there's your customer -- but for most it is not something they will ever need and certainly not need a spare.
Lou Metelko
There might be a weird o like me out there that would like to replace the TR4 engine now in his early 3 and the 4 engine number is not even close to his commission number of his 3. Giving the number of the engine for sale (TSxxxxxE) might just help. If you need me to explain you really would not understand.
Lou Metelko
Auburn, Indiana
Geo Hahn
Not weird at all Lou.
I had quite neglected that possibility. Yeah, if you can get an engine number higher than the commission number but within reason then that is 'good enough' for a judge as TRs do not have a detailed data plate like some marques I could name.
bobhustead
Anybody in the market would want to have the reusable components (head, block, crank) crack checked, the cam miced. They are really not worth the cost of shipping in unknown condition and barely that if good. I have almost two old engines that sit and slowly rust. Sorry.
Bob
C TR2/3/3A Frame repair and value Triumph 2
D I have doubled the value of my MG Midget. Spridgets 2
AngliaGT 1275 Engine Value? Spridgets 5
AngliaGT TR2/3/3A Value of a One Owner,Excellent Condition TR3B ? Triumph 12
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
HealeyRick Gold Level Concours Value Austin Healey 20
M Original Bugeye steering wheel value Spridgets 3
Kleykamp Rubber bumper Midget value? Spridgets 5
J 1963 Austin Healy "Sprite" Value Austin Healey 7
J MGB 1973 MGB Value MG 8
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
TR4nut TR6 Ballpark hardtop value? Anyone? Triumph 3
D 68 Sprite value - need help Austin Healey 9
TomMull GT6 More on value trends Triumph 12
Brinkerhoff TR6 value of a TR6 factory hardtop Triumph 5
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
M The value in 5 speed conversion Spridgets 18
7 TR6 help with tr6 hardtop value Triumph 5
B Original Hardtop - Identification and Value Austin Healey 8
C Value of 100-4 heater box?? Austin Healey 2
J TR2/3/3A Dynamic timing value Triumph 5
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
Gliderman8 TR6 Opinions on value of this '76 TR6 Triumph 18
C Color change...impact on Value? Austin Healey 24
Mink TR4/4A Your thoughts/value of this TR4 Triumph 357
Jim_Stevens TR2/3/3A OD Transmission value Triumph 3
AngliaGT MGB '67 B - Value? MG 5
T 100-6 Longbridge value Austin Healey 5
2 GT6 69 GT6+ suggested value? Triumph 4
J Value on an original BJ7 these days. ?? 38,000 miles Austin Healey 4
RickB MK1 Midge radiator value? Spridgets 2
apbos Works hardtop. The value of or cars is climbing! Spridgets 11
K TR2/3/3A Torque value for TR3 clutch cover to flywheel bolts....... Triumph 2
Brinkerhoff Market value for an unrestored BJ7 ? Austin Healey 17
K Value of an early Commission Number Triumph 5
N BT7 Restoration value advice Austin Healey 32
6 any value to this?? MG 2
TR4A_IRS TR4/4A TR4A long block value? Triumph 11
C BJ8 Smoothline top value Austin Healey 9
Marvin Gruber Looking at another 100 6- value? Austin Healey 16
R Fair Market Value Triumph 15
J Things that influence the value of a Spridget? Spridgets 18
K TR2/3/3A TR3 starter dog bolt torque value? Triumph 1
A T-Series MG TD Barn Find [sort of] value MG 1
Marvin Gruber TVR Value TVR 1
