Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: glove box lock
Discussions of Triumph motor cars
  1. #1
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    2,657
    Thanks Thanks Given
    Thanks Thanks Received
    3
    Thanked in
    glove box lock
    I got working on this glove box lock and wanted to removethose little tumblers, and I am mystified how they got in or come out, aliens? Cansomeone suggest a way to get them out of their cocoon?
    Steve
    Attached Images Attached Images
  2. #2
    Great Pumpkin TR3driver's Avatar
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,216
    Thanks Thanks Given
    2
    10
    Thanked in
    Re: glove box lock
    Gently tap them through from the other side. When you get the new ones installed, you'll probably have to stake the body a bit to hold them in.
    Randall
    56 TR3 TS13571L once and future daily driver
    71 Stag LE1473L waiting engine rebuild
    71-72-73 Stag LE2013LBW waiting OD gearbox rebuild
  3. #3
    Jedi Knight Tr3aguy's Avatar
    Join Date
    Mar 2010
    Location
    Dulles,Va.
    Posts
    1,021
    Thanks Thanks Given
    Thanked in
    Re: glove box lock
    Flat blade screwdriver from the bottom, as long as you are gentle when you reinstall the should stay in place. Be careful because the little spring will take off flying!
    JP TS 35123 L (Family Resto)
    I can only gauge the quality of a friendship based on how hard it will be to shoot you when you turn into a Zombie; R.S.
    http://www.flickr.com/photos/pucman/...7608177739192/
    http://s1066.photobucket.com/albums/u418/Pucman1/TR3A/
  4. #4
    Jedi Warrior 6TTR3A's Avatar
    Join Date
    Mar 2008
    Location
    San Diego, CA
    Posts
    409
    Thanks Thanks Given
    Thanked in
    Re: glove box lock
    Not sure why you want to remove them. Be sure to reinstall them in the same slots or your key won't work.
    It appears from the photo that one of the "tumblers" is lower than the others. As JP mentioned there are miniature springs
    holding them up. One of the springs might be collapsed. Most brick & mortar locksmiths have a variety of the springs on hand. Take
    a good one in to them & see if they can duplicate it.
  5. #5
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    2,657
    Thanks Thanks Given
    3
    Thanked in
    Re: glove box lock
    What I am really up to is replacing the outside chrome ring with another tr3 and want to learn what and how they worked. In addition, I wanted to understand more about locks because my daily driver trunk lock was broke by this kid playing with it when it was locked; he forced it open and now it will not lock, so I replaced it with one from Moss. On this car, all my locks work with the stock key except the trunk and I want to move stuff in that lock around after I learned more.
    steve
  6. #6
    Join Date
    Mar 2008
    Location
    San Diego, CA
    Posts
    409
    Thanks Thanks Given
    Thanked in
    Re: glove box lock
    OK, Here's a good place to start your education;
    http://www.bobine.nl/jaguar/12-body/wilmot-breeden-union-locks-and-keys/
    It's Jaguar but all the important stuff applies to Triumph as well.
    Frank
  7. #7
    Join Date
    Mar 2008
    Location
    San Diego, CA
    Posts
    409
    Thanks Thanks Given
    Thanked in
    Re: glove box lock
    Sidescreen Triumphs only used 3 Wilmot-Breeden key & barrel series; FA, FS & FP
    The barrel designs were different depending on the application, but they could all be
    keyed the same. Sidescreen Triumphs used 2 keys, always the same series but two
    key numbers; One for the ignition and the boot lock if fitted, the other for the cubby box
    and the doors if locks fitted. My guess is so you could open the cubby box while
    the engine is running..??
    Frank
  8. #8
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    2,657
    Thanks Thanks Given
    3
    Thanked in
    Re: glove box lock
    I bought my tr3 in 1971 and it had one key that locked and unlocked, the doors, glovebox, trunk, plus worked the ignition. My plan is to rebuild the broken trunk lock, so it works with that key. I would send it out, but too expensive. I asked a local guy and he said there is a broken cheap cast pot metal peg in back that is broken and cannot be fixed. I assumed if I had the tumbles out and moved them to a new block perhaps I could get back to original.
    steve
  9. #9
    Join Date
    Mar 2008
    Location
    San Diego, CA
    Posts
    409
    Thanks Thanks Given
    Thanked in
    Re: glove box lock
    Am I to understand that you want to re-key the Moss Trunk lock to match the ignition, doors, etc.?
    That can be done only if the Moss key is the same series (FA, FS or FP) as your master key.
    If so remove the brass tongues from your broken cylinder and re-insert them in the same
    sequence in the Moss cylinder.
    If not look for a tired trunk handle/lock on ebay from which you can salvage an unbroken
    (same series) lock cylinder.
  10. #10
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    2,657
    Thanks Thanks Given
    3
    Thanked in
    Re: glove box lock
    There you go-- that is what I needed to hear. I have several old truck handles that I do not have the keys for and a couple that are unlocked and move, plus one I played with with an old key and got to open. I will check to see what series they are. I remember the numbers reflected what series the locks are either a FS or FP and the numbers are on the shaft and I know the series of the car. I should be able get a good functional block and keep my old tumbles to use in the correct sequences, and that should work. I wonder if I can move the whole tumbler assemble over without pulling each one out. This will be a good winter project for those cold days when I cannot heat the garage to 60 for bodywork!
    Thanks steve
  11. #11
    Join Date
    Mar 2008
    Location
    San Diego, CA
    Posts
    409
    Thanks Thanks Given
    Thanked in
    Re: glove box lock
    You have to remove and replace the brass tongues one at a time.
    Be sure to salvage the tiny return springs both from the donor
    cylinder and the broken one. Between the two you should have
    5 good ones. You can tell by looking at them if one is collapsed.
    Once you have your donor cylinder stripped, clean all parts with
    mineral spirits or even lacquer thinner. Get all the graphite/oil
    mess out. Clean then shine up the brass tongues with 600 grit
    wet/dry. Lube the re-assembled cylinder with 5 wt oil.
    (Sewing machine or synthetic clock oil) Don't use graphite.
    Test your work with the key. None of the tongues should
    protrude out of the cylinder, not even 1/64th inch.
    50+ year old tongues might have enough wear to not be
    perfect. If so, leave the key inserted and file the protruding
    tongue(s) flush.
  12. #12
    Join Date
    Mar 2010
    Location
    Dulles,Va.
    Posts
    1,021
    Thanks Thanks Given
    Thanked in
    Re: glove box lock
    Or send it to the lock guy and let him do it
  13. #13
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,216
    Thanks Thanks Given
    2
    10
    Thanked in
    Re: glove box lock
    Why not graphite?
    Randall
  14. #14
    Join Date
    Mar 2010
    Location
    Dulles,Va.
    Posts
    1,021
    Thanks Thanks Given
    Thanked in
    Re: glove box lock
    There are so many different kinds of graphite that is made. Generally with the tolerances in locks, it creates issues, usually jams them up. Most lock manufactures recommend a Teflon based dry lubricant like Tri flow or something similar.
  15. #15
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    4,647
    Thanks Thanks Given
    3
    Thanked in
    Re: glove box lock
    Interesting to know, JP!
    I'm with Steve. Locks are one of those fiddly tasks that I enjoy messing with...since you can do it indoors with the heat or AC on, when you don't feel like tackling a large greasy job outside. And it is SO nice having all the locks work with a single key!
    John
    1955 TR2
  16. #16
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,216
    Thanks Thanks Given
    2
    10
    Thanked in
    Re: glove box lock
    Thanks, JP.
    I was taught that finely powdered graphite was the preferred lubricant (but Teflon was not in common usage back then). I don't see how graphite could get gummy (unless someone added oil).
    Here's one lock maker's recommendation:
    "Yale KeyMark cylinders are lubricated from the factory with a Teflon
    lubrication . Cylinders should be lubricated periodically depending upon environmental conditions and usage . LAB Lube is the approved lubricant .
    Caution: It is not recommended to lubricate cylinders with oil or to mix lubricants ."
    https://www.lsamichigan.org/Tech/Yal...250_5-11RE.pdf
    Randall
  17. #17
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    4,647
    Thanks Thanks Given
    3
    Thanked in
    Re: glove box lock
    Along that topic, where can you buy the powdered Teflon? It works for all kinds of things...our piano tuner even blows it on the key action. But I haven’t found a source for it?!?
    John
    1955 TR2
  18. #18
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,216
    Thanks Thanks Given
    2
    10
    Thanked in
    Re: glove box lock
    The above referenced "LAB lube" seems to be available from most locksmith supply houses, eg https://www.clksupplies.com/products...lock-lubricant
    Here's another form, sold in high end bicycle shops https://www.amazon.com/Runaway-Bike-.../dp/B00W61ET9E
    I prefer the stuff suspended in solvent (so it goes on wet and dries for better adhesion), like https://www.mcmaster.com/?m=true#8710t44/=1a57w8b
    Randall
  19. #19
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    4,647
    Thanks Thanks Given
    3
    Thanked in
    Re: glove box lock
    Great...thanks Randall!
    John
    1955 TR2
  20. #20
    Join Date
    Mar 2010
    Location
    Dulles,Va.
    Posts
    1,021
    Thanks Thanks Given
    Thanked in
    Re: glove box lock
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
