Installing Front rotors to hubs
aero3113
I'm in the process of installing my brake rotors to the front hubs (later 5 lug hubs). My hubs have studs that are installed from the front of the hub with nuts on the backside. Should there be washers under the nuts? The Moss diagram only shows the stud with a lock nut, no washer?
red57
Interesting question - the Bentley Book, Pg. 263 refers to a "spring washer" aka lock washer. However the Moss catalog shows a lock washer for the BJ8 1/2" rotor but no lock washer for the earlier 3/8 disc - don't know why they would be treated differntly.
I have always used lock washers but now I'm not sure they are needed...
Dave
steveg
A locknut holds better than a spring (split) lockwasher. Plain washers are only necessary where you need to reinforce thin, i.e. sheet, metal.
I like the all-metal oval type, grade 8. I've been told these are the kind NASA uses:
drooartz Installing front hubs, tips? Spridgets 15
RickB Installing flip front kit, what's easiest way to secure back of bonnet for driving? Spridgets 40
J TR2/3/3A Having fun installing the front bumper and bumperetes Triumph 7
B TR2/3/3A Installing front fenders on TR3 from TRF Triumph 12
bighealeysource Installing front fender stainless steel beading Austin Healey 4
drooartz Installing front suspension/brakes - review Spridgets 1
H Installing New Front Wheel Cylinders Austin Healey 12
T Installing front anti-rollbar poly bushings Triumph 4
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
